Is anyone else itching to get started? I've been lining up everything I need for this build and coming up with my build sequence. I'm using a bunch of AM stuff on this build, so that's a necessity.
The only thing I'm still lacking is some extra styrene sheet stock; I'm planning a wee bit of scratchbuilding in the cockpit. This'll be my first attempt at any kind of scratchbuilding, so it'll be simple... just some stuff that should be mounted on the floor like the tail wheel lock and hand hydraulic pump.
Here's the AM stuff being dumped into this build:
Quickboost resin engine, landing gear doors, and gunsight.
Eduard PE: a bash of the Zoom set for the Academy kit, and the full-boat color PE set for the Tamiya kit.
Also getting a prop and wheels from the spares box, originally from the Tamiya kit.
Waiting patiently to get started!
Kevin
Kevin Johnson Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
