Animalistic GB-Official place
    July 2014
Posted by modelcrazy on Monday, December 27, 2021 8:51 PM
I got a 1/48 Suyata Panther A for Christmas so I'll change to that of that's OK.
Steve
    July 2008
Posted by castelnuovo on Tuesday, December 28, 2021 12:51 AM
No problem. List updated.
    July 2008
Posted by castelnuovo on Tuesday, December 28, 2021 12:52 AM
JBRaider
Would you please add me to the list with an Academy 1/72 P-51B?
Thanks for joining. List updated.
    July 2008
Posted by castelnuovo on Tuesday, December 28, 2021 12:54 AM
Glamdring
I have settled on my project, it will be Dragon's 1/72 Tiger I, dressed up as Michael Wittman's Tiger.  If I did one of my big cat's in 1/35, I'd probably never finish in time with my schedule for the year.
The big question will it be the Italian Front tricolor or an Eastern Front whitewash....
OK, list updated
Posted by oortiz10 on Saturday, January 1, 2022 5:26 PM
OK zookeepers, it's officially the first, I'm sitting at home with a cold (No, it's NOT Covid!) so figured today would be a good day to start. I'm in with AMT's 1/48 F7F-3 Tigercat.
I have some TD resin wheels, Wolfpack's wingfold, and some SAC metal gear for it. I'm avoiding the rubber wheels, and given all the weight I've read this thing will need to stay on its nose, I'm going with SAC's gear.
It's a slow start, but I've managed to paint up the cockpit walls and nose wheel area. The cockpit itself is in progress. I'll try to get some photos to share.
This kit has some pretty nicely molded detail. I think I'm going to attack the wingfold area next. I don't want to get too far along with everything, only to screw up the most important part later. May as well start with the tough stuff and get it out of the way.
I like to build more than one kit at a time, so this one will share bench-space with a Hasegawa (sorry, NOT Tamiya) P-38 for the Mighty 8th GB. Stay tuned!
Here's to finishing more than 3 in 2022,
-O
-It's Omar, but they call me "O".
    November 2008
Posted by plasticjunkie on Saturday, January 1, 2022 7:20 PM
I'm in with a 1/32 Revell P51D Mustang.
 GIFMaker.org_jy_Ayj_O
    July 2008
Posted by castelnuovo on Saturday, January 1, 2022 11:41 PM
oortiz10
-O
I was about to say that you folks are free to unleash your animals Smile. I will finish my MIG 15 shortly, then start one of my critters.
    July 2008
Posted by castelnuovo on Saturday, January 1, 2022 11:42 PM
plasticjunkie
You are on the list. Feel free to set your Mustang free any time.
    November 2008
Posted by plasticjunkie on Sunday, January 2, 2022 7:59 AM
Thanks Castelnuovo. Thought a pony be fitting for this GB so here it is.
I bought this Revell 1/32 Mustang when it first came out a while back. I was hoping to find colorful markings for a NMF non filleted tail scheme but was unable to find one I liked. There is a huge selection for the filleted Mustangs so I opted to get a resin filleted tail from a company in the UK called  Aircraft Models.
I superglued the resin parts to the fuselage sides.
The resin parts are on solid and have good fit on the fuselage sides.
Preliminary dry fitting revealed a small gap on the fillet spine. Once the sides go together, I will use thick CA and baking soda as a filler on the resin allowing sanding the area to a thin sharp edge along the spine.
Posted by oortiz10 on Sunday, January 2, 2022 9:23 PM
PJ, nice work on the conversion. I once did the same thing...but in 1/48...on a Tamiya...with Ultracast's fillet-less tail. So, yeah, totally the same thing.
Actually, that was the first time I used any sort of resin coversion, or any resin for that matter, besides the occassional seat or wheels. That was, until today...
I am going to use Wolfpack's resin wingfold set on this build. The first thing I had to do was chop up the wings. I was a little nervous because WP's instructions aren't terribly clear. So, I went for it and turned this...
Into this...
I haven't started assembly yet, but things look promising after some dry-fitting. In the photo above you can see AMT's lovely detail.
That was all I was able to get done on the Tigercat today. I'm expecting to have some benchtime tomorrow, so maybe I can make some more progress on these wings.
Until then...stay tuned! Oh, and don't forget, comments, questions and criticisms are welcome.
Cheers!
-O
    November 2008
Posted by plasticjunkie on Sunday, January 2, 2022 10:01 PM
Thanks O, your kitty is coming along fine.Yes
Those AMT kits are very nice and pack lots of details. I have the F7F-2/2N and the 3N in the stash, both 1/48 from AMT.
    August 2015
Posted by crown r n7 on Monday, January 3, 2022 1:14 PM
Castelnuovo. would the f-86d sabre dog qualify?
 Nick.
Posted by oortiz10 on Tuesday, January 4, 2022 2:40 PM
I've had some time at the bench, so I took advantage and made some progress on my Tigercat.
I was able to get the inner wing sections with the resin bits assembled. I must say, Wolfpack's resin fit very well! There was some minor trimming and thinning necessary, but overall, the parts were a drop-in fit! This is the first time I've tried a major resin coversion like this, and I must say, I'm impressed! There will be some minor filling and sanding, but nothing too difficult.
I was also able to get the fuselage assembled. This thing needed A LOT of weight in the nose. It's a good thing there is plenty of space in its long nose to stuff a bunch of pine derby car weights into. Unfortunately, I didn't take any photos. Here it is with all closed up with the seams cleaned up and the panel lines rescribed.
Next I'll be focusing on cleaning up the inner wing section.
So, that's it for now. I expect some more serious benchtime in my future. Stay tuned...
Cheers,
-O
    July 2008
Posted by castelnuovo on Tuesday, January 4, 2022 5:37 PM
crown r n7
It is a dog and the dog is an animal. So yes Smile List updated.
Posted by oortiz10 on Wednesday, January 5, 2022 6:31 PM
Hey gang, I have a little progress on my Tigercat to share, but before I do, I have a confession...I cheated.
I cheated on a couple of the less visible seams. At the bottom of the nacelles, the joint runs through the exhaust channels (for lack of a better term).
The two sides are angled and meet at an interior angle that I thought might be hard to fill and sand. So, I tried using some filler and a diluent, but I kept wiping away too much filler when I tried to smooth things out. As an option, I decided to use tape.
Yes. Tape.
I used some of the "Scotch" type because of its lack of texture. I laid a piece on then carefully trimmed it to fit the area.
I was careful to burnish the edges and the areas up to the seam but did not press the tape into the angle's apex. Once covered with primer, it looks OK.
Luckily the areas will be mostly covered by the engines' cowl rings, so not terribly visible. Again, this is on the underside of the nacelle. I'm OK with it...
Speaking of primer, I was able to get all of the major sub-assemblies primered.
There are a few places that still need a little love. Nothing major, just a kiss here and there. All in all, I'm happy with where things are at. It's starting to look like an airplane!
Again, comments, questions, and/or criticisms are welcome.
Thanks for looking!
-O
Posted by keavdog on Wednesday, January 5, 2022 6:42 PM
Brilliant!  Any concern of it lifting?  I've got that kit in the stash with the Lonestar fire bomber conversion tank.  Not sure if was mentioned but don't use the rubber tires, they melt the plastic wheels.  I made that mistake back in my late teens...  EDIT:  just read your first post and looks like you have it cover with the TD wheels - I've got the same.
Thanks,
John
    July 2008
Posted by castelnuovo on Wednesday, January 5, 2022 9:06 PM
Nice progress ooriz10. The tape trick is one to remember LOL
Posted by oortiz10 on Wednesday, January 5, 2022 11:29 PM
keavdog
...Any concern of it lifting?...
Nah. I bought an old kit at a swap meet or yard sale, I don't remember which, that had a couple of clear parts masked in Scotch tape. The kit was O.L.D., but the tape was still on. As a matter of fact, it took quite some effort to remove it. Yeah, it's not exactly the same, but I think the stuff will hold. Only time will tell...
-O
    November 2008
Posted by plasticjunkie on Thursday, January 6, 2022 6:37 AM
I love the Wolfpack products. They fit very well needing minimal trimming.
The flaps, ailerons and elevators are all missing the riveting so, out came the RB Riveter and spent a few hours roling the missing details. Just enough to busy up the metal skin.
The parts before detailing.
After rolling the riveter.
Topside completed, the reverse sides will get the same treatment.
The rivets are subtle and hard to see in the pictures but will be more visible after paint and washes.
    May 2004
Posted by cbaltrin on Thursday, January 6, 2022 7:14 AM
Your riveting looks good PJ.  A riveter is a tool I still do not have. It keeps getting bumped down on 'to get' list by other things.  Right now I am looking for a replacement to my dremel and a more powerfule blower for my spray booth. Kit Aquisition Syndrome is getting in the way as well!
On the Bench: Too Much
    November 2008
Posted by plasticjunkie on Thursday, January 6, 2022 8:50 AM
cbaltrin
Thanks cb. I highly recommend the one I’m using. It has several wheels for different scales and simply attaches to the reliable xacto handle. About a year or two back I got a nice adjustable speed rotary tool on eBay. Shop there and Amazon for a decent set.
    July 2008
Posted by castelnuovo on Thursday, January 6, 2022 10:29 AM
Looks so plain before and looks so good after Smile
    November 2008
Posted by plasticjunkie on Thursday, January 6, 2022 2:04 PM
castelnuovo
Yes
    July 2008
Posted by castelnuovo on Friday, January 7, 2022 11:37 PM
Well, I am crackin' the Wasp open
Posted by oortiz10 on Sunday, January 9, 2022 8:40 PM
OK gang, I've made some more progress on my Tigercat. Once I had all the major subassemblies together, it was time to spray some paint. Before I could do that though, I needed to get the canopy squared away. That's where I ran into my first major problem of the build.
As I was sawing the canopy from its sprue, I had a minor mishap. The canopy tore away from the sprue and lost a big chuck of a corneras a result.
To fix it, I glued a small strip of styrene to the inside of the canopy. This would act as a backing for some filler.
Some careful masking and filling with Tamiya White putty...
Led me to an acceptable end.
But that wasn't the only problem with the transparencies. The parts themselves are too narrow for the cockpit opening. I had to use a spreader to keep the canopy at the correct width while the glue dried.
Once the canopy was set, the windscreen was a little easier. I was able to press down on the windscreen to spread it to the correct width while its glue dried.
After that, it was time to paint!
I used various blues over the Mr. Surfacer primer to help break up the ultimate Sea Blue finish.
I still need to go back with a (very) thin coat of the Sea Blue to tie things together, but I'm happy with the results. I was looking for a blotchy weathered look, and I think I got pretty close.
That's where things with the Tigercat stand as of now. I have to go back to work tomorrow, so there might not be any progress made until next weekend. As soon as I can post some more progress, I will.
That's it for now. Stay tuned for more. Your questions, comments, and/or criticisms are welcome.
Thanks for lookin'!
-O
    May 2004
Posted by cbaltrin on Sunday, January 9, 2022 9:53 PM
Looking good oortiz. Nice save on the canopy.
    July 2008
Posted by castelnuovo on Tuesday, January 11, 2022 12:00 AM
Little progress on the Wasp
    July 2008
Posted by castelnuovo on Sunday, January 16, 2022 7:28 PM
Suspension and chassis done. Everything fits perfectly but the small parts are quite a challenge for my shanking hands so slow progress.
    November 2008
Posted by plasticjunkie on Sunday, January 16, 2022 10:28 PM
That looks really sharp castelnuovo, lots of detail on there.
 Got the pony pit completed. I used the kit decals and placards but were not enough so I dug into my spares for anything looking close to what the pony used. The wood floors were painted black and would show some foot traffic from use. I simulated this effect by dry brushing dark brown on the worn areas.
I wired up the radio battery.
The pit sides after paint and decals.
I used some Verlinden 1/32 seat belt buckles and wine foil to make the seat belts
Used The kit decals for the instrument faces then added clear parts cement for the glass.
    July 2008
Posted by castelnuovo on Sunday, January 16, 2022 11:27 PM
Holly molly, that looks fantastic.
