White_R34 wrote: |
WOW! That is some hard core work right there. Hey, wanna make an extra set or two? I'd throw you a few bucks for 'em - you might have found yourself a little cottage industry there... How many guys are in this build? Figure, what, 5 - 10 bucks a set... man you could do alright...
But seriously, here is a quick update from me:
My AFV Club /4 is going along. I am finding that this kit hides a bit of frustration to it. Just about every locating pin is either too big for the hole it is supposed to fit into or it does not really align properly. There are also some pretty 'fiddly' parts that you need about 3 men and a fat kid to get into place properly. Ah well... heres a few progress shots:
First, the lower hull - even the way that went together was a little frustrating. You have to align three locating tabs (which thankfully actually fit) and sandwich a couple other pieces in between at the same time... Even if you can accomplish that, getting a nice join between the hull and floor was not possible (I think the rear axle - one of the pieces sandwiched in between - is just a bit too long...)
Next, the front suspension - this is composed of 6 parts, so not too extreme there, but they all required quite a bit of cleaning. Addtionally, they are all pretty fragile, but the way they are attached to the sprues makes it hard to remove them without damage or distortion...
And finally, the suspension attached to the hull. The wheels are only slipped on (again - after sanding down the mounting pins to fit). Those wheels are another story - it is not exceptionally clear in the photo, but the join seam between the halves is nasty - going to require a fair degree of cleanup...
Despite the challenges, I am having a pretty good time with this kit. It is definately testing my skills...
