Castles of Steel, 1880 - 1914 *Group Build* (pg 17)...
    April 2006
Posted by waynec on Saturday, November 26, 2011 11:26 PM
i think my lightship is an eastern express. already have one mast done so the fighting tops are out unless i drop the damn thing again. am using brass rod for all the spars. may use thin styrene for the railing to. i have a lot of luck with cya and i have some real thin stuff plus accelerator. i have a generic GMM 1/450 merchant ship set i will use for the railings. i chose that over the 1/400 naval set because i have some 1/400 or 1/500 freighters and it has ratines which i may need while the naval set had a bunch of radars i will never use. this was the armoured castle british design of the RENOEN and MAJESTIC class and was the last pre-dreadnought design before HMS DREADNOUGHT.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    February 2010
Posted by EBergerud on Sunday, November 27, 2011 1:56 AM
I didn't need to know about another Eastern European model company. Especially one that sells a WWI German torpedo boat. Or a 500 scale Royal Sovereign. (Maybe wearing WWII warpaint because it was Rooskie for a while: that would spoil the fun.) This is a bad influence. Pretty soon I'll be thinking of resin.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    March 2007
Posted by bondoman on Sunday, November 27, 2011 12:16 PM
I have made progress on the Ting Yuen, finishing a couple of other projects first.
After a little debate I stuck with the earlier Victorian paint scheme, as I'd like her to be fully rigged as she was for the delivery sailing from Germany, and it's then the earliest pre-dread in my collection.
I probably will leave one of the barbette covers off though as the big guns look nice.
I stained the KA decks with a semi transparent stain I have called "coastal boards", a warm gray.
Big word of caution- if you use the wood decks, they are cut to go down BEFORE the midship structure. I don't understand that, as it would make those sit high, but there it is. So I of course found out the hard way and had to peel the first one back off and trim the two main deck pieces, but not a big deal.
Posted by Anonymous on Monday, November 28, 2011 12:40 PM
Nice work, M0J0's!!! Toast
Posted by VanceCrozier on Monday, November 28, 2011 2:03 PM
Quite the fleet being assembled here folks - looking good!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    March 2007
Posted by bondoman on Tuesday, November 29, 2011 2:20 PM
fermis
 Manstein's revenge:
That wooden deck loos very sweet.  Any issues with it?  How did you affix it, CA?
 It is self adhesive. No real problems. Some spots are just a touch long (main deck, fore and aft) and needed to be trimmed (1/2mm at most, pretty close!). The hardest part about it is getting the backing sheet off the adhesive. Pretty easy stufff!
I am having nothing but trouble.with the decking. I can't get it to stay flat. Some additional trimming on the main deck, in place, will help. Up on the boat deck, it's harder because it didn't fit too well between the various skylights. oh well, should have done more trial fitting. live and learn.
Posted by Anonymous on Tuesday, December 6, 2011 7:40 AM
bondoman
 fermis:
 Manstein's revenge:
Maybe Fermis has some tips?
Posted by Anonymous on Monday, February 20, 2012 6:59 PM
bump...
    August 2005
Posted by Tracy White on Monday, February 20, 2012 7:24 PM
Manstein's revenge
bump...
Fist Bump!
Tracy White Researcher@Large
    March 2007
Posted by bondoman on Monday, February 20, 2012 8:01 PM
Right, well, the 60 day test of the deck glue has gone well, so, on to modeling!
Time to shoot some yellow!
    February 2010
Posted by EBergerud on Tuesday, February 21, 2012 1:26 AM
I have not yet been called home. I'll be going to St. Paul in mid-April and USS Oregon will come with me and it will be the first project there. I'll bring Varyag just in case of mishap.
Anyone note the ad for an "Encore Models" rendition of Olympia? Ancient Revell plastic with PE, wooden decks, metal barrels - and all for only 90$. Last year a couple of shops had the old version on back order but no idea when it would be in. Wonder if this group got exclusive rights to the kit. Pacific Coast Models sells mostly Italian aircraft and I think that's their strategy. They buy the plastic in Eastern Europe and throw in all kinds of after market stuff.
Eric
    February 2010
Posted by EBergerud on Tuesday, February 21, 2012 1:28 AM
BTW: any chance of this enterprise becoming a real group build? We're kind of hard to find. Might recruit someone to build the Zvezda Dreadnought.
Posted by VanceCrozier on Tuesday, February 21, 2012 7:13 AM
Tracy White
 Manstein's revenge:
bump...
Fist Bump!
Sometimes you've just gotta bump to get back on the front page! (I've done it... Embarrassed )
    January 2003
Posted by p38jl on Tuesday, February 21, 2012 8:07 AM
ive been busy with other projects.. but my Olympia is right under the bench.. my feet tap it when I sit down...
[Photobucket]
Posted by VanceCrozier on Tuesday, February 21, 2012 8:22 AM
"Kicking the tires", are we?
Posted by Anonymous on Tuesday, February 21, 2012 9:46 AM
Ya'll guys need to get back into the dry-docks and get to work on these ***'s...I'm assembling a fleet of Chinese Heavy Cruisers just in case I can to impose a quarantine on your houses until these sucka's get done...
    February 2010
Posted by EBergerud on Monday, April 16, 2012 5:40 PM
Going to take a crack at the 1/225 Glencoe Oregon starting tonight. I've looked at a lot of models of the kit online and while some are wonderfully done they all look like white bathtubs. I want a gray battleship coming home from battle like this one: Oregon returning from Cuba after the ceasefire:
I've never done a dio so that means I'm going to have to cut the hull in two, reinforce it with sprue and give it a styrene bottom. How I'm going to do this, I'm not quite sure. You may see a Varyag or a Chinese BB instead if there's a catastrophe.
Eric
Posted by Anonymous on Monday, April 16, 2012 6:20 PM
EBergerud
http://i971.photobucket.com/albums/ae191/ebergerud/afterbat.jpg
Eric
Thank you for saving my Group Build...
    March 2007
Posted by bondoman on Monday, April 16, 2012 6:27 PM
Ohcome now...we are all going to get to Tsushima sooner or later!
    February 2010
Posted by EBergerud on Monday, April 16, 2012 7:07 PM
If I could buy a real one, I'd sacrifice a chicken to Apollo or someone because I really don't know how this is going to work out. Plastic is pretty thick and so's my head. May even give a dremel a try. You may see Varyag yet. Although one thing is very evident. There's only one mast on Oregon - even the real ship junkies give her very little rigging. So if I don't cut my hand off or I don't wreck the ship, this might be fun.
Eric
    April 2006
Posted by waynec on Monday, April 16, 2012 10:36 PM
me too between finishing up shelf queens for a group build AND to get more practice plus doing stuff for contests i haven't done anything with my chinese ships. the alanger POTEMKIN is coming along slowly. i think i cleaned up the BORODINO launches well enough they won't look bad painted dark gray. using dark gray instead of black.
    March 2007
Posted by bondoman on Tuesday, April 17, 2012 12:17 AM
So, let's get this on ye band of brothers...
Eric, just get a keyhole saw, razor saw or a pair of diagonal wire cutters and chop off the hull. Then sand back to the paint line I explained. I have only built a couple of water line models that got mounted to a display, but I like acrylic gel the best, followed by plaster. Problem with plaster is that the display only lasts a couple of moves around.
My big hold up on  the Ching Yuen battleship is that there are way too many parts, and painting half of them yellow is challenging because they need to be sprayed etc. However I have a plan which is to drill a pin into the bottom of each, stick to a foam panel, and...
Wayne, I build black ships with any of the old Polly Scale railroad (Floquil) colors like Engine Black or Steam Power Black. Any and all attempts to do a true dark gray fall way too light IMO.
Those ships were black, and if they don't model photo so well, oh well.
    February 2010
Posted by EBergerud on Tuesday, April 17, 2012 2:39 AM
Herr Feldmarshall,
Appears that coal burners do live. Knock on wood, but I spent the entire night splitting Oregon's hull (for which it is not designed) and I think it worked. If so we're going to have a 1/225 scale Tamiya style "waterline" battleship. In real life it was less than 400' long so it's not huge. But bigger than a 700 scale dd, yes.
News soon.
Eric
    February 2010
Posted by EBergerud on Tuesday, April 17, 2012 3:00 AM
Perhaps the quandry wasn't clear. I have never done a dio and haven't the slightest idea how to proceed and I'm not sure this is the time to try it. (I may change my mind if war is a stern teacher.) I split the hull with a scalpel, a razor blade, a #11 Xacto and a razor saw. It took about three hours plus. Not needed by the wise, but I wasn't sure anything would work so I wanted to keep to the split as narrow as possible in case I had to return to bathtub mode. Tools below:
If fortune smiles the split worked (I think it did) and we'll use some styrene to repair the hull and end up with a waterline Oregon. I've found a thread that has a bunch of little scratch improvements and I'll follow them. If the structure works, as I have made it, even with Tom's PE this is a simple model because there's so little rigging. I figure if I do a battleship I must suffer. Will try. Just don't expect to see any waves.
Eric
    February 2010
Posted by EBergerud on Wednesday, April 25, 2012 12:33 AM
Small progress report. To summarize the artistic challenge that I am facing with limited skills I have a kit that wants to look like this (except in the view of most modelers white):
But I want it to look like this:
I've never made a dio, so all I want to do is cut the hull in half and get the deck to fit. (I think I've got my hands full with a battleship and a bad dio would cripple the model. So I want is a very large version of a 1/770 scale Tamiya or Fujimi waterline warship.) Here is the first stage:
Because ships are modular you pretty need to have your colors down from the beginning. I want this ship to wear warpaint appropriate for the (at the time) epic battle of Santiago. Nobody is really sure what this color is. Someone on ship modeler refers to a color that would look like RLM02 - a dark greenish gray. Another wants something closer to RLM75 - gray violet. WEM has a color for these ships they call "Slate" and here's a sample:
Better than no help but is this adjusted for scale? I've only got one photo and from past experience (especially with the early Zero) I know that grays can drive you bats. What everyone agrees on is that the color we're looking for is not the pre-wwii neutral gray. So do we want a neutral gray simply shaded (I doubt this) or are we looking for a dark gray with a tint of blue or green? This is big ship. It's very close in size to the ICM 1/350 Konig I did last fall. At that size, getting more or less the right color is pretty important. (I'm not worried about the deck: it's some kind of buff and there will be at least three varieties.) So I'm going to have to work around the smaller stuff or maybe do as much deck as possible until I get a bottle of WEM Slate that I ordered yesterday. So it will join my WEM Navy Blue and Deck Blue as color samples. Outside of washes and some drybrushing, I haven't worked with enamel paints seriously for fifty years and don't plan to start.(Personal preference only - if I had a really well ventilated room and spray box I might sing a different tune. Enamels certainly leave a splendid finish.)
One thing I was able to do was reinforce the remaining hull with sprue (I cut off 60% easy) and put on a styrene bottom. Then I gave the beast a pre-shade painting the hull carbon black and the deck a dark reddish brown. So this is where we are now:
Considering the small number of parts involved, progress has been slow. I also don't have anything to do for a few weeks. That hurts modeling. I find myself reading, socializing and watching movies. My wife will be back in town soon and then modeling becomes a productive activity. Anyway, forward toward Manifest Destiny.
Eric
    March 2007
Posted by bondoman on Wednesday, April 25, 2012 1:16 AM
The Oregon was built at the Union Iron Works in San Francisco.
She was also shopped there before sailing to the Atlantic in 1898.
Here's one of the earliest motion pictures ever, of workers leaving the "Union Iron Works. Here was built the peerless US battleship Oregon" in 1898, by Edison Pictures.
http://www.youtube.com/watch?v=pNws5XHcx0w
Here's an interesting picture from later in 1898.
The turret has a tarpaulin tied down over it, to go along with all of the various sun shades that have been rigged.
The bridge and the turret ring appear to be a light color.
Ahh, a great and lost art. "Rig for Chapel!".
Posted by VanceCrozier on Wednesday, April 25, 2012 1:24 PM
What's going on in here? Did I miss anything? Has fermis been here & gone three times already????
    September 2005
Posted by Sprue-ce Goose on Wednesday, April 25, 2012 10:58 PM
VanceCrozier
.........maybe.............
    September 2005
Posted by Sprue-ce Goose on Wednesday, August 29, 2012 10:00 PM
    February 2010
Posted by EBergerud on Thursday, August 30, 2012 1:27 AM
Funny you should bring this up. The real world intruded in the most impolite way and created terrible problems for my modeling. (Among other things my wife was hit in a crosswalk by a truck. No real harm done, but it's been that kind of summer. I also got talked into writing something big for free - that's almost worse.) Anyway, we're back in CA, I have two classes up and running, and have Oregon sitting on the table ready to be re-engaged after a three month lay-off. Below are three photos that show the progress made on the hull. I spent a lot of time getting the right slate gray and because Oregon was beat-up properly before even arriving at Santiago, I gave it a proper salt-weathering. There was also a lot of scratch work involved which I mostly finished. I seriously intend on returning to PE tomorrow. Actually several components are in some state of repair, and hopefully I'll have something looking more like a ship in not too long. Below is what I have so far.
(Not sure what I did wrong: pics are on next post.)
Eric
