Nino
Nice work on the finish.
Thanks Nino!
Nino
Now, choose wisely were you cut for the interior.... and no monkeying around.
Okay got it... no monkeying around. Like I'd (cough) do such thing. Hehe.
Nino
That Epoxy looks like a fantastic product. Thanks for the tip. It self-levels and won't melt plastic! Bet we can find a bunch of uses for it. Since it sands and self-levels I suppose it might be just the thing for sink holes and such too.
Correct... had I known about this stuff I could have used it to fill all the imperfections on the Monsters and Motion kit, and do it in one swoop. It would have been perfect for that. This wouldn't have fixed the horribly warped misaligned pieces, but you get my drift.
The instructions with this epoxy say that it will produce heat. I have to tell you; I had seen no evidence of that. In fact, there was so little heat that I was getting concerned that I either mixed it wrong, or that I had a bad batch. I rechecked my mixing process more than once and it looked correct. Once when the epoxy reached a stage of holding its place (for me about 45 minutes), with deep reservations I set it aside. Maybe the heat came later, can't say. The next day I found the mixing stick solid as a rock. I test sanded the stick and giddy up--all systems go, the rest is history.
This is interesting stuff. On the mixing stick there are thin and thick pieces of cured epoxy. What surprised me too is that the thin pieces are extremely strong, not even bendable. Maybe I shouldn't be surprised. Maybe I am used to 5-minute hobby epoxy that for me, does not have a good bond nor strength.
Anyhow--shifting gears. I found some to scale chairs that I will order on-line. The price is not outrageous and buying them will save me time fabricating from the ground up. I will modify them though in keeping with the movie prop. Probably more effort than its worth since you might not be able to see the detail but... why not have fun with it.
Do you see what you did here, Nino? You got me yammering. LOL
