Official Ho229 Group Build
    April 2005
Posted by Thunderbolt379 on Tuesday, January 25, 2011 5:05 PM
Vance -- for your canopy I can seriously recommend Squadron Thermoform. Easy to use -- carve your pattern from balsa or basswood, sand to shape as precisely as you can, fill the woodgrain (for balsa I use the old dope and talcum powder mix, it's fragile but creates a surface like glass), then heat small pieces of the clear sheet over a candle and draw them firmly down over the pattern. It might take a fair few goes to get one just right, when I did a scratchbuild SF aircraft a few years back I took at least fifteen shots before I was satisfied, but the end result really does look the part!
Cheers, Mike
http://worldinminiature.blogspot.com/
Posted by VanceCrozier on Wednesday, January 26, 2011 9:16 AM
Thanks for the Squadron Thermoform tip Thunderbolt. If I do go the thermoform route, I'm going to pull a Hans von Hammer & try it with some packaging plastic I have gathered up first, see how that works.
Think I'll try to work on the engine pods tonight. I've, uhhhh, liberated a variety of pens from the office, will try to use end pieces or pen caps as a start for building the cones that project out of the engines.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by Anonymous on Wednesday, January 26, 2011 9:19 AM
The agent---I mean cat, is watching your every move with contempt and skepticism...
    January 2003
Posted by p38jl on Wednesday, January 26, 2011 9:23 AM
Indifferent
[Photobucket]
Posted by VanceCrozier on Wednesday, January 26, 2011 9:56 AM
Manstein's revenge
That's nothing new, cats are like that!
    January 2003
Posted by p38jl on Wednesday, January 26, 2011 10:21 AM
ve need more agents.... er..cats...Whistling
[Photobucket]
Posted by Anonymous on Thursday, January 27, 2011 6:36 AM
We need more building of the 229...
Posted by VanceCrozier on Thursday, January 27, 2011 7:29 AM
Alright, got a question for the more experienced styrene-benders out there.
I made the tubes for my engines last night. I cut some rectangles of sheet styrene (.01? I think) to the right size rectangle, leaving a little overlap. Heated up the styrene under my work lamp, wrapped it around the barrel of a thick pen, and glued the seam. Because I was working with thin sheet I repeated the process, starting the end of the second sheet where the seam from the first wrap ended. The second layer I glued all the way around as I was wrapping it to make sure there weren't any gaps.
Well, they're tube-ish, but not round enough for my liking. I'm thinking of picking up a piece of wooden dowling as close to the right size as I can, then wrapping a layer around that, keeping the dowel inside the tube to hold its shape. I'd have to leave a little overhang on either end.
Any other ideas?
Oh, a little note. While I was rolling tubes (with my puzzled wife watching from the couch) I spilled probably 1/3 of a bottle of Tamiya thin cement on the cutting mat. Good news, it stayed on the mat, thereby saving me from re-finishing a kitchen table. Bad news, does that Censored ever stink up a house when you let it loose like that! It also removes the cutting line grid, if you're interested!! Big Smile
    January 2003
Posted by p38jl on Thursday, January 27, 2011 8:24 AM
Vance.. humm.. maybe magic markers? cut them apart ? copper tubing from the hardware store ? maybe lurk the craft section of your LHS ? for tubing ideas ?
[Photobucket]
Posted by VanceCrozier on Thursday, January 27, 2011 8:37 AM
...last time I lurked in a store I got kicked out for three months! Propeller
    January 2003
Posted by p38jl on Thursday, January 27, 2011 8:39 AM
sheesh.. well.. dont try the lingerie on this time.. wait till your home!! Wink
[Photobucket]
    January 2003
Posted by p38jl on Thursday, January 27, 2011 8:40 AM
ok,, progress and set backs last night...
figured out the decals as best I could.. HOT water,, and patience... and its still a crap shoot..
I masked and hand painted the walkways...[View:/themes/fsm/utility/Photobucket:550:0]
[Photobucket]
    January 2003
Posted by p38jl on Thursday, January 27, 2011 8:43 AM
Lightningoops.. I preposted..
second... starboard side..[View:/themes/fsm/utility/Photobucket:550:0]
Setback.. was, when I was done and applied a dull coat, the metalisizer after the engines on the port side, crazed...AngryBang HeadBang HeadCensored,, no pics of that yet,, I walked away...
grrr....Storm
[Photobucket]
Posted by Anonymous on Thursday, January 27, 2011 8:43 AM
Wing walks are always dubious decals at best to use becuase there is more carrier film than actual print going down and if the decals are not perfect you will usually have grief over them...I tend to leave a lot of these off of a/c builds because of that issue and because often you will see in ref pics that they were not applied or painted over during camo applications, etc...at this late stage in the war probably a lot of stenciling was never applied anyway...
Posted by VanceCrozier on Thursday, January 27, 2011 9:02 AM
p38jl
Awwww, who told? Embarrassed
    April 2005
Posted by carsanab on Thursday, January 27, 2011 10:31 AM
VanceCrozier
http://i1012.photobucket.com/albums/af250/VanceCrozier/Horten%20229%20Scratchbuild/100_5840.jpg
Any other ideas?
Hollowed out cat femurs work just as well....
Meouw!!!!
Carlos
 Photobucket
Posted by Anonymous on Thursday, January 27, 2011 10:40 AM
carsanab
 VanceCrozier:
Any other ideas?
Meouw!!!!
Carlos
Ahhhhh...that explains why I didn't get my usual morning report from the agant---I mean cat---at Vance's house...
    January 2003
Posted by p38jl on Thursday, January 27, 2011 10:46 AM
Manstein's revenge
 carsanab:
 VanceCrozier:
Any other ideas?
Meouw!!!!
Carlos
humm.. that might explain the peculiar odor wafting down from the Maritimes this am...in the early morning snow..Chef
[Photobucket]
  • From: 41 Degrees 52.4 minutes North; 72 Degrees 7.3 minutes West
Posted by bbrowniii on Thursday, January 27, 2011 10:55 AM
Manstein's revenge
First Tunisia, then Egypt, and NOW??  THE OFFICIAL Ho229 GB FORUM!!!
Lurkers of the world, UNITE!!! Join me now, to throw off the chains that bind you! Let no further work be done until we see some progress from the Field Marshall himself!!!
LURKERS!!! LURKERS!!!! LUUUUUUUUUUURRRRRRRRRRRRRRRRRKKKKKKKKKKEERRRRRRRRRRRRRRRRRRSSSSSSSS!
FIGHT TYRANNY IN ALL ITS FORMS!!!
Whistling
'All that is necessary for the triumph of evil is for good men to do nothing' - Edmund Burke (1770 ??)
    April 2005
Posted by carsanab on Thursday, January 27, 2011 10:56 AM
p38jl
 Manstein's revenge:
 carsanab:
 VanceCrozier:
Any other ideas?
Meouw!!!!
Carlos
and his new ear muffs....(made from100% Muffy fur)
 Photobucket
Posted by Anonymous on Thursday, January 27, 2011 10:58 AM
I order all members of the "Order of the Rubber Spine Device" and/or holders of the "229 Cross" to mobilize and neutralize bbrowniii with extreme use of all and any means...
Posted by bbrowniii on Thursday, January 27, 2011 11:01 AM
Disclaimer:
The previous post was inspired by a post in another thread, and is intended as nothing more than good natured sarcasm from a lurker. Field Marshal, I hope you won’t feel the need to send the Gestapo to my house… Propeller
To all of you guys doing builds in this GB, great job. It is great fun to lurk here and watch to goings on…
Vance – good luck with that styrene rolling. I’ve had mixed success with that, so I won’t offer any suggestions…
Can't wait to see more... and tweak the Field Marshal from time to time...
Posted by VanceCrozier on Thursday, January 27, 2011 11:03 AM
Help! Help! I'm being oppressed! Violence inherent in the system! Violence inherent in the system!
    October 2008
Posted by oddmanrush on Thursday, January 27, 2011 11:16 AM
Hello, Mr.....Brown.......come with us, please.
Jon
My Blog: The Combat Workshop
Posted by Gamera on Thursday, January 27, 2011 1:07 PM
BAH!!! Cats are nothing!!!
Wait till you are attacked by an army (air force?) of FLYING TREE RATS!!!!!!!!
Posted by bbrowniii on Thursday, January 27, 2011 2:40 PM
You'll never take me alive!
Posted by Anonymous on Thursday, January 27, 2011 2:43 PM
Yikes, they did get my spy---eerrr, I mean, cat...
Posted by bbrowniii on Thursday, January 27, 2011 2:47 PM
Whose next?  I'm ready for you MOJOs... dontcha think for a minute that I'm not!!
Posted by bbrowniii on Thursday, January 27, 2011 2:48 PM
Oh, yes... READY I am... (in my best Yoda voice)...
Posted by bbrowniii on Thursday, January 27, 2011 2:50 PM
And then, there is always my final line of defense...
GIMME YOUR BEST SHOT, MOJOs!!!!!
Devil
Disclaimer - that's a 'J' ladies... don't get your panties in a bunch...
