Moto GP group build '05
Posted by Anonymous on Monday, May 15, 2006 6:08 AM
Suzuki RGV500
I tried a new technique which I borrowed from the Armour and Aircraft modelers. Big Smile [:D]  I basically sprayed the exhausts with fairly bold blue, purple and yellow bands to simulate the burnt metal effect and the toned down the whole lot with smoke. When completed I “misted” a much diluted X32 (about 1 paint to 20 thinners) over most of the exhausts leaving only exposed the places where the real exhaust showed discoloration. Since the X32 is very thin it allows the underneath tones to subtly show through improving the impression of burnt metal
See pictures below
Andrew
    February 2004
Posted by Yamafreak72 on Monday, May 15, 2006 6:03 PM
I feel like a pre-schooler smashing together crayons, paste and tongue depressors after seeing this.
Right now, I've got to make a decision about my Duc.  I painted the insides of the fairings flat black as per the instructions, then a coat of Testor's Guard's Red on the outside of the panels to include the frame.  Now, those panels that are black on the inside seem to be translucent enough to allow some of the black to shine through, which is darkening the red significantly.  You can really tell the difference between parts like the frame and fender (which I haven't painted the inside black yet) and the rest.  I suppose I'll try another coat of red on the outside and see how it goes, but do you all have any suggestions as to how to avoid this in the future?  I'm just really afraid of losing surface detail by laying on too much paint.
Status: Nastro Azzurro NSR 500- finis!
    January 2006
Posted by wolfpac on Monday, May 15, 2006 6:06 PM
I've read (the key work there) that others will lay down a grey primer and than a white primer prior to paint.  I've often wondered why someone would bother putting down so many coats of primer but this may be the reason.  You guys have forgotten more about modeling than I know, so I hope this helps Smile [:)]
If you love your bike let it go. If it comes back to you, you've highsided. http://public.fotki.com/luke76/
    January 2006
Posted by wolfpac on Monday, May 15, 2006 6:12 PM
 Andrew Collodel wrote:
Suzuki RGV500
See pictures below
Andrew
Absolutley stunning.  Were all the parts painted with Tamiya Acrylics?  If so please list the color codes you used, I'd kill to produce such fine results.  I was going to experiment with some of the Alclad II paint such as jet exhaust, pale gold titanium and clear blue.  But If you are able to obtain these results with Tamiya paints screw $7.50 a bottle Big Smile <img src=">
Posted by joelrydh on Tuesday, May 16, 2006 12:27 AM
This was really stunning work! I have to agree with the others that you have really done a master piece here Andrew. It will be very fun to see them installed!
As for the cowling color issue I agree with Erik that a grey plus white primer job would take care of the problem. If you want a correct match with other parts you can prime these white as well as the different plastic colors will affect the final result. This primarily happens with translucent colors like red, yellow and some of the blues. Red is also a night mare to photograph by the way...
/Joel
Posted by Anonymous on Tuesday, May 16, 2006 5:50 AM
Hi WolfPac
The colours that I used were all from the Tamiya Enamel range and the process that I used was as follows:
·        X32 Titanium Silver Base coat
·        X23 Clear blue around the main areas where the staining is found
·        X16 Purple in bands next to the clear blue and blending in the blue/purple
·        X24 Clear yellow bands next to the purple again blending in the yellow/purple
·        X19 Smoke spray a fairly dark coat over all the bands etc to just tone down the colours a bit
·        At this stage it really looks more like Joseph’s Technicolor coat that a Suzuki exhaust pipe!
·        “Mist” coat X32 Titanium Silver this time very diluted about 1 part X32 to 20 parts thinners (Enamel thinners)
I misted the silver by looking a pictures of the Suzuki exhausts and where there was heavy discoloration I did not apply any X32 and where the exhausts should be silver I put down a heavy coat of X32 but again keeping it light here and there to let the blues and yellows shine through in some areas Smile [:)]
I think the end result was a “lot of luck” and not sure if I can get it right again, sometimes with modeling you have really good days and sometimes off days where nothing works? Wink [;)]
Andrew
Posted by Anonymous on Tuesday, May 16, 2006 8:05 AM
Hi Yamfreak72
I have had similar problems in the past with the black and have adapted my technique to putting down a white primer coat before the colour coats on the body parts and the frames.
The results work very well but you have to watch the primer it can turn into orange peel especially in corners etc. Apparently it is supposed to “chemically bond or etch” with the plastic but I have found that it chips very easily and now I rub down all body parts with 600 grit water paper, roughing it up nicely to get the paint to grip onto the plastic (I am not convinced by the “chemical bonding” story).
Next I lay down a mist primer coat to check for imperfections etc and then is all is okay a wet primer coat is laid down. Once the primer is dry I sand it with 1500 grit water paper and then spray the colour coats with super results, I have had some colours like TS49 Red and TS14 Black go on and produce a very smooth gloss finish. There is no need to do too many coats I find I can manage with one mist primer followed by one normal primer coat then one or two colour coats. I spray the black insides last after decals and clear etc and use Tamiya Black Enamel paint very thin and just put down enough black to produce the CF effect inside the fairings etc, you don’t see most of it anyway once the fairings are on.
Here are a couple of bikes sprayed recently using the above primer/gloss coat system
Senna 916 Ducati
 Pramac Ducati GP4
Hope this is helpful
Andrew
    June 2005
Posted by archangel571 on Tuesday, May 16, 2006 6:14 PM
Aside from the primers, I have seen online for a F2001 F1 car build that the builder used a coat of silver before painting the inside of the cowling black.  I haven't tried it myself yet but it falls in the same light reflection theory behind the lighter colored primers.
-=Ryan=- Too many kits... so little free time. MadDocWorks
    January 2006
Posted by wolfpac on Tuesday, May 16, 2006 6:49 PM
I'm curious as to how the effect of unsanded primer would look on the inside of race plastics.  The race glass on my Honda was very rough on the inside (fiberglass, not CF), I wonder if just using a white primer untouched would re-create a similar effect of unfinished CF?
Posted by joelrydh on Wednesday, May 17, 2006 12:34 PM
That's one crazy shine on those cowls Andrew...!! I'm simply amazed!
/joel
    February 2004
Posted by Yamafreak72 on Wednesday, May 17, 2006 10:02 PM
THIS JUST IN!
http://www.tamiyausa.com/product/item.php?product-id=14104
Can't wait to see the parts differences from the '04 to the '05!  Promised myself I'd take a break from posting for a while, but this I couldn't resist.
But just the #5 machine?
JUST PRE-ORDERED MINE!
    March 2004
Posted by SeaBee on Saturday, May 20, 2006 8:10 PM
Good to see you suys are still having fun! I'm still following, though taking a slight break from the bikes - but not for too long!
Andrew, lovely new technique for the exhausts! And those cowlings are simply... well... smooooth! Bow [bow]
Wolfpac, whether I use white or grey depends on the colour I want to do over it. The grey tends to show up irregularities a bit better, which is nice to get everything smoothed down. White allways for lighter/livelier colours, whether you use it over gray is up to you. From what I saw from Andrew's results, try that!
As for your question on the non-sanded primer - I don't think it's too textured. I never sanded it before painting, just painted and then smoothed out the paint - it never came out roughly textured. Yet again, from Andrew's tip, this will be the last time I've not sanded my primer!
Yamahafreak, that is very interesting indeed that only #5 is represented. For once you'd have thought you did not need to buy aftermarket tobacco decals, now you have to go out and buy aftermarket 46's!
Posted by shayne wright on Sunday, May 21, 2006 5:55 AM
Well hello and salutations everybody; I have hit a little snag with the KR500 it is now in the bin ,if I feel the urge latter on will dig it back out .Sad [:(]
For some reason I decided to put decals on with the cowling on the bike ,big mistake, while putting on front cowl was trying to get the frame connectors for cowling and everything sort of got broken with my big clumsy hands.Angry [:(!]
So have now decided to make the spiderman bike and the 2005 movistar bike at the same time so should be fin about same time.
Andrew-have to agree with everyone by saying that paint job/s are awe inspiring and jaw droppingMake a Toast [#toast]
Shayne
Posted by Anonymous on Monday, May 22, 2006 4:55 AM
Hi Shayne, I feel your pain and frustration with the KR500, I think we have all had those breakages, bikes are quite flimsy and they do tend to break for no good reason.  Sad [:(] Good luck with the Spiderman version Big Smile [:D]
Progress pictures of the Suzuki RGV 500 with the lower exhausts on
Will post more as the build progresses
Andrew
    January 2006
Posted by wolfpac on Monday, May 22, 2006 7:15 AM
The zook is looking very nice!  I have a 99 RGV-R that I have been toying with.  My problem is I cannot find any reference pics.  I'm looking to find out if the sub frame is CF, and what parts of the air box are CF.  I'm also looking for a view of the speedo and data collection boxes.
Very clean work!!!!!!
Posted by Anonymous on Wednesday, May 24, 2006 5:10 AM
The Suzuki RGV500 is completed pictures added below
Andrew
Posted by joelrydh on Wednesday, May 24, 2006 7:20 AM
S-T-U-N-N-I-N-G!!!!
Great work Andrew and such crisp photos. My best for this one!
/Joel
    January 2006
Posted by wolfpac on Saturday, June 3, 2006 10:57 AM
I figured most of us building the GP bikes were both race fans and motorcycle riders I thought I would drop this in here.
Ducati has anounced thier 2007 street version of the Desmosedici GP bike.  The purchase price is $65,000 US and includes 3 years free maintainence as well as the exhaust upgrade kit which will put the bike @ 200 RWHP.  I'll try to find the official spec link but here's a few photos.  They are offering two versions, one with white rear number plates, and the other with the white striping that will include the official sponsor logo's the customer may apply.
Sex on wheels in my opinion Bow [bow]
Posted by shayne wright on Saturday, June 3, 2006 8:30 PM
Wolfpac---Ah yes now that is what I call sexy on wheels Kisses [:X]Tongue [:P].
    ye owh (just get wacked around head by wife)LOL
Posted by joelrydh on Sunday, June 4, 2006 12:38 PM
phhhhhhhhwwwwwthhhhhhhhhhhhhh.......aaaaaaaaaaaaargggghhhhh, crap I don't have 65000 USD...Do you guys think they would accept my right foot as payment???
/Joel
    June 2005
Posted by archangel571 on Sunday, June 4, 2006 12:45 PM
Now is there mention of aftermarket marlboro decals for it??
    January 2006
Posted by wolfpac on Sunday, June 4, 2006 4:04 PM
The Desmo RR "Team Edition" comes with the factory sponsor decals that may be put on by the customer.
I would give more than my left foot for it Shock [:O]
    January 2006
Posted by wolfpac on Sunday, June 4, 2006 5:36 PM
Anyone watch the Italian GP?  Best race I think I have ever seen!!!!
I was really digging the Ducati colors for this race.  GP.com has not updated the site for race pics, once they do I'll post a few pics up.
Here is the article for the Street legal Desmo
Ducati just sent us this PR blog from Mugello to mark the launch of their production prototype:
Thursday Jun 1 2006
Desmosedici RR Unveiling:
The Ducati Desmosedici RR production prototype has been launched at Mugello on the eve of the Italian Grand Prix. Available from July 2007, this first true MotoGP replica motorcycle can already be reserved from the official Ducati dealer network.
DUCATI DESMOSEDICI RR: THE ULTIMATE DUCATI EXPERIENCE.
Scarperia del Mugello (Italy), June 1st 2006:
Ducati has chosen the magical atmosphere of the Italian Grand Prix at Mugello to launch the Desmosedici RR production prototype.
The dream of a true GP replica has finally come true and the Desmosedici RR will be the first-ever road-going motorcycle to offer such a stunning wealth of performance and technology that comes directly from Ducati's experience in MotoGP. The RR derives from the Ducati Corse Grand Prix racing Desmosedici GP6, the same bike with which Loris Capirossi and Sete Gibernau are competing with in the 2006 MotoGP World Championship.
The Mugello launch is the perfect occasion to reveal the shape and the technical characteristics with which the bike will go to market, confirming the high technological features of this exclusive and esoteric machine.
The body design and the aerodynamics faithfully reflect the Desmosedici GP6. The colour scheme, the fittings, the materials used in its construction as well as the technical features of the powerful four-cylinder desmodromic engine built by the Borgo Panigale factory engineers, leave no doubts whatsoever: the Desmosedici RR is the ultimate expression of the most extreme MotoGP racing machine today.
The project is currently in the industrialization phase and, as previously announced, it will be a limited edition motorcycle, with approximately 400 bikes being produced a year. The RR is scheduled to arrive in the market in July 2007, while from June 2nd 2006 it will be possible to reserve the bike through the official Ducati dealer network, with Ducati 999R owners receiving priority.
This is the new frontier of Ducati technological evolution, a dream come true, demonstrating once again the courage and the passion of Ducati, as well as the ability to transfer the experience of the racing world to a machine that is destined for road use.
Federico Minoli - Chairman and Managing Director of Ducati Motor Holding - and Claudio Domenicali - Product Director of Ducati Motor and Managing Director of Ducati Corse - together with Ducati Corse riders Loris Capirossi, Sete Gibernau and Vittoriano Guareschi were at Mugello to unveil Ducati's latest jewel of technology.
"This is an important moment for us, another dream come true. Producing the Desmosedici RR means offering the ultimate expression of Ducati technology, while remaining faithful to the tradition of every one of our road and racing bikes," declared Federico Minoli. "It is a challenge that we wanted to accept and although relatively few bikes will be made, the RR will be a true object of desire for all Ducatisti. It will be the ultimate Ducati experience, one that best exemplifies the passion and the ingenuity for which we are famous. Meanwhile the twin-cylinder remains and will continue to remain Ducati's traditional engine, having equipped all of our production models in the past and equipping them in the future."
"The Desmosedici RR is a true Grand Prix replica," commented Claudio Domenicali. "The technological level of this bike is extraordinarily high and for the first time ever all the authentic performance and technology of the ultimate MotoGP racing machine have been transferred to a road-going motorcycle. Over 200 hp of power for a bike that features exclusive components and quality materials, destined to become the new point of reference for production motorcycles. There couldn't have been a better place than Mugello for the unveiling of this new bike and who better to take the wraps off it than Loris, Sete and Vittoriano, because this bike is also their bike and all of their experience has gone into developing this road-going motorcycle."
Technical features at a glance
Desmosedici engine features:
200+ hp with racing exhaust kit (supplied with every bike)
989cc L-Four cylinder, Twin Pulse configuration
Desmodromic, with 16 titanium valves (Desmosedici)
quadruple 12 hole 'micro-jet' fuel injectors
Double overhead cams, gear driven
titanium connecting rods
cassette transmission
sand cast engine cases
magnesium covers
4 into 2 into 1 vertical exit exhaust
dry 'Slipper' clutch
Desmosedici chassis features:
Hybrid Trellis frame
Carbon fibre seat support
Öhlins nitrogen pressurized reservoir 43mm "FG353" PFF forks
Öhlins four-way adjustable rear shock with GP6 linkage and geometry
Brembo radial "monoblock" front callipers
forged and machined Marchesini magnesium wheels
New lightweight Corse electronic multifunction dashboard
aluminium alloy tank
Full Carbon fibre body
Bridgestone tyres with special profile and structure
The Desmosedici RR will be available with a special race kit that includes a 102 dB racing exhaust, a dedicated CPU, bike cover, track stand.
For this exclusive Ducati model a new dedicated service plan has been devised thanks to which each Ducati Desmosedici RR owner can count upon a three-year warranty and a three-year maintenance period free of charge.
Two versions of the RR will be available: the Desmosedici RR is painted in 'Rosso GP', has a white number plate on the tail section and a white Ducati logo on the fairing, while the Desmosedici RR 'Team Version' is painted in 'Rosso GP', and as with the factory Corse bikes, has a broad white stripe on the fairing. A team sponsor decal kit will be provided with each bike.
Taken from here
http://www.superbikeplanet.com/2006/Jun/tb/060601k.htm
    January 2006
Posted by wolfpac on Sunday, June 4, 2006 5:39 PM
Here's a shot of the Duc
Posted by joelrydh on Monday, June 5, 2006 11:52 AM
Yeah what a race!!!!!! One of the best ever as said. But I don't agree with you on the color scheme. I liked it at first (Perhaps the dream of new decal sheets to be released) but as the race went on I changed my mind.
/Joel
Posted by joelrydh on Monday, June 5, 2006 11:53 AM
And remember it was my RIGHT foot ;-)
    May 2005
Posted by nick31 on Tuesday, June 6, 2006 9:58 AM
Hi all,
Ive done all 250s up to now (making all of Tetsuya Haradas bikes - should be a nice little collection when its finished). Thought you might like to see this. Its an 2000 NSR500 that Harada used during pre-season testing in 2002, before he got the "new" look NSR. Came across a few pictures of it and liked the look of it, so just had to have a go and make it. Heres the real one:
The model is the Tamiya Nastro Azzurro NSR with custom decals. First 500 Ive tried. Not perfect imo, but as with everything, its practice, practice and more practice....
Posted by joelrydh on Wednesday, June 7, 2006 1:34 AM
Ohh, I LOVE these kind of projects. I haven't seen any pictures of this ride before and can say nothing about how you succeded with the decal job but it's a lovely bike and the build looks really clean.
My best regards
Joel
    February 2004
Posted by Yamafreak72 on Saturday, June 17, 2006 12:15 AM
OK, so I'm watching the FP2 for Catalunya right now, and I may be a little slow on the uptake, but why aren't Loris and Sete running Marlboro logos?  Did they lose Marlb. as a sponsor?  I saw that both the Camel Yamahas and Fortuna Hondas are wearing full tobacco sponsorship, so what gives?  And please forgive me if this is something I should have noticed earlier, hard to keep track of what countries they're allowed to run tobacco ads and which they're not.  Oh, and the Hayden RC is DONE, just gotta get the digi camera to cooperate, and I should have pics this weekend.
    January 2006
Posted by wolfpac on Saturday, June 17, 2006 1:19 PM
I do not beleive they run the Baco logo's during FP and QP.  I noticed this the first race of the season, the Ducs were running the logo stripes but no logo, but during the race they were running full Baco logo's.
Definitley looking forward to the Hayden bike!
