British Army Group Build 2020
    January 2017
Posted by mawright20 on Thursday, March 19, 2020 12:05 PM
Love the depiction of the Enfield next to the seat.
Posted by Bish on Thursday, March 19, 2020 4:02 PM
Thanks AA, thats very nice. And ye, i like the rifle perched there.
    November 2018
Posted by sickdude on Thursday, March 19, 2020 6:37 PM
Excellent work AA! Hope I will do, half as nice a job as you, on my builds, thumbs up sir Yes.
William (Willy)
    April 2015
Posted by Mopar Madness on Thursday, March 19, 2020 6:51 PM
Really nice AA!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    April 2006
Posted by jgeratic on Friday, March 20, 2020 1:54 AM
Little update on the Humber Scout Car ...
Before tackling the warped hull, thought it best to get some strength to the body by attaching the underside framework and such.  Above pic is the forward suspension, the leaf springs being composed of two halves glued together.  Major seam to clean up here, with details not lining up square.  So added 4 plastic strips that act as strapping detail.
Above shows the three areas where hull sides are cut apart to better 'splay' out to correct warpage.  The locations are actually weld beads that will have to be reintroduced later.
Further to the correction, have slightly widened the firewall, as well as adding additional thickness.   The piece in the foreground is the part that sits atop the firewall.  A strip of plastic sheet was added here as well to ensure a snug fit once in place, as seen below:
regards,
Jack
Posted by Bish on Friday, March 20, 2020 2:52 AM
Nice work there Jack and nice updates as always. Very informative.
    December 2005
Posted by Svenne Duva on Friday, March 20, 2020 6:51 AM
Hi,
here is a short update on progress (or lack thereof) with the W.O.T.8.
The parts come all sprues together in a single plastic bag.
This means that the bag is cramped and some parts have suffered from this at least 3 parts have actually snapped.
The parts are nicely molded in a soft grey plastic, care needs to be taken when cutting them of the sprues and using a razor saw is a good idea.
Constuction is fairly straightworward but the main chassis / undercarriage / wagon / frame (what do you guys call this in english?) is a multi part assenbly and alligning everything making sure that all parts are square is key.
I did and then again I didn't as you can see from the following pictures...
Didn't quite get the two main beams to allign which results in a bit of a warpage in the completed structure.
This is best vissible here:
As you can see those Kangaroo rails tilt starboard while the portside wheel axle tilt downwards.
While I was up to speed I then managed to get the wheel axle out of center as well:
Oh well, strange how focus and care changes with a bottle of wine or two...
Having said all that I really enjoy this kit!
Since I have now left the "damage control" stage behind me I will probablly aim for tilted wheels and removable drivers compartment.
I mean why not, WOTWOT :)
Keep up the good work guys and happy modeling!
With regards
Svenne
sic transit gloria mundi
Posted by Gamera on Friday, March 20, 2020 7:43 AM
AA: That looks awesome!
Jack: Great work there with the corrections. And I noticed that your kit is by Bronco too. Oh brother, are ALL their kits like yours and mine!?! I've got a couple more of their kits in my stash including a M24 Chaffee... Indifferent
Svenne: Nice work on the chassis (to a Yank that's what I'd call it, there might be a different term in the UK). That blows to see the sprues all broken up like that, you've done a great job repairing the damage.
Posted by Bish on Friday, March 20, 2020 7:56 AM
Gamera
I can't see Svenne's pic's until i check at home. But if your talking about what i think you are, then nope, its still a chassis.
Posted by Gamera on Friday, March 20, 2020 9:01 AM
Thanks Bish!
    April 2006
Posted by jgeratic on Friday, March 20, 2020 1:00 PM
Svenne, good start on the lowers.  Hopefully once the upper structure is added it will correct some of the present warping.
Thank you Bish and Cliff.
Bronco does seem to have something questionable about each of their kits, at least the few I have built.  I've done a couple of their Italian tankettes.  Though they went together well enough, been told they are a bit too wide scale wise.
Their A13 Cruiser Tank series is also well known for having shape issues, particularly the turret armour.
The only other kit  I've partially built/studied is their Staghound.   When working out some Canadian markings, was having trouble getting them to fit on the front hull glacis.  After enquiring about some measurents and studying these, I came to the conclusion that, although not perfect, the front glacis is not that bad.  The real offender is the hull  machine gun mound.   It could be a hair smaller, but the main correction is shifting the mound almost 3mm closer to side.
regards,
Jack
    December 2005
Posted by Svenne Duva on Friday, March 20, 2020 5:12 PM
Good catch on the allignment prob Jack!
Looking forward to your next update, comfortably seated and following if you don't mind :)
(have mine out of the Frankenstein cellar)
    December 2005
Posted by Svenne Duva on Friday, March 20, 2020 5:19 PM
Hi AA,
Very impressive!
Very Best Regards
Svenne
    December 2005
Posted by Svenne Duva on Friday, March 20, 2020 5:26 PM
Looking good Willy!
The Bantam is a killer.
Just don't.
Posted by Bish on Friday, March 20, 2020 5:31 PM
That does look like a complicated construction there Svenne.
    March 2017
Posted by Armor_Aficionado on Saturday, March 21, 2020 11:22 AM
Alright, she's DONE.  Time for the final reveal!  Bish, you can use the first photo here on the front page gallery:
Posted by Gamera on Saturday, March 21, 2020 12:29 PM
AA: WOW! Beautiful job there!!! Love her!!! Heart
Jack: Gee, a few millimeters off doesn't sound like a lot except when it's a model a dozen centimeters long.
    November 2018
Posted by sickdude on Saturday, March 21, 2020 12:49 PM
Man, that's some nice twucky modelling there (para-phrasing elmer fudd). Great job AA Yes.
William (Willy)
    November 2018
Posted by sickdude on Saturday, March 21, 2020 12:54 PM
Hey Bish, could you please strike the bantam off the rooster Wink. I have more then enough on my plate with Dingo, and my other 2 difficult builds right now. And spring is fast approaching, so I don't think i'll get around to it in time. Busy busy busy!
William (Willy)
Posted by Bish on Monday, March 23, 2020 4:18 PM
AA, thats a stunning job on that truck. Love it. Front page is updated, thank you for shareing that with us.
Willy, got your Bantum off.
    March 2017
Posted by Armor_Aficionado on Tuesday, March 24, 2020 11:27 AM
Hey Bish, thanks! Since that one went so well, I’d like to do another one! I have a second Tamiya LRDG truck kit (with the additional 5 figure ex-Master Box set, instead of the ex-Italeri 20mm gun), and I was going to build them both for a diorama I have in the works, so I might as well enter it into this GB, too!
Posted by Gamera on Tuesday, March 24, 2020 11:59 AM
AA: The second LRDG truck sounds cool!
William: Sorry to hear that but looking for more updates on the Dingo.
BTW: My Conqueror Mk II came in and the Chieftain Mk II was on sale. So if I ever get done with the PE on this Comet and get her all painted up I've got plenty more here.
    February 2020
Posted by The Model Guy on Tuesday, March 24, 2020 1:34 PM
Am I too late to join in on this? I started a Sherman Mk III last week.
Posted by Bish on Tuesday, March 24, 2020 2:48 PM
Armor_Aficionado
Looking forward to that AA, will get it on the list.
Posted by Bish on Tuesday, March 24, 2020 2:49 PM
The Model Guy
Nope, glad to have you on board. What brand and scale?
Posted by Bish on Tuesday, March 24, 2020 2:50 PM
Gamera
O, now i hope you can fit those in. I have the Chieftan Mk 11 so will be keen to see that built. And i have been giving that FV214 some thought.
Posted by Gamera on Wednesday, March 25, 2020 11:18 AM
I hope so too Bish. I normally go on holiday in May and I like to take an armour kit along so I can clean up road wheels etc while I'm sitting around watching TV at night. We'll have to see if Corona-chan has other plans for me this year though...
    November 2018
Posted by sickdude on Wednesday, March 25, 2020 2:13 PM
Those are 2 great looking pickups there Gam, they should go together really well, being from Takom and AH. Other then that, I haven't got anything to report, and probably for a long time... Spring is finally here, so i'm hitting the outdoors as much as possible, especially mountain biking/cycling. Been thinking bout this for awhile now. Seeing as I have very limited energy, because of my FM/ME/CFS, so I don't think i'll be able to do any modelling for quite a while, at least till next winter. Even then, I have way to much stuff to do round the house. So for those reasons, i'm withdrawing my entrance into the group build (builds). I'm sorry if I have left you fellers out to dry, believe me, it's not my attention in the least. I'm still going to stick around, and enjoy your builds. Oh, i'm passing the builds to my brother (German Armor), he has the time and (especially energy) to finish them. I'm thinking i'll barter him a decent commission to build them, after all, all the blood, sweat, and tears (not to mention bondo Wink) cost money. Maybe if I feel up to it, i'll drop by his shop to tinker along with him Smile. Thanks Bish, Gam, AA, and all others.
William (Willy)
Posted by Gamera on Thursday, March 26, 2020 7:48 AM
William: Sorry to hear you're bowing out. Still it's good to get outside and do stuff now that it's getting warmer. And it breaks the cabin fever from this stupid virus. Please do drop in and say hello from time to time if nothing else!
Posted by Bish on Thursday, March 26, 2020 7:50 AM
Sad to see you go Willy, but will hope your spot open and hopefully German Armor can finish it off.
