75th Anniversary of 1941 Group Build (World at War)
    July 2014
Posted by modelcrazy on Tuesday, May 12, 2020 8:30 AM
Just a small update. I just got 3 hours on the Akagi last night. I black based and sprayed the linoleum at the bow, most of which you won't really see once the hanger overhang is installed, and stern deck. I then proceeded to work on the stern girder system. Wow, what a delicate interlocking puzzle that is. I first had thought that it attached to the deck while one constructed it....nope. There's no reference. So, to be able to place the deck correctly, aligning with the massive posts, the assembly needs to be built on the bench first. Another issue I see is the deck at the stern is curved on the actual ship, not on the kit. I need to add some curvature to the deck to match the curvature of the delicate mass of PE. Others have done it, so can I. It's going to take a while and I'll work on it while other things are drying.
There are areas of the deck that will be masked and sprayed Sasebo Arsenal Grey A, at least that's what Hasegawa says to paint it, even though she was built in Kure. Whatever Confused It was their ship after all, what do I know.
Steve
    July 2004
Posted by stikpusher on Tuesday, May 12, 2020 1:57 PM
Very nice Steve! The bow area in those colors look sharp!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Tuesday, May 12, 2020 3:39 PM
Love the colors!  Yep, very nice work.
    July 2014
Posted by modelcrazy on Wednesday, May 13, 2020 8:03 AM
Thanks Stick and Check.
It took longer than usual to get the AB to work properly. I ordered a replacement 105 extream during Badger's sale in Jan, still nothing. I'll have to order a new needle set for it my old 105 anyway.
Enough complaining. I put in about 4 hours last night. I masked and sprayed the grey and did some fading since this area will be impossible to get to later. I'll add some weathering tonight for the same reason and then continue to add the hanger overhang at the bow. I also worked on the girder system some. something to get my wound up before bed.
This is one of the most fun kits I've done.
Steve
    July 2004
Posted by stikpusher on Wednesday, May 13, 2020 11:37 AM
Can you say intricate?
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Wednesday, May 13, 2020 3:48 PM
stikpusher
I'm afraid I'd be saying more than that Embarrassed--but "intricate" is a good description.  Nicely done, Steve.
    July 2014
Posted by modelcrazy on Thursday, May 14, 2020 1:42 PM
Thanks Stick and Check, more to follow.
Steve
    September 2003
Posted by checkmateking02 on Thursday, May 14, 2020 5:06 PM
modelcrazy
We're waiting for it, Steve!
    July 2014
Posted by modelcrazy on Friday, May 15, 2020 8:34 AM
checkmateking02
Well then how about this Check.
I didn't get anything done last night due to other engagements but I did find and order one of these, making each a kit in itself.
Steve
    September 2003
Posted by checkmateking02 on Saturday, May 16, 2020 8:41 PM
Surprise
That is shocking!!
    June 2018
Posted by DRUMS01 on Saturday, May 16, 2020 11:32 PM
Holy smokes Steve! I am really excited for you to complete those little boogers.....
I never knew they make 1/350 aircraft to that level of accuracy.
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    July 2014
Posted by modelcrazy on Monday, May 18, 2020 10:11 AM
I should be getting that super datail set in today or tomorrow. I'll break out a couple palnes and start work on them to see just what I got myself into.
Much done this weekend. PE girders and dry fitting to the hull to make sure all is streight. I apperently didn't take a picture of bow work. Too bad because that took most of Sunday to do.
Stern girders just about done
A little addition to the fore deck.
All that work covered. used filler to smoothe out the join
The stern girders, not attached. I need to smooth the filler. Also there is a smaller section just aft of this section. I'll work on that then install the pillers. After test fitting, all of this will need to be painted. Again, it's to bad I didn't take a pic of the bow work
Steve
    August 2015
Posted by crown r n7 on Monday, May 18, 2020 10:22 AM
my hats off to you photo etch guys...Bow Down
 Nick.
    September 2003
Posted by checkmateking02 on Monday, May 18, 2020 4:37 PM
That is truly astonishing, awesome and admirable, Steve.  I'm not sure I've ever seen anything like it.  Congratulations!
    July 2014
Posted by modelcrazy on Tuesday, May 19, 2020 8:13 AM
Thanks Nick and Check.
I received a few things last night. I was so busy playing with them that I didn't get a whole lot done. I did get an hour on some more of the stern girder framework. I'm planning on finishing it up with, hopefully, the pillars, or at least get them made. I'm not sure I want to attach them until I fit the deck on just yet. We'll see, I may dry fit the deck, attach the pillars to the framework, then paint it all. I think it would be more difficult masking and painting with everything together.
The pic of the bow girders
The laser cut paper set from South Korea. 12 page instructions and 6 "trees".
Some other items that arrived including the aircraft PE set.
Steve
    September 2003
Posted by checkmateking02 on Tuesday, May 19, 2020 4:45 PM
You are going to be very busy, Steve.  What a lot of PE!
    July 2014
Posted by modelcrazy on Wednesday, May 20, 2020 8:50 AM
Why yes, yes I am.
Almost complete with the stern girders. Just some pillars and what look to be walkways(?) then on to the mid section. The deck is just dry fitted to the hull. Hase supplied some huge aligling pins to set everything correctly.
Steve
    September 2003
Posted by checkmateking02 on Wednesday, May 20, 2020 5:19 PM
It looks spectacular already, Steve!  Gonna be even more when you start painting.
    July 2014
Posted by modelcrazy on Tuesday, May 26, 2020 8:01 AM
Thanks Check and everyone.
OK this weekends data dump. I worked on and off. I have 79 hours into it now. The Zero took 9 of those hours, but now that I did one, I get faster as I go. Not that I have any complaints with the detail kit but I do wish they added drop tanks for the Zeks.
The canopy was more difficult that I thought it woule be. Cutting out for the interior and the canopy/antenna were to toughist and too the longest. Now time to paint but I'll do that when I have the AB out for other things. The wheels are turned brass.
Moving on the she ship. I completed the pillars and added the crane tracks. I dry fit the deck to check the fit. Looks good. Now I need to add the cable stays but am also continuing on to the kits instructions and the additional paper detail set. Theres still some girders needed to add to the fore/aft sides and the mid deck.
Also, I didn't like some pillars hard molded on the kit so I am replacing those.
That's all I got done this weekend.
Steve
    April 2020
Posted by BBorBust on Wednesday, May 27, 2020 1:37 PM
Outstanding work Steve, truly inspiring and astonishing.
    July 2014
Posted by modelcrazy on Wednesday, May 27, 2020 2:41 PM
Thanks BB
Steve
    September 2003
Posted by checkmateking02 on Wednesday, May 27, 2020 9:03 PM
This is truly awe-inspiring, Steve.  Your detail work is beyond words!  Simply great!
    July 2014
Posted by modelcrazy on Thursday, May 28, 2020 7:26 AM
Thanks Check.
I put aside most of the PE work until more work is done on the hull, so back on the hull I go. I beleive I mentioned before that the molded in girder framework. behind the 1.2mm dual AA guns, were bothering me so I decided to replace them with scratch built pieces. They are snuggled far back under the mid deck so most won't even see them since there's just so much detail on the exterior, but I know they are there and feel better about it now. They're not perfect but will look just fine snuggled back under the deck
Steve
    September 2003
Posted by checkmateking02 on Thursday, May 28, 2020 9:33 PM
Nice duplicates, Steve.  They look very acceptable for the purpose.
    July 2014
Posted by modelcrazy on Tuesday, June 2, 2020 9:08 AM
Thanks Check,
Some more progress, slow, but progress. I worked on the AM paper braces and finally got the process down. Now I'm starting to get some things done again. A 25mm AA gun platform is shown here. The other platforms shown also have the paper braces. Once I touch them with thin CA, they become as hard as plastic. I need to attach the bracing posts and makes up some AA guns from PE. There are also 2 ladders that will be attached from the small hull opening to the platform.
Steve
    September 2003
Posted by checkmateking02 on Tuesday, June 2, 2020 6:47 PM
Paper braces are something I haven't heard of.  Sounds like you got them to work very well.  Everything is looking great!
    July 2014
Posted by modelcrazy on Thursday, June 4, 2020 10:23 AM
Thanks Check
I worked on the PE 25mm gun and here it is finished and next to a kit gun. It took me around 3 hours but now I know the sequence. They should take about and hour each and have 13 more to do....unless I loose parts.
Steve
    September 2003
Posted by checkmateking02 on Thursday, June 4, 2020 9:56 PM
Vast improvement, Steve.  They look beautiful!  Great work!
    July 2014
Posted by modelcrazy on Friday, June 12, 2020 8:06 AM
Hey Check,
I have been working dillegently every night on the Akagi. I have been replacing the bracing parts with the laser cut paper parts. Each one takes me about an evening each and still have several parts left to do. After this do I work on the AA guns or planes or do I go back to finishing the hull?
Steve
    September 2003
Posted by checkmateking02 on Friday, June 12, 2020 5:57 PM
Impressive, Steve.  What are the black lines on the parts?
