#100 Tristar Pz 38(t) B COMPLETE PICS P.10 10-24-09
    November 2006
Posted by dupes on Monday, September 28, 2009 4:48 PM
Bill - a lot short on time, so I'll just say that this looks terribly cool. Thumbs Up [tup]
    October 2007
Posted by panzerguy on Monday, September 28, 2009 9:57 PM
   Bill wonderful work! Now that I've seen how the cut outs look I've stopped cringingApprove [^].
   Have you thought about filling the openings in with clear plastic? Maybe add some rivets using clear sprue.
"Happiness is a belt fed weapon"
    July 2004
Posted by wbill76 on Tuesday, September 29, 2009 8:42 AM
Thanks Marc! I know you're busy these days and appreciate you stopping by.
Steve, thanks as well and glad to hear you like the cut-outs. I had considered clear plastic but in the end that will cause more problems than it would solve from a masking standpoint. I deliberately preserved all the rivet detail when I did the cut-outs so there's no loss of detail in that department. Thanks for the suggestion, great minds think alike in terms of the possibilities! Wink [;)]
    July 2004
Posted by wbill76 on Saturday, October 3, 2009 8:02 PM
I managed to get all of the construction work done on this project today but due to rain wasn't able to start painting. Hopefully the weather will improve tomorrow, we'll see!
In the course of the past week I started the assembly of the MK replacement workable tracks. I find that it's best to work on these a little bit at a time while watching TV, it helps break up the monotony/repetition involved in their assembly. The MKs for the 38t assemble very straightforward, pins on either side using the supplied jig and you can assemble runs of 9 links at a time then join the runs together using the same jig. I assembled two runs of 92 links each and may have to add another link or two once they are installed in the end.
With that out of the way, it was time to finish up the remaining hull details. I installed the fenders on both sides, starting with the right hand side first. I used a combination of regular and liquid glue to make sure it sat at the proper height/angle starting at the rear and working my way forward. The final piece added was the front fender brace and I used a pair of tweezers to help hold things together here while the glue dried to insure a good join. This was repeated on the left side. I installed the fender that accommodates the large stowage box since this is a feature found on 25 PzReg, 7 PzDiv vehicles.
Checking the reference photos for this unit in PT 18 revealed that they didn't fit the cowled mirror that is a common feature on Ausf Bs. The reason for this is the large stowage box since it blocks any view the mirror would've provided otherwise. This meant a little bit of correction needed to be done on the front portion of the fender in terms of removing the mount post and filling the matching pin hole that would ordinarly have taken the mirror mount. I also carefully trimmed down and sanded the reinforcing line in the area that the mirror would've occupied so that it too would have the appropriate gap. The large stowage box was assembled and mounted and the PE straps installed for the large crow bar that occupies the rear portion of the fender. PT 18 states that the reflectors for the front and rear fenders were only mounted when night driving was anticipated and were ordinarily stowed in a felt-lined box when not used so I scratch-built the mount posts for the reflectors out of scrap PE and installed them at the front and rear since the kit parts have the reflectors and posts as a single part. Last but no least, the pot for the radio antenna was added to the superstructure front plate but the top left off to allow for detail painting and drilling out to take a brass antenna later on. It's also worth noting here that the mount post for the front Notek is integral to the fender...if I'd chosen to go with the France 1940 vehicle as provided in the finishing guide, that too would've needed to be removed since the reference shots show it wasn't fitted at that time but added later.
The right side fender received the standard treatment for the jack and grouser box even though the option is provided in the kit to have the jack stowed behind the box instead of on top of it. The 38t stowage was often moved around by the crew based on unit or individual crew preference so it's nice to see these kinds of options provided. The pics of my chosen unit had the jack in thee standard spot so I didn't make any special modifications to this fender. I left off the jack block, axe, and wire cutters since those will be detailed and installed after painting to keep things simple.
That just left the remaining details on the engine deck and rear hull. I installed the engine hatches without any issues and also added the PE air intake cover provided in the kit. The exhaust was assembled and a small amount of putty needed to fill a gap on the pipe at its base. Other details like the brake light, the tow hooks, the tow chain hooks, and the rear Notek light were also added at this point. The kit includes a nice PE latch bracket for the central towing hook, this was added using small amounts of CA gel.
Everything is now in place and if the weather cooperates, I should be able to get the exterior painted tomorrow!
    January 2012
Posted by I make stuff on Saturday, October 3, 2009 8:48 PM
Oh, Bill, this has "Epic" written all over it.  The cutouts are a great, and brave, way to avoid interior work in vain.
Looking forward to exterior paintwork.
Bill
    January 2009
Posted by Schnobs on Sunday, October 4, 2009 1:29 AM
Hey Bill!
Are you going to paint a red outline like they do on some large scale armor cutouts?
Very nice work so far!
"There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance. That principle is contempt prior to investigation." Herbert Spencer
    February 2008
Posted by stick man on Sunday, October 4, 2009 1:34 AM
WOW! Bill this build is realy looking GREAT!!! I hope to see more soon!
Smile [:)]
I'm 15 and I model I sk8board and I drum what could be better.
    December 2008
Posted by model maniac 96 on Sunday, October 4, 2009 1:53 AM
Wow, that is awesome! I love the way that your interior/cutaway is looking!!
Thanks, Jim
"Veni, Vidi, Vici" Julius Caesar: I came, I saw, I conquered.
    July 2006
Posted by redleg12 on Sunday, October 4, 2009 6:53 AM
Nice work as always. Now all you have to do is pray to the great rain gods!!!
Can't wait to see the paint!!
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    December 2006
Posted by Jester75 on Sunday, October 4, 2009 9:59 AM
Bow [bow]
Amazing work Bill, just beautiful!!
Eric
    July 2004
Posted by wbill76 on Sunday, October 4, 2009 10:24 AM
Thanks Bill, Orion, Jim, and Eric for the kind words and support!
 Schnobs wrote:
Hey Bill!
Edmund, I'm leaning towards doing just that. Have to see how best to execute it after the exterior paint work is done though.
 redleg12 wrote:
Nice work as always. Now all you have to do is pray to the great rain gods!!! Can't wait to see the paint!!
Thanks Mike! Woke up this morning to overcast skies and higher than usual humidity. If I'm lucky it's done with the actual rain and I can get enough time this morning to actually paint. And, with that, I'm off to the garage to make the most of what is available! Big Smile [:D]
    May 2006
Posted by panzer88 on Sunday, October 4, 2009 10:40 AM
WOW!!! She's shaping up to be a beauty.
    January 2008
Posted by Bodge on Sunday, October 4, 2009 11:06 AM
Modeling at its finest for sure.great stuff . I dont get much time for lookin in lately but this is magic.Thumbs Up [tup]
    May 2005
Posted by hughes2682 on Sunday, October 4, 2009 12:32 PM
Bill,
Very nice work on this one (as always). That had to be a pensive moment, or two, when you decided to cut. A very nice way to show off the interior. Which is exquisite.
Cheers
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
    July 2004
Posted by wbill76 on Sunday, October 4, 2009 12:46 PM
Sadly the weather has conspired against me once again! The humidity level is too high and even with a moisture trap on my compressor I'm getting water in my air so I had to shut things down about half way through applying the primer. Maybe if things improve in the course of the week I'll be able to get more paint work done. This is the first time I've ever not been able to paint due to humidity and living in a desert, that's saying something! Laugh [(-D] So instead of painting I'm going to go see the Toy Story/Toy Story 2 3-D double-header with my wife so that the Sunday isn't a total loss. Wink [;)]
David, Andy, appreciate the comments as always!
 hughes2682 wrote:
Bill,
Cheers
Dave
Thanks Dave, I'll admit to having a lot of trepidation about cutting but finally had to just dive in and do it. Nothing ventured, nothing gained after all! Glad you like the interior. Thumbs Up [tup]
    October 2007
Posted by panzerguy on Sunday, October 4, 2009 8:04 PM
   Looking good BillThumbs Up [tup]. Sorry the weather won't play ball. It's not cooperating up here either, last two weekends have been nothing but rain.
    July 2004
Posted by wbill76 on Sunday, October 4, 2009 8:26 PM
I'm holding out for better weather during the week. Most of the clouds have cleared out now, one good day of clear skies will dry things out pretty quick. I've never encountered a circumstance here before that the moisture trap couldn't handle...it was working pretty good for about 15 minutes or so and then gave me quite a shock when it spat out the first bit of water! Since I work with enamels, it just about gave me a heart attack! Laugh [(-D]
    July 2006
Posted by redleg12 on Sunday, October 4, 2009 8:47 PM
OK take it from a chemical engineer who has designed many an industrial high pressure air system (and a 10 gallon system for the bench and air brush). Go to Home Depot and pick up a 5 gallon pressure tank. Put the tank between your compressor and air brush. Even if the knock out bottle fails the tank will buffer you. I can paint in the pouring rain at 95% RH with no problem.
About once a year you need to empty about 3 oz or so of water from the tank.
Better yet, you are in the garage...move up to a high pressure compressor. With the 5 gallon tank and HP compressor your worries will be over!!
Rounds Complete!!
    February 2009
Posted by scratchmod on Sunday, October 4, 2009 9:09 PM
Sorry to hear that there was no painting session Bill, I was so looking forward to seeing that 38t with some paint on it. I can relate to the rain situation, nothing worse than spitting water instead of paint. Guess we have to wait a bit longer.
Rob
    July 2004
Posted by wbill76 on Sunday, October 4, 2009 10:28 PM
Thanks Mike, will have to check that out and see what I can come up with. The compressor I use is a smallish hobby compressor and I don't really need anything bigger for what I use it for.
Appreciate the sympathy Rob and sorry to disappoint. I was depressed myself as I was looking forward to getting the paint on, especially after all the masking work I had to do to get ready for it! Laugh [(-D]
    April 2005
Posted by wing_nut on Monday, October 5, 2009 8:03 AM
Really looks great Bill. I see what you mean about the modeling gods nowWink [;)] At least with a PITA cold I can still do some modelling.  Can't wait to see this one done.
Marc
    July 2004
Posted by wbill76 on Monday, October 5, 2009 7:19 PM
The weather gods were more accommodating this evening vs. yesterday so I was able to complete the work I started. Prior to painting, all of the cutout areas needed to be masked off and this required a little more creativity than usual due to the nature of the areas to be masked. For the hull, I used strips of blue painter's tape that were cut down and positioned with tweezers to create a vertical barrier. For the turret, since the cutouts were curved, I used strips of sheet styrene inserted from below and wedged in between the small gap at the turret rear and the front with a small strip of painter's tape at the bottom to keep it in position.
The primer coat of Italian Dark Brown was applied by airbrush to check all the putty work and insure I didn't have any bare plastic showing through.
Next came the base coat of Panzer Schwarzgrau also applied by airbrush. The road wheel hubs were sprayed while the rubber rims were still in place to insure paint didn't get into unwanted places. Once the paint was dry, the rims were dismounted and painted separately with enamel Gunmetal.
I added some highlights and shading to the Panzer Gray with a mix of 80/20 Panzer Schwarzgrau/Light Gray and lightly sprayed it on various areas for some color variation as a foundation for the later weathering steps.
    May 2005
Posted by hughes2682 on Monday, October 5, 2009 7:24 PM
Bill,
I like the tonal variation you have with the grey. I may have to try your approach with a Panzer III and IV in the stash. Superb work indeed.
Cheers
Dave
    December 2006
Posted by Jester75 on Monday, October 5, 2009 7:25 PM
Man I do love panzer grey! This is looking fantastic Bill!
Eric
    August 2008
Posted by Pvt Mutt on Monday, October 5, 2009 7:29 PM
Alright, we've got forward progress at last.Make a Toast [#toast]
Woop it on me Tex.Bow [bow]        Tony the Mutt
Shoot Low Boys They're Ridin Ponys
    July 2004
Posted by wbill76 on Monday, October 5, 2009 10:02 PM
Dave, Eric, and Tony, appreciate the comments and interest. Moving ahead at last indeed! Wink [;)]
Posted by IBuild148 on Monday, October 5, 2009 10:16 PM
Bill,
Awe inspiring! That is "outside the box" level 5 craftsmanship. Just my two cents.
I hope you are going to display this in a class box case with a placard "100th Build by WBill" and date.
IBuildOne48
Teach modeling to youth!
Scalefinishes.com
http://i712.photobucket.com/albums/ww122/randysmodels/NMF%20Group%20build%20II/Group%20Badge/NMFIIGBbadgesmall.jpg
    July 2006
Posted by redleg12 on Tuesday, October 6, 2009 6:02 AM
Ahhhhhh - Paint at last. Nice shading, looking good!
Rounds Complete!!
    July 2004
Posted by wbill76 on Tuesday, October 6, 2009 9:12 AM
Thanks Mike!
IB, thanks for the comments! I am considering this one getting its own special case with a little plate. Have to see what will work best, probably a small case such as those designed for auto models.
    December 2003
Posted by psstoff995 on Tuesday, October 6, 2009 9:19 AM
Nice work! That's some tricky masking- you're braver than I leaving it open- I would have done something to crimp it off haha but I have little control with an AB and probably would have done the major coats with a rattle can Whistling [:-^]
Nice work! Bow [bow]
-Chris
US Army Infantryman
