Hey crown, that G is 1/72? Looks sweet.
I have been busy doing another kind of painting, like the walls of our laundry room. The washer finally gave out after 11 years of faithful service so the wife wants new paint on the walls before the new dryer and washer get here.
So another update on my Dora.
Hasegawa dropped the ball here with the dash padding/coaming. It's missing a piece for the Revi sight to sit in which is absolutely wrong.
So the first thing to do here was to add some stretched sprue to match the rest of the padding.
I did some minor surgery on the Revi16B sight to make it fit in the square and added the glass pieces to it. I have resin ones but the Hasegawa sight was equally well made so I used it for this build. I also see in the picture the white is showing on the inside of the seatbelts . I need to touch up those to get rid of that white color.
I also attached the boarding ladder, loop and small straight antenna. The smaller antenna is a piece of very thin metal.
For the pitot tube, the thiiner part was replaced with .004 brass pipe into a drilled hole in the thicker plastic part.
