Hooray for Hollywood 2014 GB extended til July 4th
    September 2003
Posted by checkmateking02 on Saturday, March 22, 2014 1:26 PM
I installed the SBD's on the hanger deck yesterday.
When I test-fitted the flight deck, it makes things so dark on the hanger deck that they aren't going to show up too well from the outside.
    September 2003
Posted by checkmateking02 on Saturday, March 22, 2014 1:29 PM
This afternoon I installed the flight deck and one of the catwalks that is attached to the hull.  Now everything is weighted down till the glue dries.  I used Aleene's "Original Tacky Glue" to make any clean-up easier, and the stuff seems to work pretty well holding the pieces in place.  I used the same method on USS Saratoga a couple of years ago, and it's still together.
GAF
    June 2012
Posted by GAF on Saturday, March 22, 2014 5:42 PM
CMK>
It's nice to finally see someone do a little known episode from WWII, "Operation Java", where the Americans rounded up every coffee bean in the South Pacific and... well, you know the rest of the story.  Stick out tongue
Gary
    September 2003
Posted by checkmateking02 on Saturday, March 22, 2014 7:24 PM
Thanks, Gary.  It's nice to know someone remembers!
Coffee
GAF
    June 2012
Posted by GAF on Saturday, March 22, 2014 10:46 PM
And detailing continues apace on the Enterprise.  (Sorry, no SBDs in the shuttle bay).
One thing I'm glad I bought months ago were some half-beads of various sizes.  You can see them on the top of the saucer and at the rear of the secondary hull.  They work out well as domes and ID lights.
Meanwhile, the nacelle end caps are progressing nicely.  The "bussard collector" caps I sprayed with flourescent orange, then went over the sides with Tamiya Clear Red.  Then, using a mechanical pencil, I sketched in the filaments of the collectors.  Next I'll give them a clear coat of future, then attempt to give it an overall spray of white.  Hopefully, it will be just enough to allow the orange/red and filaments to show through.
Next up, the impulse engines are masked and ready to paint.  Sorry for the blurry images.  My camera doesn't like taking pictures without the flash.  Go figure.
Getting close.  Thanks for looking!
Gary
    September 2003
Posted by checkmateking02 on Sunday, March 23, 2014 3:33 PM
That is a great effect on the bussard collectors, Gary; they look fabulously realistic.  Won't be long before you leave space dock!
    September 2003
Posted by checkmateking02 on Friday, March 28, 2014 8:01 PM
I got the flight deck glued on this week.
Then started working on the superstructure.
Port side:
Starboard side:
Posted by Bish on Saturday, March 29, 2014 3:44 PM
Stunning progress there guys.Those collectors look really nice gary, going to have to make a note of that.
GAF
    June 2012
Posted by GAF on Saturday, March 29, 2014 10:54 PM
The Enterprise is close to being finished with her paint.  I only have to touch up the hull color in spots and she will be ready for decals.  I already have some from JT Graphics for the windows, which will save a lot of time.  However, the insignia and lettering decals are a bit up in the air right now.  I'm working on that.
The "Bussard Collectors" turned out okay.  I tried to give a light spray of white over them, but it didn't turn out very well.  I removed most of the white spray paint (luckily I had a coating of future underneath the white and over the red/orange filament paint) and then used some thinned international orange to go over the caps.  This looked much better, and was transparent enough to allow the filaments to show through.  Overall, I'm pleased with how they look.
I also picked up a wooden base and will be making a stand for the model.  With luck, we'll see her leave dry-dock soon.
Maybe both Enterprises will sail together (though at my rate of work, I wouldn't hold out any hopes of that).
Gary
    September 2003
Posted by checkmateking02 on Sunday, March 30, 2014 1:07 PM
You've got dilithium crystals and warp drive, Gary.  That's a pretty good headstart.
And I think the collectors turned out extremely well.  The very subtle color variations make them exceptional.
Maybe you're aware of these decals:
www.federationmodels.com/.../default.htm
650 Hull Markings Decals
www.federationmodels.com/.../pnt-4075.jpg
They look pretty good.
GAF
    June 2012
Posted by GAF on Sunday, March 30, 2014 10:12 PM
Bish and CMK02>  Thanks, guys!  The collectors are probably too reddish.  They should be a more orange/white IMO.  But, I'll go with what I've got.  Smile   Hoping to see CV-6 Enterprise ready soon.  The island looks pretty good.
I'm going to need a stand for this model (better than that plastic thing supplied in the box).  I was at the craft store yesterday and found this round disk with a hole in it.  Bringing it home, I went in search of something that would fit that hole, and... lo and behold... the handle on one of these sponge applicators fits perfectly!
In addition, the sponge is actually attached to the handle with a plastic pin, and pulling that out leaves a nice hole to put something in... like some brass tubing I just happened to have lying around.  Surprise
So I put this all together and it almost seems as if they were made to fit!  I couldn't be so lucky!
I have an idea about what to put on the base, after it is varnished and painted.  It will be pretty nice if I can do what I think I want to do...  if that makes sense.
Meanwhile, I'm thinking about weathering...  Weathering?  In space?  Well...
Oh, and thanks for the links to the decals.  However, some have magically appeared... from somewhere...  no idea how...  Whistling
Thanks for looking!
Gary
PS> I was hoping to have this finished up by the end of the month so I could get started on a couple of builds for other GBs.  Well, I'm shooting for this week anyway.
    September 2003
Posted by checkmateking02 on Monday, March 31, 2014 11:50 AM
Excellent!  Very nice-looking and even:  fascinating!
    November 2010
Posted by Eagle90 on Tuesday, April 1, 2014 10:05 AM
Glad you decided to extend!  There is some seriously awesome work being done here!
Eagle90
    October 2009
Posted by greentracker98 on Tuesday, April 1, 2014 10:16 AM
Every one's build looks great Thank you all for the kind words.
I'm going to get axles this week for the halftrack. i have to get it out again.
I'll be getting back into the swing of things. Right now,I need to finish the P47 Jug for a model club
meeting sat
I'll post pics later today/ Its up on it's landing now. but no tires yet
Right now, my shelf queens are;
58 chevy impala
Lise Kelly's Kenworth
53 foot trailer (for lisa's truck)
Also a pup trailer; (a 28 footer)
F4 Phantom
A.K.A. Ken                Making Modeling Great Again
    October 2009
Posted by greentracker98 on Tuesday, April 1, 2014 10:20 AM
Eagle90
Eagle90
 Eagle, I'm way behind too. Yea I agree with the "awesome work" part.
GAF
    June 2012
Posted by GAF on Tuesday, April 1, 2014 9:47 PM
Thanks, guys!  My decaling is continuing this week and I'm shooting for a weekend finish.
Ken and Eagle90>  Welcome back, guys!  I was wondering what had happened.  Glad you're able to make it back to the fold.  Hope things are better.
Gary
    October 2009
Posted by greentracker98 on Wednesday, April 2, 2014 12:54 AM
Thanks Gary,
Well, I just have to learn to walk away from certain things.
Hey, I know. Just walk away and work on my models. LOL
Posted by Bish on Wednesday, April 2, 2014 8:20 AM
Gary, she is loking great.
CMK, thanks for that link, I hadn't come across those before. I would like to get some AM for my enterprise kits, but there so many different kits and I never know which AM goes with which kit. But I think I know what I need for the TOS ship, so thanks.
Ken, Eagle, welcome back guys.
    September 2003
Posted by checkmateking02 on Wednesday, April 2, 2014 3:12 PM
Welcome, Bish.
It's kind of unfortunate that all Star Trek kits are not made to one consistent scale, so they'd all be in harmony with each other.
I can't speak to either the company or the decals themselves, since I haven't tried them; but glad you found the link useful.
I grew up on ST, and have followed the "franchise" ever since TOS.  Used to build the kits frequently.  I still have NCC-1701 (TOS) hanging from the ceiling in my office.  It elicits comments from time to time.  It's just too bad it doesn't have working photon torpedoes sometimes.
And, it is good to have Ken and Eagle back, too!
    October 2009
Posted by greentracker98 on Wednesday, April 2, 2014 11:26 PM
Thanks everyone. Coming here takes my mind off other things
Posted by Bish on Friday, April 4, 2014 4:21 AM
CMK, I know what you mean.I have always followed the series and the movies.And I think the new ones have breathed new life into it.
And I have been trying to decide between Polar lights and AMT as well for the kits I don't yet have. I am the same. I did build two of the Enterprise kits in the past, the original and I think the B, but they haven't survived, I am trying to build every one of the Enterprises, just trying to decide which ones to get and find some nice AM for them.
GAF
    June 2012
Posted by GAF on Saturday, April 5, 2014 10:52 PM
Just checking in.  My decaling is nearing completion, and I hope to have it finished tonight.  We'll see how she goes.  I just hope the power doesn't go out as we're having some thunderstorms.
Bish>  I watched Star Trek from the beginning.  I was 11 years old when it first came on, the perfect age for getting caught up in the TV magic.
As for kits, I saw the Polar Lights Enterprise / Botany Bay kit at the Hobby Town last weekend.  The model on the box certainly looked like the most accurate small scale Enterprise I've seen.  I'll have to check for a review sometime.
Gary
GAF
    June 2012
Posted by GAF on Sunday, April 6, 2014 9:57 PM
The weather did not cooperate with finishing the Enterprise today.  I needed to do some outside spraying and it (naturally) rained all day.  I'm hoping the weather improves this week and I can complete the final steps in construction.
This is where I am now.
Decals are all on.  I need to touch up some of the hull paint in spots.  The base needs to be spray painted black and the emblem attached.  Then model and base will be sprayed with clear coats.  After that, I will go over domes, nacelle caps and lights with Future to give them a shine.  I also want to shorten the brass tube in the stand just a bit.
And that should do it.  Not long now.
Gary
Posted by Bish on Monday, April 7, 2014 3:27 AM
Now that is nice. I really like that. Personally, I think I would leave the base natural wood, but then I do prefer un painted wood. Did you print out that emblem.
    September 2003
Posted by checkmateking02 on Monday, April 7, 2014 5:05 PM
That is really sharp-looking.  Should be the pride of Star Fleet.  Excellent result on the painting and decaling.  Very nice touch with the Federation logo on the stand.  Outstanding work, Gary!
GAF
    June 2012
Posted by GAF on Tuesday, April 8, 2014 8:04 PM
And... she's done.
And the money shot...
"Space.  The Final Frontier..."
This one was a long ride.
Exterior hull color was done with Valspar "Gloss Azure Snow".  A pain to work with, but the color has a hint of bluish-green, which worked out well.  This model is all spray can and brush work.  Not something I would enter into a contest, that's for sure!
The "Buzzard Collectors" (yes, I know it's "Bussard") were spray painted fluorescent orange, then Tamiya Clear Red was brushed over the sides.  The filaments were penciled in and then covered in International Orange.  They really should be more "whitish", but they're good enough for now.  Next time.
The grids on the sides of the secondary hull at the front were made using some plastic card which was grooved using an x-acto blade.  Rods made from paperclips were placed above and below the grids.
Dome lights were half-beads from the craft store that come in various colors and sizes.  Very useful.
Windows were from JT Graphics.  I cannot recommend using the white windows from these decals as they are just too light (if used on a light exterior color such as this one).  I used the marking for the hatches and the black windows.  I either painted the white windows or cut strips from a piece of white decal paper and made my own.  The actual registration numbers, striping, insignia and name were printed on inkjet decal paper and worked well.  The decals were a bit thick, but I found the Testors decal paper was very thin and ran when I tried to coat it with decal bonder.  Not a good experience.
Ship was flat coated with Model Master Dullcote, and the end caps and dome lights coated afterwards with future for a shiny effect.
The insignia for the base was done by a talented artist called Balsavor.  I downloaded it and printed it as a decal on label paper.  Unfortunately, I almost messed it up in preparation.  It didn't turn out as well as I had hoped.
Bish>  Sorry, I went ahead and painted the base black.  I needed to cover the writing on the handle of the foam brush I used.  Only later did I realize I could have just sanded the writing off and left it natural wood! DOH!
And that's it.  Thank you to Ken for running this GB and making me get this model done (eventually), and thanks to all of you who have followed along with encouragement.
Gary
PS> The pictures have pointed out a couple of things I need to correct.  One is to touch up the paint around the hole for the base, or placed a washer or something around it.  Another is that the observation deck just above the shuttle bay doors needs a window.  Nothing too critical.
    September 2003
Posted by checkmateking02 on Tuesday, April 8, 2014 8:47 PM
There is an empire full of Klingons worried right now, since you've launched Enterprise; or, at least there will be in a couple hundred years.  Qapla'!
Great results, Gary.  A superlative rendition of Star Fleet's finest.
The decals really enhance the effect, and I think you made a good choice in the paint color.
    October 2009
Posted by greentracker98 on Tuesday, April 8, 2014 9:06 PM
Looks great Gary,
Pic will be posted shortley
Posted by Bish on Wednesday, April 9, 2014 2:54 AM
Now that's nice Gary, love it. And I like what you have done on the base. Going to have to try that with the insignia.
Great looking build.
    May 2005
Posted by pyrman64 on Wednesday, April 9, 2014 3:35 AM
Gary: nice job on the Enterprise, the base is a great addition.
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
