Time to start my builds up. I'll begin with the Kawasaki ZX-RR bike and here comes an introduction to the kit.
The Kawasaki ZX-RR transkit uses a Yamaha M1 as base but I would say there are quite a few parts needed. You'll need tires and rimbs along with brake discs and front forks and that's nearly all. I have the forks from another build but I think I'll just order the B tree from the M1 along with the tire bag instead of wasting a whole kit.
One of the nice attributes when buying S27 kits is as you all probably know, THE BOX.
Let's have a look inside it, shall we?
Here are the white metal parts (just some of them actually)
Resin parts layed out.
Seat and tank dummy is molded in one piece. As it will all be green this will ease the painting. I've ordered some Ninja Green from Hiroboy to use on this kit.
Here is the bottom side of the same part.
Engine leaves a lot to wich for. There are a lot of moulded in details that will be hard to pick out and give some life. I'll need to figure out if some parts will be replaced or if I shall just close my eyes and remember that all will be hidden undernieth the cowls...?
As you can see the front section of the exhaust system is...well, crappy...to say the least.
Here's a closer look at the side and top cowl part. Looks pretty well detailed and molded.
Unfortunately, when you put the two halves together what you get is this...
A very poor fit... I'll decide if cutting the insert pins will lessen the problem or if I have to pick out the old epoxy putty and starting filling away.
Anyhow, in general it's a fairly decent mold with just a little flash and some mold edges to take care of. No air bubbles what so ever from what I have spotted so far and the resin is very hard.
Kit comes with a PE sheet and decal sheet that both looks rather promising.
best regards
Joel
