Shelf of Doom GB 2016-17 (now extended to 30th June !!!!!!!)
    February 2010
Posted by 68GT on Saturday, January 7, 2017 8:34 PM
So I got working on the Phantom today.  Had to make some side glass for the nose cause I misplaced them.  Otherwise I'm moving along.
On Ed's bench, ???
    April 2005
Posted by taxtp on Monday, January 9, 2017 5:29 AM
It's good to see some progress 68GT.
I'm calling my 1/16 Tamiya German Infantry man with reversible winter uniform done. I hope you like it. That makes 8 models that have been rescued from the global Shelof of Doom by the participants of this GB. Here it is:
Cheers
Tony
I'm just taking it one GB at a time.
    February 2010
Posted by 68GT on Tuesday, January 10, 2017 7:39 PM
Wow, thats a great job!
Had a little setback with the Phantom.  I planed on doing a closed canopy but it is so poorly fitting I have to switch gears and go open.  Have to figure how I'm going to spred the section between the front and back canopies and cement it in.
On Ed's bench, ???
    November 2016
Posted by Gerhard on Sunday, January 15, 2017 1:47 AM
Going have to opt out with the UH-60 Black Hawk. Wanted to start it today, but one of the main rotor blades has gone awol out of the box. Will substitue it with an Academy 1/48 F86 Sabre that has been sitting on my shelf for a good part of 10 years. It's about 5% done. Cant recall why I never carried on with it.
Is that ok?
    April 2010
Posted by Theuns on Monday, January 16, 2017 10:59 AM
That infantry man is just superbly painted!
Theuns
    January 2014
Posted by jelliott523 on Tuesday, January 17, 2017 2:41 PM
PKorson2
Hi, might as well hop aboard.
This is a Revell F-15E that only needs some clean up and a coat of paint. But I've fouled up so many parts (namely the insides of the exhausts and front wheel bay) that I don't even want to see it. Nonetheless, I'll try to soldier on. I'll work on it at some point when I get the motivation but for now I have two F-16s tying me up.
One thing you could do is to use the FOD covers that are included in the kit and make some rear exhaust covers to show the aircraft in a "parked on the ramp" state. The could be easily made using tissue cut just larger than the exhaust out of tissue paper and coated with thinned Elmers white glue. Also, to note, the front wheel well of the F-15 gear doors close when the gear is extended, except for the small portion at the rear of the main gear strut.
    November 2016
Posted by SteveCB on Sunday, January 22, 2017 7:17 PM
I'm a slow builder, and I actually went back and redid the engine.  Bear in mind I'm getting back into the hobby after a few years.  I did try a couple of new things, adding sparkplug wires and using bare metal foil to the air cleaner and valve covers.  Here's where I am now.
    June 2008
Posted by lewbud on Sunday, January 29, 2017 5:58 PM
Change of plans.  Going with the Monogram 1/72 F8F Bearcat I started for last year's Weekend GB.  Here's where she's at.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    April 2005
Posted by taxtp on Sunday, January 29, 2017 7:40 PM
Hi Folks,
Nice progress everyone. I've updated the list Gerhard and Lewbud. I've been away for a couple of weeks, then crook for a few days. Should be back to normal now.
Thanks for the comments on my figure.
Cheers
Tony
    January 2015
Posted by TheMongoose on Sunday, January 29, 2017 9:31 PM
I finally found the pictures of my P-51B in it's original state. Now I feel like I can start putting the bare metal foil on it. These were from December 2014. Next weekend I'll start the recovery project!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    June 2009
Posted by jimbot58 on Monday, January 30, 2017 1:20 AM
Hey all!
I also have a shelf of doom, but it sort of runs at 2 levels: there is the shelf of doom that contains quite a number of kits that will probably never be completed, some that are just waiting for inspiration to continue, and a few that are nearly done and are waiting for me to add minor items such gear doors, armament, etc.
The other level is my work bench: at this point, I count 9 kits in various stages of completion. I seem to have the attention of a 2 year-old as I work on one for a week, another for a day and so on.
Wondered I might fit into this group?
Jim
On my workbench now:
Fujimi F-4K Phantom "Yellow Bird" and Zvezda Su-27SM Flanker
    April 2005
Posted by taxtp on Tuesday, January 31, 2017 5:45 PM
Hi Jim,
Use the group to fit your own purposes in getting something finished. There are few rules here, just encouragement to get them done !
Cheers
Tony
    April 2005
Posted by taxtp on Tuesday, January 31, 2017 5:47 PM
Hi All,
This GB was proposed to finish on 28th February, but I'd be ok to extend by a couple of months if it helps to get things done. If I get three people wanting it to continue, then I'll extend until 30th April.
Let me know.
Cheers
Tony
    February 2010
Posted by 68GT on Tuesday, January 31, 2017 7:06 PM
Thats a nice looking engine!
Got a little done on the Phantom.
On Ed's bench, ???
    July 2014
Posted by modelcrazy on Tuesday, January 31, 2017 7:41 PM
I'd be up for an extension.
Steve
    November 2016
Posted by SteveCB on Tuesday, January 31, 2017 7:50 PM
I'm good with an extension.
Thanks 68GT.
    April 2005
Posted by taxtp on Tuesday, January 31, 2017 8:10 PM
Thanks guys, just need one more vote for an extension. Nice work on the Phantom 68GT.
Cheers
Tony
    January 2015
Posted by TheMongoose on Tuesday, January 31, 2017 11:19 PM
Extensio is ok by me
    June 2009
Posted by jimbot58 on Tuesday, January 31, 2017 11:48 PM
I would vote for an extension if I can bring Meng's 1/72 F-102 Delta Dagger:
    April 2005
Posted by taxtp on Wednesday, February 1, 2017 4:36 AM
OK, let's do the extension. You can bring that Meng F-102 in Jim, because I have one in the stash and I want to see how it goes. I'm going to add an Airfix multi pose 1/32 British Infantryman, that I failed to complete for the FSM New Years Resolution GB.
Cheers
Tony
    November 2016
Posted by Gerhard on Wednesday, February 1, 2017 5:00 AM
Excellent. The goodies I ordered from the UK for my F86-F are taking their time to get here.
    January 2015
Posted by TheMongoose on Friday, February 3, 2017 10:26 PM
True progress has been made already this weekend! No more prep work. Here's my first attempt at BMF. I really like this so far And what an improvement over my old brush painting attempt. I've not tried anything too complicated yet in that I covered the wing all in 1 piece rather than try and do seperate panels. I'll post more as i make progress this weekend.
    April 2005
Posted by taxtp on Saturday, February 4, 2017 2:08 PM
I agree Mongoose, that's looking good.
Cheers
Tony
    January 2016
Posted by Hunter on Saturday, February 4, 2017 4:23 PM
taxtp
Cheers
Tony
Tony...great job on the detail and paint. Really enjoyed looking at this build
Hunter
    January 2016
Posted by Hunter on Saturday, February 4, 2017 4:25 PM
SteveCB
Steve....the engine is looking great.
Hunter
    January 2016
Posted by Hunter on Saturday, February 4, 2017 4:26 PM
68GT
68GT.....coming along nicely. Can't wait too see it completed.
Hunter
    July 2014
Posted by modelcrazy on Monday, February 6, 2017 12:07 AM
Well It’s been quite a while but I’m back on the Johnston. I’m redoing the base because I didn’t like the old one.
Here’s the process for the base.
I bought some hard Styrofoam from the local craft store and cut it to shape.
Next I drew out the hull shape and cut it out of the Styrofoam.
I then drew out where I wanted the wake and cut them out.
Using a lighter I turned the base upside down and used a lighter to melt the Styrofoam and create the waves (out in the garage).
I used some printer paper and tore them in strips. I then wetted the strips and applied them to the base using acrylic gel.
I continued this process until the entire base was covered with the paper strips. The wet paper wrinkles and makes beautiful ripples on the waves.
Steve
    July 2014
Posted by modelcrazy on Monday, February 6, 2017 9:01 PM
I did some work on the base today. I checked the fit of the build in its slot then sanded the base and applied another coat of acrylic gel stippling it with the brush to get more of a ripple effect. After this coat was dry I mixed up some acrylic artist paint and applied it for the color.
Steve
    April 2005
Posted by taxtp on Tuesday, February 7, 2017 2:18 PM
Thanks for the great explanation on how to make water MC, it looks great. Are you going to give it some white caps ?
What colour paint do you use for the blue. I always use Pthalocyanine Blue mixed with Pthalocyanine Green. More blue for the Pacific, more green for the Atlantic.
Cheers
Tony
    December 2007
Posted by PANZERJAGER on Tuesday, February 7, 2017 2:30 PM
I have over 100 of these projects sitting around, I'm sure I can come up with one...
I'm in!
Give me a day to figure out what one to finish...
PANZERJAGER
 PANZERJAGER
