Ships of the German Flag GB 2020
    November 2008
Posted by plasticjunkie on Friday, September 4, 2020 9:09 PM
I have the hull sealed up and almost ready for the tower.
 GIFMaker.org_jy_Ayj_O
    January 2015
Posted by TheMongoose on Saturday, September 5, 2020 8:20 PM
That's gonna be a beautiful looking sub!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    November 2008
Posted by plasticjunkie on Saturday, September 5, 2020 8:22 PM
TheMongoose
Yes
    January 2015
Posted by TheMongoose on Saturday, September 5, 2020 8:24 PM
    November 2008
Posted by plasticjunkie on Saturday, September 5, 2020 8:46 PM
So Happy Brthday !!! Boy this is looking very interesting indeed.Beer
    July 2010
Posted by docidle on Saturday, September 5, 2020 9:44 PM
plasticjunkie
PJ,
Those holes cleaned up right nice. It really does look great. Did you place anything inside to block a see through or it the model small enough that it’s a moot point.
Steve
    November 2008
Posted by plasticjunkie on Saturday, September 5, 2020 10:28 PM
docidle
plasticjunkie
PJ,
Steve
Thanks Steve. Yes I did  add something but forgot to mention and photograph the card stock I glued on the keel going up just under the deck to block that empty look. I painted the interior and the center card sheet black.
    January 2015
Posted by TheMongoose on Sunday, September 6, 2020 9:49 AM
The initial primer is on. Everything here is just set in place.
Any suggestions on how to deal with the 4 deck joints? On the main deck Tamiya used raised lines to simulate decking. Everywhere else I've been able to eliminate the joints so would like to do that on these as well.
    September 2012
Posted by GMorrison on Sunday, September 6, 2020 12:07 PM
My two bits.
Do the best you can.
when you splice pieces together with a piece of plastic on the underside, leaving space at the end for the edge of the hull; be sure to make the tops flush. The pieces may well be different thicknesses.
That alone may be enough.
If not, mask an area as best you can considering the raised detail no morevthan 1/16" wide or so.
carefully try filling crack with a little Tamita Gray diluted in Tamiya liquid cement.
sick of fighting autocorrect with the Tamit's word!
Tight construction followed with super minimal repair should work well.
Bill
    July 2010
Posted by docidle on Sunday, September 6, 2020 8:51 PM
Continuing with the torpedo tubes, I started small by attaching PE to the lids first. Not a big deal but a step forward.
Steve
Next I marked off the size of the hole needed to be drilled. Then again starting small and working up to a point where I needed to measure again. It's always easier to take away tthan trying to replace plastic that you've removed...
To make sure that I had the angles right and to further hone the openings, I started drilling small holes on the exterior portions of the tubes which are kit parts.
As you can see, I was making small holes and then digging out portions. You can also see that I made a mistake and drilled way to close to the edge and had to fill in with Perfect Plastic Putty. Measure twice, cuss once or more...
And so on to this point.
Getting closer to where I want to be. I had to file at an angle so that the torpedo tubes would allign.
Then dry fitting to see how much more I needed to remove from the hull.
Now to dry fit all the components to see how they fit together. The PE is for the facing around the exterior tubes.
Note that the opening is completely round.
Everything lines up and now I need to clean up the openings to make them smoother.
Next up will be surgery on two of the smoke gererators stands and then onto the bridge and more major surgery.
    July 2010
Posted by docidle on Sunday, September 6, 2020 8:57 PM
Mongoose,
I can't add anymore to Bill's(GMorrison) advice. As much as I'm not a fan of wood decks from various firms (there's no 3D effect) I also am a realist when it comes to multiple sectioned decks and sometimes only a wood deck will do. Unfortunetely, I think you're too far along to be able to fit a deck on with all the deck furniture in place.
Otherwise, your Tirpitz looks awesome.
Steve
    January 2015
Posted by TheMongoose on Sunday, September 6, 2020 9:19 PM
docidle wow does that look good! love the build up photos as well. I k how complicated that is, a perfectly round tube to complex geometry. Well done!
    July 2014
Posted by modelcrazy on Sunday, September 6, 2020 10:21 PM
Hi guys.
Sorry, I have been working long hours in a attempt to correct a serious misscalculation in my federal income tax withholdings, and I will be working more to save for the inevitable payment to come the first of next year.
Chris and PJ, I attempted to answer you guys yesterday but my phone locked up while trying to send Super Angry
So now that I'm at my copmputer I'll try to catch up.
Chris, you first. I agree with Bill, do your best, it can be done but with much work. I don't know why Tamiya did that instead of just giving a solid deck. As far as the stacks, I usually drill out holes and stick in coffee stir staws of diffrent sizes to add intrest. They aren't accurate but add some intrest. She's coming along great.
PJ, great job on the limber holes Yes That's going to make it awesome.
Docidle, Nice job, beautiful work. I really wasn't seeing it until the last couple of pictures. Once you got the door on I see what you were talking about. Sorry, I'm quite a bit scatter brained lately.
Did I miss anybody? Sorry if I did and you had a question I missed. Luckly Bill is in here and can answer some of them, thanks Bill!
So, during all this extra work I'm doing, including passing my Real Estate exam, sitting at open houses, working at HP and driving for Grubhub in the evening (actually really good money) I will be able to purchase the Pontos set for the Revell Bismarck. It's a supper nice set.
Steve
    January 2015
Posted by TheMongoose on Sunday, September 6, 2020 10:50 PM
modelcrazy
Hi guys.
You've got to tell me about this! So I've been working hard to stay focussed on just building the Tirpitz out of the box and essentially using it to get ready for my Revell Bismalrk build. That one I want to knock outta da' park. I've just sarted looking at what's available for it. I bought the AK Interactice Modeling Straight Ahead book and plan to walk through it in detail. Let me in on your thoughts for aftermarket as well please!
    January 2015
Posted by TheMongoose on Sunday, September 6, 2020 10:51 PM
Prepping for paint! Check out the camo scheme...
    July 2014
Posted by modelcrazy on Sunday, September 6, 2020 11:30 PM
Chris, take a look at the Pontos set for it, it's massive! I like AM sets very much, they really make a subject stand out but do add quite a bit to the build time.
The camo looks intense. I saw a drawing where the starboard side and deck had the camo and the port side, next to the cliff, was clean.
Steve
    January 2015
Posted by TheMongoose on Monday, September 7, 2020 12:30 AM
modelcrazy
yep, that's the one I'm doing :-)
last time I looked at the clock it was 10:15. Guess it got away from me as it's after 1. Took longer than normal to mock this up. My current plan is to mask the white gray, paint the 2 different browns, then do the all over green by using what I've cut out in browns as the masks. Tomorrow though , or today I guess lol
    September 2013
Posted by Marcus McBean on Monday, September 7, 2020 6:23 AM
TheMongoose,
That is quite a camo pattern but it will look awesome when completed.
As for laying the colors wouldn't you want to lay the green before the brown, darker over lighter?  Or are you hand painting each section?
Marcus Beer
Posted by Bish on Monday, September 7, 2020 6:39 AM
TheMongoose
modelcrazy
Hi guys.
I have a Lion Roar set for my Revell Bismarck. Like the Pontos one its huge. But i think the Pontos set comes with wood deck (Steve, correct me if i am wrong) i just went for the Artwox deck. I have repleaced all the AA guns with resin ones from vetren models. Still thinking about replaceing the ammo lockers, searchlights and a few other bits.
Posted by Bish on Monday, September 7, 2020 6:40 AM
Great job on those torpedo tubes Steve, very nicely done.
    January 2015
Posted by TheMongoose on Monday, September 7, 2020 10:21 AM
Marcus McBean
TheMongoose,
Marcus Beer
Hmmmm, gotta think about that. I'm going to airbrush each section. One color won't go over the next so no worries about coverage. My thinking, all be it possibly flawed lol, is that green overspray would show strongly on the lighter brown but the lighter brown maynot show as much on the dark green making it easier to touch up. Short of that logic I hadn't come up with a specific order of spraying. Any advice from past experience would definitely be welcome :-)
    November 2008
Posted by plasticjunkie on Monday, September 7, 2020 11:03 AM
Man that is one puzzle of a camp scheme but will look fantastic and unusual.
    January 2015
Posted by TheMongoose on Monday, September 7, 2020 2:43 PM
Thanks for the motivation guys Balloons
doing some practice today. Started with the stack, small and easily rotated to get paint everywhere. You may be wondering why i primed in the white-grey color. 2 reasons actually, it's close to the color needed for the camo and it may allow me to modulate these light colors better. Instead of adding white to lighten the color I'm trying to put more or less coverage in an area. See what you think of these pics?
the white-grey is misted with grimey black(think tamiya smoke). It appears too brite yet i think. Maybe a little more, or maybe wait and do a little heavier weathering on those areas, what do you think?
    January 2015
Posted by TheMongoose on Thursday, September 10, 2020 6:37 AM
Here's my 1st shot at the camo. Up close I can see there will be some blending between colors needed. Using MM enamels so there is a possibility of thinning it and doing a little brush work. You guys have any experience with this? Could use some suggestions to get rid of the thin white lines left between colors in a few spots. Maybe I just need to air brush those next time I have the color out? Any experience on what works best?
    November 2008
Posted by plasticjunkie on Thursday, September 10, 2020 9:06 AM
Oh my! That looks amazing
    July 2014
Posted by modelcrazy on Thursday, September 10, 2020 9:35 AM
plasticjunkie
Ditto
Steve
    October 2004
Posted by ikar01 on Thursday, September 10, 2020 3:57 PM
Finally got going on the Graf Spee. Having a little problem with the P.E. set because sometimes it's hard deciphering the drawings and matching the two sets of instructions, and then trying to find the correct metal piece on the fret.  Last night I spent a half hour going over everything with a magnifier lens and still didn't fint the piece I needed.
One thing I did notice with this kit and the deck set, the kit showed wood, so I started looking for a wood piece and started thinking it might have been left out, but the particular part I needed was actually metal.  who knew?  In another case I may have been shorted a couple ladders and some vents, but I'll keep looking and building other sections.  Hopefully they will show up later.
    January 2015
Posted by TheMongoose on Thursday, September 10, 2020 5:13 PM
Ikar01, I didn't look back at past posts, is it kit PE or aftermarket?
Tonight's entertainment for me is a modeling puzzle - 50 pieces with no straight edge pieces Surprise now where to start?
    January 2015
Posted by TheMongoose on Thursday, September 10, 2020 9:47 PM
Moving right along Big Smile The forrest green is looking pretty good. I'm trying to match my background trees on the railroad tunnel mountain and the more muted colors in the original color photograph instead of the brighter green in the rendering that I'm using for the pattern.
one nice thing is that according to the German Camo book I picked up — German Naval Camouflage, 1942–1945 by John Asmussen, “Lack of proper aerial photo documentation has made it impossible to make a top view illustration.”
So anything on the deck is plausible Whistling
