Steve, now I never thought the floats were fabricated from wood. I just assumed it was a frame work made from wood, and then covered with aluminum sheets . I might have to re-think the paint colour here and revert to aluminum.
So here are some photos from the bench:
On the left side, below the dime, is inital gluing of the fuselage halves. Not sure if it is warpage or what, but only applied cement at the cowl end and once that was set, some hand held pressure coaxed the back half together.
Next to that is Small Stuff resin engine of the Clerget 9B/Z (130/110 hp) Engine. This will be a like mini kit to build, I count about 46 pieces in total. Even a tool is provided to handle the tiniest detail.
Lastly, Minute72 PE detail specifically dedicated to the Hanriot.
The PE cockpit detail is done, and although the instructions do indicate four points to attach control wires, I'll likely skip that being 1/72 scale. The seat cushion is not affixed so it can be painted separate.
Lower wing attached, and dry fit of the PE detail inside the fuselage. The interior required both walls and floor sanded down.
regards,
Jack
