The Official F4U Corsair Group Build 4/01/08 - rolling end date
    September 2003
Posted by Daywalker on Saturday, April 5, 2008 10:00 PM
Glad to help Sean! Big Smile [:D]
Frank
    January 2007
Posted by Gigatron on Saturday, April 5, 2008 11:50 PM
Hey Sean,
As someone who has built several of the P&W R2800 double wasps, I can tell you what I've found through my research.  The gear covers are light grey, the piston cases can be either steel or aluminium in color, the pushrod cases are either black or aluminium in color and the rocker covers are either black or aluminium in color.  I've seen ignition wiring in aluminium, grey, black and copper color.  Pretty much any combination of those is correct.  I don't know if they came that way from the factory or those were restoration colors.  Unfortunately, most pictures of war-time engines are black and white.
-Fred
    September 2003
Posted by Daywalker on Sunday, April 6, 2008 3:54 PM
Well, I spent a lotta time yesterday and this morning in the shop working on the prop and engine for the Corsair.  The prop got the blade tips painted yellow, then masked for the black.  It was quite a chore to mask around each blade with Handitac for the black color.  Then a little chipping on the leading edges and voila!  This morning I put the logo decals on and she is done waiting for a clearcoat.
On the engine, I added a little brown to the plug wires and some silver where they connect to the ring on the housung.  The front of the engine looks very blue in the photos, but I think a lot of that is it picking up the blue from the background.  It is acually light blueish-grey.  Well, here's my progress thus far:
Frank
    September 2007
Posted by dirtball on Sunday, April 6, 2008 5:44 PM
  Frank, great job sofar. I havent got much done other than what I posted. I did try to dry fit some of the VERL. pit parts, thats it. But thanks for posting your pics, looking good!!.......Harv
"I once shot an elephant in my pajamas. How he got in my pajamas, I`ll never know!"
    January 2007
Posted by Gigatron on Sunday, April 6, 2008 7:10 PM
Ok, lest you guys think I don't plan on particimipatin' in my own group build, here's what I've done over the weekend
First, I cut out the gun and ammo bay from the port wing as well as removed the flaps.  I built and painted te PE gun/ammo bay and attached the PE parts to the resin flaps.
I also built, painted and poorly photograped the resin pit
Thankfully, it looks much better in person Laugh [(-D]
P.S. don't mind the bent IP - I fixed it after I took the photos.
I've also assembled and painted hasegawa's extremely complex engine.  For real, this thing was 3 parts.  Do they think everyone has a Ph.D in model building?  I almost gave up on the kit while working on this part.  I took up this hobby to relax, not be frustrated.
Laugh [(-D]
I've also assembled the fuselage and replaced the cowl flaps (terrible, terrible experience).  I'm in the least favorite part of the build - sanding and filling Sad [:(]
Next up is to cut up the starboard wing for a folding wing conversion.  Apparently, I'm  glutton for frustration and punishment.
Between work and a busy weekend coming up, progress is going to be slow for a while.
-Fred
    September 2003
Posted by Daywalker on Sunday, April 6, 2008 8:52 PM
Thanks Harv, I appreciate that! Big Smile [:D]
Fred- Looking good my friend! Thumbs Up [tup]
Frank
    September 2007
Posted by dirtball on Sunday, April 6, 2008 10:45 PM
  Well so far tonight, I managed to cut my finger and discover I`m missing 1 part of my Verlinden cockpit set. #32. I believe it is the emergency hyd. hand pump, but not sure. Anyway, does anyone know who I can contact to get a replacement? I bought it from Squadron. Any help would be appriciated.............Harv
    January 2007
Posted by Gigatron on Monday, April 7, 2008 9:12 AM
well, construction is on extended hiatus.  I've been having a heck of a time with the seams, so I finally tracked down a place that carries brushable Mr. Surfacer 500.  Lord knows how long it will be before I get  the stuff - and hopefully, it does what it promises.
-Fred
    September 2007
Posted by dirtball on Monday, April 7, 2008 9:46 AM
good morning! FWI I noticed that Great Models has Mr. Surrfacer 500 in stock!. Get it while it lasts................Harv
    October 2007
Posted by Summit on Monday, April 7, 2008 9:47 AM
Fred, Sprue Brothers are showing to have it in Stock ! I just ordered me a bunch from Hong Kong, took about 3 weeks to get them.
Fred & Frank your Progress looks Great !
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
    January 2007
Posted by Gigatron on Monday, April 7, 2008 9:50 AM
I orderd 3 bottles from missionmodels.com.  Hopefully, they get here before the end date of the build Laugh [(-D]
-Fred
    January 2007
Posted by thuds1 on Monday, April 7, 2008 9:55 AM
 Hi Fred,
 Just a simple question,what do you use the Mr. Surfacer for?
 Frank
 ps
 just getting back into my half done f4U
    October 2007
Posted by Summit on Monday, April 7, 2008 9:57 AM
Fred, I can send you one out of my stash , and you can replace it when yours arrive.
    January 2007
Posted by Gigatron on Monday, April 7, 2008 11:20 AM
Hey Frank,
Mr. Surfacer is supposed to be one of the best filler/primers out there (if you believe the hype).  It comes in 3 grades 500, 1000 and 1200.  500 is for filling seams, scratches and sink holes. 1000 is a filler/primer - basically a primer that is good at filling surface scrathes.  And 1200 is a finishing primer that can be sanded glass smooth.
Sean, thank you for the offer.  But since I won't get a chance to get to my bench until sometime around the 19th (girlfriend seems to be keeping me extra busy over the next couple of days Wink [;)]), it really doesn't matter when it shows up.  But thank you again for the offer.
-Fred
Posted by navypitsnipe on Monday, April 7, 2008 11:21 AM
   well i decided to re-engine my fictional Corsair V, instead of trying to stuff in a Wasp Major (R-4360) i've opted to commit blasphemy and install a Curtis-Wright R-3350-32W. i decided on this engine due to almost identical dimensions (same length, slightly larger Dia., slightly higher weight) and Superior HP (3700 HP WEP (War Emergency Power) as opposed to the R2800's 2800 HP) when compared to the P&W R-2800. i figure the higher power will give me the ability to loadout the Corsair with a single Mk. 13 torpedo, 2-500 lb. bombs, and several small depth charges on each wing or 5" rockets instead.
40,000 Tons of Diplomacy + 2,200 Marines = Toughest fighting team in the world Sis pacis instruo pro bellum
    September 2007
Posted by dirtball on Monday, April 7, 2008 11:37 AM
  Navy, sounds fantastic! Cant wait to see some pics. Should be a true KILLER!!.........Harv
Posted by navypitsnipe on Monday, April 7, 2008 2:04 PM
  well, it'll be a while before i post any pics of this one, at least until after i return stateside. although as soon as my F2G and accessories show up i'll get started on it and then post some pics.
    October 2007
Posted by Summit on Monday, April 7, 2008 9:55 PM
Anybody know of a paint or decent method to make exhaust pipes look like they should ? I have never had this much to deal with Confused [%-)]
    September 2003
Posted by Daywalker on Monday, April 7, 2008 11:03 PM
Spent some time on the Corsair this weekend, managed to button up the fuse and spray the front under the windscreen.  Also added a few wires to the boxes on the dash for a little extra detail.  Started cleaning up the seams, and hope to put the wing on in a couple of days.  Here she is:
Sean-
WHen I paint exhausts, I usually give them an overall coat of black first.  Then I dry-brush them with raw umber, burnt sienna, and tan.  After glueing them in place, I dust them with similarly colored pastels.  Here's a look at the effect on my P-40E:
Frank
    October 2007
Posted by Summit on Tuesday, April 8, 2008 8:50 AM
Frank, Thanks for the tip. I usually can bluff my way through with most. This corsair has all the piping attached. Even though all a person will see is the outlets once the cowl is installed. Blindfold [X-)] Its taunting me saying "make me look real" Laugh [(-D] The pipes on your P-40 look really good, are those resin ?
    September 2003
Posted by Daywalker on Tuesday, April 8, 2008 11:11 AM
YW Sean.  The P-40 exhausts are kit parts, drilled out with a tiny round bur.  Thanks for the kind words! Thumbs Up [tup]
Frank
    September 2007
Posted by dirtball on Tuesday, April 8, 2008 1:00 PM
  Moning all. I have another delima. Its the revell engine. Or lack of. Its so inacurate and not sure what to do. I guess I could fix the push rods & add wiring, but would it be better to spend the $16 or so ang get a resin AM engine. Would anyone be willing to sell a Trump engin?? Yea thats what I thought. But where the mags are ,are two humps and thats it. All the pics I`ve seen, I`d have to do some seious cutting to make it look right.Any sugestions? Heres a pic to show what I mean.Sorry about the fuzziness......Harv
 100_0106.jpg f4u engine Revell picture by dirtball_photo
    September 2003
Posted by Daywalker on Tuesday, April 8, 2008 1:14 PM
Harv-
Yikes!  Not such a good looking powerplant.  Does Quickboost make one for it?  I have one of theirs in 1/48 that I use as a guide for modifyling kit engines.  If they make one and it's as nice as the 1/48 version, it is DEFINATELY worht the $$$ IMHO.  HTH! Thumbs Up [tup]
Frank
    September 2007
Posted by dirtball on Tuesday, April 8, 2008 1:25 PM
  Yes, Quickboost does have one. So does Engine & things. There is one other maker(they also do guns and some other stuff) but I cant recll there name. Wish I could. And yes, it is a pi** poor engine. I even thought about using my P47 but its not accurate for the F4u either(thank God!)
    January 2007
Posted by Gigatron on Tuesday, April 8, 2008 1:33 PM
Harv, ditch the POS revell engine and look around for an amftermarket resin kit.  If you need a 1/32 Wasp, get a Contact Resine kit  http://design-marketingintl.com/product_info.php?products_id=265
I used one for my 1/32 HellCat.  Builds up to a really nice powerplant
if you need 1/48, get an Aires
-Fred
    September 2007
Posted by dirtball on Tuesday, April 8, 2008 1:46 PM
Frank & Fred, thanks so much for the heads up. There is still one othe manufacture I know. But the name escapes me.Its a tough choice. Cont. Resin, Quickboost & engine & things. All are outstanding.
    October 2007
Posted by Summit on Tuesday, April 8, 2008 2:53 PM
Harv, that engine looks like the one's in those old Hawk Kits I like to build.... I say go with the resin, it is pretty nice . Thumbs Up [tup]
Fred you did a real nice job on your engines. next time need one built I will send mine to you with a bribe.Laugh [(-D]
Ok, Freds engines are a Tough Act Pirate [oX)] to Follow but here is a peak at mine. Photobucket.Photobucket
    September 2007
Posted by dirtball on Tuesday, April 8, 2008 3:10 PM
  Sean, thanks buddy. I am going with resin, just dont know wich one yet. Yours is NICE!! Me likey!  I want mine to look that good.Weres the wires? You are going to add them, right ?......Harv
    October 2007
Posted by Summit on Tuesday, April 8, 2008 7:00 PM
Hey Harv, I thought up a good use for that Revell Engine - Give to your Wife and she can use it for a cookie cutter. Then you could have us all over for coffee and radial engine cookies ! Dinner [dinner] Big Smile [:D]
    October 2007
Posted by Summit on Tuesday, April 8, 2008 10:11 PM
Hey guys, I stumbled upon an article in an Old FSM September 1989 on Detailing Radial Engines. Here is a pic from that article that may help someone out. Color
