First and foremost, Audiophile121, you are most absolutley welcome to join this build!!!!! It begins Jan 15 2005 and ends March 15 2005. Any Cat, any scale, all aftermarket or OOB alllowed. Maybe I can answer your questions...
Basically, Audiophile121, resin is a two part process that produces a highly detailed piece that is typically brittle. Some detail companies like: Black Box, True Details, etc make aftermarket cockpit or conversion pieces with resin. Actually the only aftermarket stuff I have worked with has been resin. (Correct me fellas if i am wrong with the definition)
Black Box is a company that specializes in aftermarket conversion or high detail parts. I usually order their stuff through www.squadron.com. Usually these kinds of items require sandpaper(sometimes a lot) and milliput filler. The end result is more detail than you will find OOB- Out Of Box.
Next Up:
1/35 Tamiya Merkava
1/48 Tamiya King Tiger
1/35 Dragon M1A1 AIM
