Dan Cooper - the Apache is really shaping up. Maybe it will be
ready in time for some action in Somalia
Are you going to make custom laser printer decals? That could
be tough over that darker green.
The Mig-31...
I've finally taken a break in my work to photograph some progress.
This first picture shows the amount of sanding that I am
performing along the fuselage side.
Serious terra-forming going on here --^
I've recarved the space inboard of the intake. It was way wrong.
It needs alot of follow-up smoothing.
A good shot of the putty usage on the side. I wish I took a before
picture of this seam, 'cause it was butt-ugly.
Tonight I worked on four different models at once! I'm in the F16
build, and a couple personal projects. It was sweet to load the
airbrush with a color, use on several kits, then change. Very efficient.
You can see I blasted the intake walls with black.
This project has only begun it seems. I will be at this stage for a
long time, I think.
