2008 Airliner Group Build
    November 2004
Posted by Chris_in_Japan on Sunday, January 13, 2008 8:47 PM
Welcome.. Look forward to seeing how she turns out..
Chris
On the bench:
                          1/48 RAAF 3 Sqn F/A-18B
                          1/150 /1/160 N Scale Japanese Rail diorama.
    November 2004
Posted by cdclukey on Monday, January 14, 2008 1:09 AM
Frank: Man. those photos look just like the real jet. Outstanding work!
Chris and Kenjitak: Looking very good so far!
I did so more work on the CV-118 tonight. Got the weight in the fwd fuselage and poured some carpenter's glue around it to keep it from shifting later. I built the wing assembly and found out it won't need much work at all after the glue dries. I had been planning on working on these builds one at a time,  but after I was finished with the CV-118 for the night I wanted to do more, so I grabbed the Braniff 707, cleaned up the fuselage and assembled the wings. The wings are nicely done and went together as easy as you please, and the dry fit of the fuselage indicates that there will be no seam at all. I'll post in progress pics later...much later, I don't have a digital camera yet.
Oh, and I also picked a color, finally: the Braniff jet will be orange...specifically Testors Competition Orange from a spray can.
    March 2005
Posted by philo426 on Monday, January 14, 2008 4:04 PM
I am building a Hasegawa 747 in the Ansett 2000 Sydney olympic scheme.
    March 2005
Posted by philo426 on Monday, January 14, 2008 4:05 PM
    March 2005
Posted by philo426 on Monday, January 14, 2008 4:06 PM
Here is a pic of one of the completed engines
    November 2004
Posted by Chris_in_Japan on Monday, January 14, 2008 6:01 PM
Comming along nicely.. Is that the Hasegawa 1/200 kit?
Chris
On the bench:
    November 2004
Posted by cdclukey on Monday, January 14, 2008 10:51 PM
Looks beautiful, philo...nice fade job. Are you joining the build? If so, I need to know the scale of your kit.
    March 2005
Posted by philo426 on Tuesday, January 15, 2008 12:19 AM
Yes it is the 1/200 scale kit !Thanks I love my Paasche VL really makes paiting easier!
    November 2004
Posted by Chris_in_Japan on Tuesday, January 15, 2008 4:06 AM
Just one thing I will bring up.. The one on the decals sheet is what appeares to be a 747-300, and it looks like the one that you have painted is a 747-100.. Not knocking it, just stood out when I went back and had another look at it..
Chris
On the bench:
    March 2005
Posted by philo426 on Tuesday, January 15, 2008 8:39 AM
Well the box denotes a 747-200 but that does not bother me.The decals will fit just fine.
    November 2004
Posted by Chris_in_Japan on Tuesday, January 15, 2008 3:28 PM
Noted....
The thing is, that the top deck is long, where by the 747-100/200 is the short original Jumbo design.. Completely different aircraft.. Infact I am not sure if Ansett Australia ever flew any 747-100/200's.. The only reason they had the 747-300 was because they started a "few" International services before its demise... The fleet was mainly smaller domestic aircraft..
Chris
On the bench:
    March 2005
Posted by philo426 on Tuesday, January 15, 2008 4:06 PM
Don't worry dude!I'll make her look good!As an aside the kits original decals are for Japan Airlines!
    November 2004
Posted by Chris_in_Japan on Tuesday, January 15, 2008 4:12 PM
Oh, I know its your kit and all, but just thought you would like some info regarding the airline..
Chris
On the bench:
    March 2005
Posted by philo426 on Tuesday, January 15, 2008 4:28 PM
Thanks for the info Chris!
    November 2004
Posted by Chris_in_Japan on Wednesday, January 16, 2008 4:26 AM
Does anyone know of any Airbus A330-200's in 1/144 scale?.. I am very much interested in doing a Jet Star International aircraft to go with my Qantas A38o..  Oh, and I am still looking for A380 decals aswell..
Chris
On the bench:
    May 2003
Posted by bablenw on Wednesday, January 16, 2008 7:03 PM
philo426;
Looks great so far I've wanted to try that beautiful scheme. Is that bare metal foil on the engines?  That's good stuff too.  I also like the Paashe airbrushes.  I have two H models and realy love them. Great fit and weight for my hands.
Chris;
Here's a link to Draw decals I found on converting the Revell 1/144 A330-300 to a 200 because I don't believe there is a 200. Check it out. http://www.drawdecal.com/download.htm
Folks; I have a related question since this is an airliner GB. How do you all paint the white on the fueslage? I use two methods. One uses the Tamiya laquers. I spray their Fine Surface primer followed by their Pearl White color. They are self leveling and look quite nice. The surface primer needs to be built up to get good coverage and is used as a base coat.
The second is that I'll under coat with grey primer and then spray with Krylon white. It's probably the cheaper way to go. The Krylon doesn't yellow and it drys very hard. Then I'll use the micro mesh finishing system to rub out any orange peel.  Safety note: a respirator and lot's of proper ventillation is a must using these paints!
P.S. I'd like to add a second kit. The minicraft B737-300 1/144 if that's ok?
NeilMake a Toast [#toast]
[IMG]
    March 2005
Posted by philo426 on Wednesday, January 16, 2008 10:10 PM
Yes sir!The ultra bright Bare Metal Foil makes the parts look like they are chrome-plated!I put the wings on today,but the horizontal stabilizers needed another coat of paint so I have to Future and foil the leading edges before assembly.
    March 2005
Posted by philo426 on Wednesday, January 16, 2008 10:15 PM
I used Tamiya flat white on the fuselage,gave it three light coats.Then I gave it two coats of Future.The flat paints tend to cover better and you can adjust the degree of gloss by how many coats of Future you spray on.
    November 2004
Posted by cdclukey on Wednesday, January 16, 2008 11:22 PM
Sounds great! What livery?
    November 2004
Posted by cdclukey on Wednesday, January 16, 2008 11:26 PM
I haven't done an airliner before, but on a battleship I did that had a lot of white (she was wearing post Spanish-American War colors) I used the primer-and-spray-paint method. the paint in that case was the Wal-Mart house brand, and it worked just fine as long as I warmed the can and sprayed light coats.
    May 2003
Posted by bablenw on Thursday, January 17, 2008 8:58 AM
Norwegian :Kandiden Scheme.
[IMG]
    November 2004
Posted by cdclukey on Thursday, January 17, 2008 9:54 AM
Thanks for the quick response, Eric. I'll make that edit right away. I'm not familiar with that scheme and didn't turn anything up on airliners.net. Can you help me grab a clue? Smile [:)]
By the way, that brings us to 14 participants building 25 models. I never thought this thing would be that big!
    January 2008
Posted by acmodeler01 on Thursday, January 17, 2008 12:07 PM
If you don't mind another builder and kit, I'd like to join with my Minicraft 1/144 777 wearing "Lindbergh Line" decals.
    November 2004
Posted by cdclukey on Thursday, January 17, 2008 5:56 PM
Welcome aboard, the more the merrier! That Lindbergh Line bird is one on my to-do list. Very nice.
    March 2005
Posted by philo426 on Friday, January 18, 2008 7:24 AM
I put the horizontal stabilers on last night and boy were they tight!I had to enlarge the slots a bit to get them to snap into place.I think Hasegawa did that to establish the proper dihederal(Which it did)!
    November 2004
Posted by cdclukey on Friday, January 18, 2008 2:11 PM
Looking sharp! I'm going to put your build info on the front page.
    November 2004
Posted by cdclukey on Friday, January 18, 2008 2:18 PM
Sixteen participants, 27 models. Sweet!
    March 2005
Posted by philo426 on Friday, January 18, 2008 4:13 PM
Yeah this is a cool group build.isn't it?
    November 2004
Posted by Chris_in_Japan on Saturday, January 19, 2008 6:16 AM
Yes, it's great to see that we are starting to get a bit of a build going here.. I am thinking about pulling out of the Australian RAAF, RAN, Army build due to lack of participation, and the fact that the guy who started it has gone awol, and I am still waiting to be accepted into it 2 months on..
As for me, I stripped the 747-400 today and filled the hole that was in the tail fin and also filled the windows.. I did a primer coat before I did the filling so I could see what I was indeed looking at.. I have lost alot of surface detail with the panel lines, but I am not too worried, they can be scribed, or re-drawn (which ever way I decide to go) later on.. Neil's decals arrived (thanks again mate) and so it has given the build life once more..  It will also give me a chance to try home made decals for the first time also!
Chris
On the bench:
    November 2004
Posted by Chris_in_Japan on Monday, January 21, 2008 6:45 AM
I know I am a day ahead, and everyone has probably had a good weekend. But it is Monday night here, and I simply didn't want this build to fall by the way-side like the Aussie one I am in, so I am going to give it a bump when there is no action...
As for me, I did want to have another pic ready, but I decided to do an extra white coat on the 747-400.. I have been playing around with my logo's for the home made decals, and I am really torn on weather I should do both the 747-400 and the A380 in the new Qantas markings. But I am still wanting  to do a JAL bird as well.. So its a toss of a coin at this stage..
ps: I would love to know where I can get an Airbus A330 from that I can convert for a JetStar build in 1/144?
Chris
On the bench:
