Daywalker wrote: |
Thanks Aaron, you're making me blush! Now, how 'bout some Ventura pics? You gotta have some, right? |
Better add these before the XO gets back and does it for me! He is such the tyrant! LOL!
Ventura Update today!
Ok the Vacuform clear parts are kinda flimsy! They were kinda cloudy but a double dip let dry and dip again in future cleared them up pretty well!
Now the issue is they are very soft and traditional masking methods can be frustrating. The detail is soft as far as the framework as well and uneven in spots. Bleeding and paint mess seemed un avoidable. Then Frank Mentioned the old fast frames stickers that were pre laser cut stickers that you painted the color and simple stuck on maeuvering with soapy water. Haven't seen them lately but they worked well.
Anyways I made my own. I simply airbrushed the color on some scrap decal paper. I sealed it with the ink bonder as you would the decals and to my surprise it worked! All I had to do was cut the edge where the paint met the paper and they work fine. Here is what started as an experiment.
It worked so well I took my time and used a little more finess and patience and got this!
Left the edges rough.As I have to join them to the aircraft so why smooth them twice and do double work?
The paint on the windshield is actually on the box lid so you can see the future did it's job clearing things up!
The kits white metal guns look ok? But are too fragile for me. They bend in a good breeze. So I started experimenting again.
Started scratch building guns and did a turret as the resin piece was only an external part. Nothing inside to see right by the open door!
The resin part didnt fit anyways and made the whole thing sit way way to high up! Looked aweful! So I only used the resin gunsite which I cut off it.
I had some spare guns from the B-17 kits as I decided the scratched ones looked good but were really more of a 1/32 scale. Needed Dave to help me think smaller!
Yep the only original parts are the vacuform cover and the gunsite. I used the remote controll grip from a defunked B-25 and scratched some ammo boxes and feed chutes and called it good enough and much better to see thru the open door!
Can't tell you how much test fitting and alterations I did. A lot but the slight cant to the lower turret allows it to turn freely with out hitting any of the inside details.
Starting to look like an airplane! Gotta smooth it all out where I attached the vacuform parts and repaint those areas. Then it's onto weathering using advice from the good ol XO! And you all if you wanna give some!
Whatcha think? Come on don't be shy am I gonna make it?
