Thanks much White! I've been looking forward to that kit for awhile now.
I got some work on mine done too.
I know it's been awhile, but I kinda got stuck for a bit. I got really indecisive about some minor details; piddling stuff really. So I just decided to finish the build, and fix any details I don't like later.
I blocked off the seams on the ramp w/ a thin sheet of styrene. It's not fancy but it works.
Next, I began painting. I started w/ the turbine fans. I painted them MM Steel on the outer parts, and MM Jet Exhaust on the inner parts. I thought this might look like oil or grease stained metal. They were very flat looking, so I post shaded the fan blades w/ MM Gunmetal.
I'll apply washes and drybrush them later.
Because metallics are hard to clean out of the airbrush, I sprayed some other stuff that needed to be painted at the same time.
Then I airbrushed a basecoat of MM Israeli Armor Sand over all the major assemblies. Because this is a big kit, and I tend to shoot at low pressure, it took several hours to get complete coverage. The model has some wicked undercuts on it, especially on the bottom and in the cargo bed.
I'm happy w/ this color. In these images, or under very bright light, it looks very green, but in shadow it looks almost grey. It's a green w/out a lot of yellow in it.
The hoverfans appear to have protective "bumpers" on the bottom of them, so I painted them w/ a mixture of Black and Aggressor Grey, to look the like the rubber used on tires. If I were going to weather this vehicle more, I'd carve some nicks and gouges in them.
I painted the engine housings MM Olive Drab to break up the color monotony a bit. Maybe they were manufactured in the US and shipped over? Who knows?
Then, I post shaded the "bumpers" and engine housings. A little sloppy, but I'll clean that up in the next painting stage. Adds some nice depth to the details.
The next step is the long process of post shading the vehicle hull itself. That's what I'm doing tonight.
