So after holding off on painting during the cold my daughter accidentally woke me early this evening so I figured I'd take advantage of the relatively warm weather. I got the priming done using MM super fine lacquer primer when we got up to a balmy 45 a couple days ago. It worked so-so, but the cold snap may have had something to do with that as I paint in the garage.
This evening I was able to knock out some pre-shading. The rear windows are glued in, but the main portion of the canopy is just a dry fit and holds into place nicely, no glue, tape, etc. I'm still working on my pre-shade technique, and definitely struggled with the airbrush this evening (suggestions are welcome! I'm using a Badger 200 single action with the "gravity feed" attachment that goes in the bottom). I think the pressure was too low, but it will all be covered with the green and grey anyway.
Not pictured is my first attempt at Alclad on the external fuel tanks and the exhausts. I painted directly over the white primer as I wanted a relatively dull look to the metal finish. I'm pretty happy with the results, I may need to do a second coat, we'll see. I'll post pictures of those after they are dry. I really liked the way they looked when I was finishing up though and the Alclad went down like a dream.
Groot
