My Goodness!
I'm very flattered by your kind words lads, but honestly there really is nothing to it. The hardest part is finding a wooden base to start with! They are few and fsar between in my part of the world. I am lucky that I know a man who's good with wood!
But as a "quick how-to" how about if I take you through the base for my F-117? I can take pics as I go and you guys can tell me that I'm not so clever after all!
Right, here's how I did a 1940 Spitfire base..............
First off-get a photo of your aircrafts natual surroundings, then take the essential elements of the picture in order to start planning your groundwork. For example, during WWII, many airfields were just fields-so grass is what you need.
1. Find a nice solid base, about 300mm x 300mm-its a good size for WWII fighters.
2. Mask off the edges of the base. Paint the surface a dark brown colour.
3. Get some PVA glue and dump a big blob of it on the base. Now spread it over the surface of the base-be as messsy as you like! The more random, the better.
4. Now, while the PVA is still wet, sprinkle some country scenics grass over the PVA, there is no exact science involved, just spinkle it! Cover most of the PVA and make sure you get grass on the edges of the base.
5. Leave to dry overnight. When you come back in the morning, the PVA will have dried clear giving you green grass over brown mud. The surface is textured thanks to the PVA.
6. Finishing touches: For winter..........airbrush dark green over the base, use a misting technique. When that dry's- do the same again misting white for quit a distance away. This gives you a nice frosty morning.
For summer...........spray zinc -chomate green ove the grass, again use the misting technique.
Thats it!
7. Remove masking tape from the edges of the base and handpaint with a wood varnish of your choice.
8. Place finished model on base! Ta-dahhhhh!
Here's another pic.....you can get a better idea of colour and texture here.
