First, my apology. I should have posted something in here quite a while ago, but life got in the way. It does that sometimes.
Second, I want to say I have very much enjoyed reading this thread so far, and to add that the builds in this thread kick a**. I'm now a fan of Israeli armor, and look forward to building at least one Merkava III and maybe a Zelda too.
Ok, so here's what I've been up too.
The Hellhound comes in a huge box. Here it is next to a Dragon's T-34/85.
The box is packed too. I had trouble getting all of the stuff back in after I opened it.
The instructions are well laid out, easy to follow, and have color pictures and painting guides. Unfortunately, they are completely in Japanese, I language I have no skill w/.
There is lots of interesting details molded into the surface of the kit, which suits my painting style. There is even non-skid texture on all the upper horizontal surfaces (you can just make it out in the picture). I've never painted that before, so I may have to ask for advice from the knowledgeable sages hereabouts.
The kit is extremely well engineered, and the tolerances are very close. So close in fact, that when I was test fitting the upper and lower hull, they got stuck together, and the only way I could get them apart again was by damaging part of the upper front deck.
I repaired the parts as best I could by melting them back together w/ Tamiya liquid cement, but I'll probably need to do some more later. I'll need to wait 'till I get the first coat of paint on to really assess the damage.
This model is going to be big. Here is push fit together, next to the aforementioned T-34. Notice I haven't even added the hoverfan units yet. I need to start thinking about where and how I'm going to display this beast. I may do an "in-flight" sort of thing; that way I can keep the model's footprint to a minimum. The trick will be giving it a sense of speed/motion. I'm not sure how to do that yet...
White_R34 hung some photos of some Merkavas in another thread, and I was struck by what appeared to be rivets all over the armor plates. It gave the tanks a scaly, prehistoric appearance, which I immediately decided to replicate on my kit.
The kit itself comes w/ a bunch of little rivet heads, mounted on a sprue. You shave them off, and apply as necessary. I thought they were a little small and bland, so I decided to replace them. I had some aftermarket hexagon bolt heads laying around from another build, but not enough to do the job...
...so I went on Squadron.com and ordered some 1.5mm rivet heads from Czeck Masters, along w/ some IDF tank crew. Ya never know...
While waiting for those, I started replacing the grab handles on the sides of the hull. They were molded on as flat pieces, so I started by sanding them almost completely off, leaving just enough so that I could drill holes for the new handles in the right locations.
After some long and tedious work, I had completely replaced the molded on handles w/ ones made from .02 mm brass wire. I only glued one side of each handle, so that I could make sure they are all even and at the same angle (note the locations of the soon to be applied rivets).
So that's where I am for now. More later.
