Thanks for the tips, all. I think I'll try tacking them in place with a drop of white glue on each side, then masking the stripes. Fortunately it's just one white stripe per wing, top and bottom. It shouldn't be too hard. First, I'll use some Alclad duraluminum on the rotational joints for the flaps, as I found a color photo of Shangri-La that clearly shows those were bare metal, not olive drab or zinc chromate or something.
Groot, it's not really a bad thing, but I have three kits in this GB, (one finished), three 109s in that GB (two finished), and I just joined the 1945 GB because I got the Eduard Spitfire Mk XIII. Oh well, I suppose I do have a year :)
And on top of that, I worked on the P-51B a lot today (yay for living five minutes from work and having lunchtime airbrushing sessions).
I sprayed the wheel wells Testors zinc chromate, then picked out a couple of the detail bits and then washed and dry brushed them.I noticed the doors hold themselves in, so I guess I've got my paint masking figured out there.
The cockpit got an overall coating of Model Master interior green, then detailed with Tamiya applied via brush. Then some simulated chipping on the floor and overemphasized on the rudder pedals (so it might actually show up down there). I finished that up with a wash.
The IP doesn't have a decal, and there are no raised instrument dial surfaces to hit with dry brushing like Tamiya has on it's Wildcat, so I just threw in some suggestions to simulate gauges and left it at that. The colors are mostly random, but somewhat guided by the colors on the color PE set I have for the P-51D.
Lastly, I assembled and installed the Eduard color PE harness, because that seat looked too bar without one.
As of right now, the fuselage halves are together, and I have to say, you all weren't kidding - this kit is fantastic and falls together. I'm looking at filling very little, like maybe even just the small divots where the sprues attached on the underside.
Sad to think that this plane made it all of six-ish weeks before he crashed it.
-BD-
