Fw190D/Ta-152 "Langnase" Group Build
    April 2005
Posted by wing_nut on Friday, September 9, 2005 3:28 PM
Thanks Matt.
Jerry... worth saying twice... fantastic job.
Marc
    September 2003
Posted by blkhwkmatt on Monday, September 12, 2005 12:55 AM
Jerry,
Looks great, I love the subtle weathering, especially on the underside. Looks like it just returned from a flight!!!
Great Job, hope mine turns out as good.
Update
I have started on the painting on my D-9, talk about a complex paint scheme, a total of 8 different colors!!! I am attempting to paint it as "black 6" like seen here
http://hsfeatures.com/features04/fw190d9bigtail32ir_1.htm
but will be adding some mottleing on the sides, that is the biggest challenge so far, I think that my Fine needle for my badger 150 is a bit tweeked so am having some difficulty. Will post some pics for you guys to look at and hopefully give me some feedback.
Big Smile [:D]
Quidquid latine dictum sit, altum videtur!!! - Anything said in Latin sounds profound!
    April 2005
Posted by wing_nut on Monday, September 12, 2005 6:26 AM
QUOTE: Originally posted by blkhwkmatt
I was able to read it by right clicking on it and then zooming in on it. Thanks for the great info. I have ordered the Color of Eagles RLM 84 ( which it turns out was not a genuine RLM codeing but is supposed to be the Green blue or straw color that is on a bunch if the late war planes.) If I dont like the shade that the paint gives me I will definitly use the method that is mentioned in those instructions.
Matt
In the event you are unhappy…. I was playing around with the suggested mix form the decal sheet and it’s not even close. Remember I am going by the way it looks in print and on a PC monitor. So far most of what I have read uses the word “green” in the description of the color and the mix 76 and 02 is anything but that… too blue ish. Going back to my kindergarten art class on how to make green… I added some Gelb 04 then white to lighten to the right hue and it looked great. But of course I did not write down the proportions but they were approximately in color/parts:
76/4or5
02/1or2
04/1
White was added ‘til it was the right hue. I am close to that stage so when I mix up a final batch…. I will make a note of the mix. Found this web site as well along the way…. Check the bottom 3.
http://www.xs4all.nl/~rhorta/jgrlm.htm
Marc
    September 2003
Posted by blkhwkmatt on Monday, September 12, 2005 3:50 PM
76/4or5
02/1or2
04/1
Good info,
I have received the color of eagles paint and I must say that it is a very close match to most of the color profiles that are online. Having said that, I will pass along that you MUST thin the paint as suggested on the bottle (I used my standard - isopropyl alcohol ) and it was not good. I have switched to using the suggested distilled water and it works just fine. I am also a bit fed up with the Polly S acrylic paints, great colors, just a ton of tip dry going on and that is very annoying and time consuming.
Other than that I'll try to get some pics up so you guys can have a look.
EDIT
Here is a link to the profile that I am using to as reference/ inspiration:
http://www.hsgalleries.com/gallery04/fw190d9profileseep_1.htm
Big Smile [:D]
    September 2003
Posted by dragonfly on Monday, September 12, 2005 7:18 PM
Thanks Marc and Matt, I learned alot on this one. Can't wait to see your builds.
Jerry
    April 2005
Posted by wing_nut on Monday, September 12, 2005 7:25 PM
Jerry... after seeing yours... can I send your the model and the mixed paint and let you spray itBig Smile [:D]Wink [;)]
Marc
    September 2003
Posted by dragonfly on Monday, September 12, 2005 8:49 PM
C'mon Marc!...I've seen your work....You can paint....I just got lucky. LOL
Jerry
    April 2005
Posted by wing_nut on Monday, September 12, 2005 11:02 PM
Luck had nothing to do with itBig Smile [:D]
And I am getting lazy in my old ageDead [xx(]
Marc
Posted by Anonymous on Tuesday, September 13, 2005 7:09 PM
Dragonfly, are you kidding? That's a gorgeous build. Fine job.
Wing Nut, nice tail! I've already learned some stuff just with some quick looking around here. Thanks to all. Those pics I promised are coming soon.
    April 2005
Posted by wing_nut on Friday, September 16, 2005 12:16 PM
Finally getting some paint down on the 190 big tail conversion. Mixed up a whole jar of RLM “84” and that goes down tonight.
Marc
    September 2003
Posted by dragonfly on Friday, September 16, 2005 12:56 PM
Look's spot on Marc. Can't wait to see more.
Jerry
    April 2005
Posted by wing_nut on Saturday, September 17, 2005 4:04 PM
Here is a pic of the underside with the RLM 84 I mixed. The NMF is MM buffing Aluminum Plate sprayed over the base coat. Matt… I am curios as to how this mix compares to the brand you bought color wise… but I am happy with the results.
Marc
    September 2003
Posted by dragonfly on Saturday, September 17, 2005 5:45 PM
I'd be happy too. Looks great Marc. What's on the control surfaces?
Jerry
    April 2005
Posted by wing_nut on Saturday, September 17, 2005 8:16 PM
The references are very sketchy for this A/C but the rudder and bottoms of the Ailerons are 76. There are references to the NMF being the whole underside of the wing and others says that maybe the front half was 84. Since it is speculative I decided to go this route since it looks a bit more interesting.
Now my question is…Can MM buffing metalizer be sprayed with Future and decaled like normal paint?
Marc
    September 2003
Posted by dragonfly on Saturday, September 17, 2005 8:37 PM
Never tried it, but I don't think there should be a problem. Water based products, (future)cannot attack laquers (metalizer). BTW...have you noticed there doesn't seem to be much activity in this GB?
Jerry
    April 2005
Posted by wing_nut on Saturday, September 17, 2005 10:00 PM
Yup...lookin' like you me and Matt
Marc
    September 2003
Posted by blkhwkmatt on Sunday, September 18, 2005 11:01 AM
Looks good, by just looking at my model your mix looks just a bit too tan but very, very close. I think that I would be very pleased with that mix had I not bought the color of eagles paint.
I have most of the painting done, just have to do the small stuff and the canopy. I'll see if I can post some pics later on tonight.
    April 2005
Posted by wing_nut on Sunday, September 18, 2005 11:52 AM
Matt – Looking forward to seeing the pics.
Future this morning… decals tonightSmile [:)]
Had to re-dip the completed canopy (headrest, rails, slides, hand grip… all installed) in Future from a "missed a spot with the tape masking problem and the following paint clean up gone awry"… and I dropped it on the floor…. Dog hair stuck all over the placeDisapprove [V]
Marc
    September 2003
Posted by blkhwkmatt on Sunday, September 18, 2005 3:37 PM
ok here are the updated pics with the painting mostly complete. The Reich defense bands are painted on, I hate having to mess with those decals. Most of the colors are the polly scale acrylic rlm colors, the BMF is MM aluminium plate with a bit of stainless steel. Colors used are light blue(76), bright green, dark green, grey-violet, brown violet, the RLM 84 light blue green, and the BMF. Interiors are RLM 66 and 02.
My references were the Revell Germany instructions and the profile I found on another forum.
Here is the profile
And here is my effort
Hope that you guys like it!! Big Smile [:D]
Any and all comments are welcome!!!
    April 2005
Posted by wing_nut on Sunday, September 18, 2005 4:17 PM
Like I said inthe A/C section... super job and a great job on that camo.
Marc
    September 2003
Posted by blkhwkmatt on Monday, September 19, 2005 1:18 AM
I LOVE 1/32 scale WWII fighters, big enough to add tons of detail to and still small enough to fit in my small house. I am begining to see the light at the end of the tunnel with this one. All told i think that I have invested about 60 - 70 hours and a bunch of cash into her, but it is so much fun. I had to scratch build the spring in the tail since the Verlinden kit doesnt have anything that represents that part in the aircraft.
Thanks for the comments.
    April 2005
Posted by wing_nut on Tuesday, September 20, 2005 12:41 AM
My entry for the FW 190 D “Langnase” GB – and warm up for the 1/24 D-9 for the Battle for gern=many GB- Tamiya 1/48 JV44 converted to a “big tail”. Eduard PE cockpit and detail set, scratched strut springs and cowl flaps with actuators, Ultra Cast exhausts, Aero Master decals and MM enamels.
The rest can be viewed at:
http://photobucket.com/albums/y269/wing_nut_5o/FW-190%20D9/?sc=1&multi=2
Marc
    September 2003
Posted by blkhwkmatt on Tuesday, September 20, 2005 1:31 AM
As I stated in the A/C section great job, that is a Dora to be proud of. Congrats Smile [:)]
Thanks for sharing!!!
  • From: Aaaaah.... Alpha Apaches... A beautiful thing!
Posted by Cobrahistorian on Tuesday, September 20, 2005 7:57 AM
Wing Nut,
That Dora is GORGEOUS!!!! I hope mine comes out one tenth as good as yours!
Gonna have to get back into building mine as soon as I'm done with my current projects for work.
"1-6 is in hot"
    September 2003
Posted by dragonfly on Tuesday, September 20, 2005 8:13 AM
I'll say it again Marc....stunning Dora.!!!!
Jerry
Posted by pingtang on Tuesday, September 20, 2005 11:41 PM
Marc - Beautiful work on your Dora mate. It's almost inspired me to get mine back out and start working on it. Hope mine turns out as nice. Great work.Thumbs Up [tup]
Matt - Your Dora is looking great too. Nice paint work.Thumbs Up [tup]
-Daniel
    December 2004
Posted by biscuit3 on Wednesday, September 21, 2005 4:15 AM
wing nut,
that is beautiful looking aircraft hope mine is half that good
mick Bow [bow]Bow [bow]Bow [bow]
    September 2003
Posted by dragonfly on Wednesday, September 21, 2005 1:14 PM
Yep there's some beautifull models here, and we don't even have a group badge. Boohoo [BH] Boohoo [BH]
C'mon Pingtang, lookin forward to your build. I wish I could find a Ta-152. Boohoo [BH]
Jerry
    September 2003
Posted by blkhwkmatt on Thursday, September 22, 2005 4:11 PM
Since I have not been able to finish my 190, I have taken a few short minutes to provide us with an Idea for a GB badge.
I know that it is a bit on the too big side but well, it is a start and these are big WWII fighters!! Smile [:)]
    September 2003
Posted by dragonfly on Thursday, September 22, 2005 5:49 PM
Looks good to me Matt.
Jerry
