Morning all...This will be the fourth attempt to post this this morning... Flickr being a pain in the effing azz this morning and keeps cutting all connections off, when I attempt to post... SO, lets try one more time,
Tha chassis is about 95% complete, and its time to start the interior. It will be sheet metal, so heres what I'm using...
The floor will be the tin seal from a 3ld can of peanuts (From Costco) This is the inner seal under the plastic lid. It (similar) can also be found on the 56oz/3.5 lb can of coffee mate.
Cut to fit, and glued down with super glue, contact cement also works well...
I had already cut the trans tunnel clearence area out in the chassis, since I'll be setting the enging back about a half inch further then stock.
Guys, I can't do this right now. I'm afraid I'll wind up smashing the computer if I do, I'm having to close flickr every time and reopen and reaquire the picture I want, then it throws me out of the program every time I try to post... I'll try to finish up later... Sorry, Doug
