Pvt Mutt
"HELP"
Now that the base coat is on, do I now just finish it as a normal gray scheme and then over-lay the white wash?????
"OR"
Work the white wash in as part of the paint job and then do my filters,washes and pigments to finish up?????
Thanks for your technique knowledge Tony "Dumb as a rock" Lee
Tony, glad I saw this in time!
You should DEFINITELY go for a "hairspray technique" finish on this one for the whitewash! Her's what to do----
Finish your model in the gray scheme--weather it with washes, drybrushing, etc--but no pigments or anything like that YET. Then, seal it with dullcoat or Future---here's the key; if you want the hairspray to come off in bigger chunks, seal it with a gloss. If you want a little more resistance to the hairspray, and a rougher whitewash chipping, use a dull coat. The sheen of the sealer determines and affects how much ofthe next paint layer comes off.
Next, get some cheap hairspray., Give the model a GOOD cover with it. Hairspray tends to come out pretty heavy--it might skeer ya at first, but fear NOT (!) Mighty Lee! That's what you want!
Let dry completely for about 4 hours. Now, put a few small "squares" of tape down first---about 5mm square---as "masks:where you know that you will definitely want the whitewash "removed". This will be necessary to "get under the paint" with the next step. Next, take some acrylic white paint--doesn't matter which. Spray it in a sloppy coat, heavy here, lighter there, and cover the tank.
Now comes the fun part. Get a stiff, short-bristled brush, First, take a wide soft brush and wet one hull panel or side with a good swipe of regular water. Let it sit for a few minutes, Now, use the stiff brush to start scrubbing away the white layer, brushing away the tape squares. You will be able to degrade the white wash in an amazing fashion. Take a look at my MIG KT here for how I did it there.
/forums/t/106709.aspx?PageIndex=3
GO FOR IT, MAN! It will look great! GOOD LUCK!!!
