Thanks Carl,,,, simple, effective tool. Nice
I've only been to the range so far.... playing, at least 9, tomorrow. The weather is supposed to be ok.
Rob,, I like the layout too,,,, will you be adding water / ocean?
Here is a quick update on my palm trees - - - -
After making the "trunks" a little paint job is required. I don't use a lot of browns,, more of a grey / light brown mix. I then wash with grey followed by a lighter grey drybrushing. I wash afterwards with dark brown and black. A pinwash of black also brings out the "rings" and trunk dings and imperfections. These trees always seem to look beat up.
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees001.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees002.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees003.jpg)
In the past I have used imagination and paper to make the palms... I tried a little bit of a new method of doing this,,, I was not super thrilled with the results..... so I removed these palms and tried something different.... I will save these palms for some ground cover though.
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees006.jpg)
I stopped by a florist and started sniffing around looking for a substitute.
I found some ferns that looked like they would do the trick.
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees008.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees009.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees010.jpg)
While the face-up side of the ferns seemed a bit too green,,,, so I turned them over and the color was better plus they have a better palm leaf look in my opinon.
So I began cutting away at the ferns. I sealed the pieces with a flat coat and then began attaching them to the trunks. Tedious as you can only attach one at a time. Rotating the trunks and continuing to attach,,, I am pretty happy with the results.
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees013.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees014.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees017.jpg)
![](http://i951.photobucket.com/albums/ad354/babill1/Semper%20Fi%20%20GB/SemPtrees019.jpg)
Hope you like...........
