QUOTE: Originally posted by j.s.harrison
Geez i go away for a couple of days and miss all the action
Tweety great looking work mateYouv'e caught the haggard and weathered look of those late war 109's very nicely
just a couple of Is the spiral on the spinner a decal? and what do you use for to wash, for some reason i have trouble getting the wash to stay in the panel lines over decals.......
Tanker love the MarderI didn't realise they were built on the panzer 11 chassis, for some reason i always thought they were built on the 38 ton panzer.....
Once again great work fellas and thanks for sharing
Cheers Jules.......
Jules, the spiral is a decal, set down with Micro Sol over Pledge.
For washes I use artists oils mostly.
Sometimes their finish is a little 'grainy', so I turn to the MM Raw Umber.
After that, the rest of the weathering is done with pastels mostly.
In this case, I used smoke to enhance all the panel lines and for the heavy exhaust stains, then used pastels, black with a touch of white ground in, for the rest of the panel line weathering.
Worked pretty well I reckon.
As for the decal weathering/panel line problem, I used to have the same issue.
Now days I place the decal on, set it with Mico Sol, and while its still softish I slice along the panel line.
2 or 3 more light applications of Micro Sol, and after the final one, I use my finger nail to really 'push' the decal into the panel.
Then I wash as usual.
Works every time, but you have to be patient and wait for around 30 minutes after applying the Micro Sol before touching the decal, otherwise the decal will tear.
BTW, have sent some stuff to you today, lemme know when/if it gets there
