A little more progress to talk about. Sorry, no photos. My own computer has decided to die - not sure what's happening there, someone said I may have a virus but I wonder if the motherboard might be done - so I'm on my wife's PC where I don't have my photo software.
Any way, I did drill out the struts and inserted a piece of rod to give more strength to those parts. Have not attached the struts yet permanently but did test the attachment strength and it looks good.
Per my resource book, the P-36 did not have windscreen framing along the front curvature of the windscreen. Instead there was a bar installed inside at the top with two wires (four total)attached and coming down the inside of the windscreen and connected to the fuselage. I have decided to replicate that first by sanding off the molded on framing, sanding the part down with 12000 grit sandpaper, and now it has a coat of Future drying. There was a tiny bit of hazing left over from the sanding but I'm thinking the Future will clear it up, if not I'll strip the Future and go at that piece again.
I next have to fashion that bar and wiring. I have a good piece of wire for the bar but I'm not sure that I have anything small enough to do the double wires on either side. I may end up just doing a single wire for each side.
