British Army Group Build 2020
Posted by Bish on Thursday, April 2, 2020 2:56 PM
Thanks Model Guy.
Posted by Bish on Thursday, April 2, 2020 3:42 PM
Nice start Bobby.
    February 2011
Posted by GreySnake on Sunday, April 5, 2020 1:54 PM
Slowly started work on the Sherman last week. I haven’t had much time to work on models lately or energy. My allergies have been kicked into overdrive with everything blooming here and I’ve been having pretty bad insomnia.
Anyway here’s the box.
Started the bogies first there’s nine parts to each one.
Next up is the final drive and differential housings.
 From building the Dragon Firefly VC last year I figured there would be some gaps and I was correct.  Filled in the gaps with putty yesterday and just waiting to get around to sanding them out sometime this week.
So far this kit seems to be going together a little easier then my last Dragon Sherman.
Posted by Bish on Sunday, April 5, 2020 3:12 PM
Nice work on those bogies. Surprised to her you need to use filler on a Dragon armour kit.
    February 2011
Posted by GreySnake on Sunday, April 5, 2020 10:40 PM
It is odd for a Dragon kit to need putty. I’ve built three Sherman’s by them and each one has needed some putty around the transmission housing. The Firefly I built last year by Dragon had some pretty big gaps that needed some attention. Here are few pictures from last year.
It was by far the worst fitting Dragon kit I’ve built. Just doing some test fitting on the current Sherman it’s going to be a breeze compared to the Firefly.
    April 2006
Posted by jgeratic on Monday, April 6, 2020 1:14 AM
Yeah, Dragon tried to fix some of those gaps on the front on some of their successive Sherman kits, but never totally eliminated the problem(s).
I've a couple Paul Budzik links bookmarked, showing his fixes if interested:
https://paulbudzik.com/tools-techniques/Sherman%20Construction/sherman-construction.html
https://paulbudzik.com/tools-techniques/Modeling%20the%20Sherman/modeling_the_sherman.html
regards,
Jack
Posted by Gamera on Monday, April 6, 2020 7:27 AM
Greysnake: With all those bogies done you're close to halfway done with assembly!
Shame about the gaps though. At least the hull ones if nothing else you splash 'sand' over them. The turret is kinda a PITA though. I normally just putty, sand, and then cover the whole thing with primer and texture it for the casting surface.
    February 2011
Posted by GreySnake on Monday, April 6, 2020 8:21 AM
Jack, already had links by Paul Budzik bookmarked but thanks for posting. His fixes were the entire reason I finished my Firefly last year otherwise I would’ve binned it most likely.
Gamera, thankfully those pictures are from the Firefly I built last year. The one I’m building right now is nowhere near as bad as that one! From the dry fitting I’ve done on my current build the turret will need a touch of putty and where the transmission cover mates to the lower hull as well. Both fixes are going to be pretty simple.
    April 2006
Posted by jgeratic on Monday, April 6, 2020 10:03 AM
Should mention too, TMD does offer some resin corrections for the Dragon Shermans.  Not really necessary, boils down to a question of time vs money decision.   Just do a procduct seach M4 DRA:
https://tigermodeldesigns.com/?s=m4++dra
regards,
Jack
    February 2020
Posted by The Model Guy on Monday, April 6, 2020 10:40 AM
Sherman Mk III finally seeing some colour. Weld beads added with tamiya epoxy putty.
Posted by Bish on Monday, April 6, 2020 10:55 AM
Got the roster updated guys.
Nice work there Model Guy, good job on that scheme.
Posted by Gamera on Monday, April 6, 2020 11:11 AM
Greysnake: Whew, glad to hear it!
Model Guy: Ohhhhhhhh, that looks good!!!
    February 2020
Posted by The Model Guy on Monday, April 6, 2020 1:13 PM
Thanks guys! Hard line camo on tanks is a new realm to me. Three different techniques ended with the brush to clean it up.
    January 2013
Posted by Zvezda1980 on Wednesday, April 8, 2020 10:53 AM
Work started with the Morris truck. The small chassis was assembled. Some of the power shafts were provided shorter than required by ITA, so they were supplemented with a little plastic. Exhaust was also replaced by a bent plastic rod.
this thing is small...
Posted by Gamera on Wednesday, April 8, 2020 11:09 AM
Zvezda: Looks good!!!
Posted by Bish on Wednesday, April 8, 2020 11:26 AM
Thats some very nice work there Zvezda. Theres a lot of detail for such a small kit.
    July 2008
Posted by Est.1961 on Friday, April 10, 2020 12:06 PM
A little progress, base coat on included a couple of other builds with same colour while I was at it. Business as usual with work apart from social distancing only 22 of us so spaced breaks and moving workable, weather's good so modelling time is scarce.   " alt="" />
Posted by Gamera on Monday, April 13, 2020 11:23 AM
That looks good 1961- dang shame all that detail under her where it can't be seen.
Btw: Is the Cromwell going to be entering this too?
    July 2008
Posted by Est.1961 on Monday, April 13, 2020 4:18 PM
That's very true G, I'm really chuffed with the scammell kit and have ordered some extras for it. The Cromwell is a long time building so wouldn't qualify, got two so I could build them with my thirteen year old get him off the xbox. He lost interest and patience kept his effort though might lend to a diarama. Keep safe.
    November 2010
Posted by Eagle90 on Thursday, April 16, 2020 3:56 PM
Stellar work everyone!  Really great builds!
I got a bit more done on the Grant.  Painting is coming along nicely....well, I'm having trouble with the colours for the commander.  I know it's funny because you won't even see his feet, but the socks...the socks worn in Africa had two or three colours to them?  I know, silly since you won't even see it, but I wanted to do them proud.  Anyway here are a couple of progress pics for you.
Posted by Bish on Thursday, April 16, 2020 4:05 PM
Looks good with the paint on bobby. Are you sure that the area at the top of the boots is not the putties rather than socks.
    April 2015
Posted by Mopar Madness on Thursday, April 16, 2020 7:13 PM
Looks great Bobby!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    November 2010
Posted by Eagle90 on Friday, April 17, 2020 5:09 AM
Bish
Thank you sir!  Please forgive my ignorance Bish...I had to look up putties.  LOL!  I don't think so.  It is at the top of the "sock" around the knees. Kind of a rolled up portion of a really long tube sock?  Here are a couple of pics that should help.  The first is my figure.  I can't find a standard colour for the part I'm talking about.  I did find this pic...the second one I found on the internet but it shows the top part the same colour as the rest of the sock.  I thought it was a different colour and that is what I'm having a time with finding.  Hope this makes sense.  LOL!
Like I said, I'm looking into this a bit too much considering you won't even see the feet or legs with him sitting on top, but I was curious.
    November 2010
Mopar Madness
Looks great Bobby!
Thank you sir.  Another great Tamiya kit!
Posted by Gamera on Friday, April 17, 2020 8:42 AM
Bobby: She looks good! I really like the pre-shading.
As to the socks I think the colour you've got them looks fine. I've only seen them in the khaki tannish shade.
You could have him as a patriotic Scot though- and paint them in a tartan... Wink
    July 2004
Posted by stikpusher on Friday, April 17, 2020 9:55 AM
The MP directing traffic here is good reference for colors
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    November 2010
Posted by Eagle90 on Friday, April 17, 2020 12:15 PM
Gamera
Thank you sir.  I got that from Andy's Hobbys on YouTube.  He does just about everone like that.  It does do a great job of highlighting.
OMG!  I should do those socks just because!  LOL!  That would look cool!
    November 2010
Posted by Eagle90 on Friday, April 17, 2020 12:16 PM
stikpusher
Hey Stik!  That's it!!!  That's the pics I keep seeing.  It appears to be a greenish color doesn't it?  Thanks for the pic!
    May 2011
Posted by Real G on Friday, April 17, 2020 12:48 PM
COVID-craziness, taxes, and a sick cat have been taking up my time, but I have not forgotten the GB.
I finally got around to start scraping all the ugly little seams on the PIAT launcher as well as the Enfield rifle.  Being an OCD modeler does not help in this regard.
The Enfield rifle has a functioning bolt, but it is wobbly so it will be glued in place.  The magazine is detachable, but that will result in scraped paint.  Spare magazines are provided, so one will be be glued in, and the rest will be scatterd around to never be seen again.  Stick out tongue
Anyway, Round 3 (or was it 4?) of filler will follow.  Almost there.  But it's a long way to Tipperary...
“Ya ya ya, unicorn papoi!”
    February 2020
Posted by The Model Guy on Saturday, April 18, 2020 10:54 AM
Finished!
