Messerschmitt BF109 GB 2012
    December 2011
Posted by Luft Modeler on Wednesday, January 18, 2012 6:24 PM
Squadron Signal BF-109E walkaround has very detailed photos including the wheel wells
    July 2011
Posted by handiabled on Thursday, January 19, 2012 7:30 AM
    Going to start weathering the cockpit after adding the upper mg's and scratch more detail around the engine,,,, then onto the problematic fuselage,,, Herman and I thank you for looking,,,,
[View:/themes/fsm/utility/Photobucket:550:0]
    February 2011
Posted by Reasoned on Thursday, January 19, 2012 10:39 AM
Looking good handi Yes.  Just curious, is this going into the GB section?
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    July 2011
Posted by handiabled on Thursday, January 19, 2012 1:00 PM
Reasoned
Thanks Reasoned!!   To be honest I never even thought about the GB section,,, mabye that should be changed,,,,,, heres the weathering done so far,,,,,what do you think?   I suck at judging whats too much or not enough,,,,hope to see your build soon!
    November 2011
Posted by 70gtvert on Thursday, January 19, 2012 1:28 PM
Looks good. Were you aware that on the inlet side of the engine block there was a white serial #? Easy to do with dry transfers or a stead hand and fine tipped brush. John
    December 2011
Posted by Luft Modeler on Thursday, January 19, 2012 3:04 PM
I think its looking good! Tell Herman no laying down on the job or high command will send him to the Russian front.
    July 2011
Posted by handiabled on Thursday, January 19, 2012 7:12 PM
                  Thanks guys and for the heads up John!  Started detailing the engine and compartment,,,,,,,,,
    December 2011
Posted by Luft Modeler on Thursday, January 19, 2012 7:58 PM
Wow, I am loving the detail of the engine of this kit!!! I will need to get this kit you have after I finish my first 109.
    July 2011
Posted by handiabled on Thursday, January 19, 2012 8:30 PM
pzl66
 The add ons you see in the last two shots are all scratched from styrene, solder and wire insulation,,,,,,,,just trying to fill the engine compartment a bit more and give it a more realistic feel,,,,without loosing my mind     Indifferent
    July 2011
Posted by handiabled on Friday, January 20, 2012 12:54 PM
       Here's a few more wip pics,,,,, Herman and I are feeling like we're hogging this GB,,, sorry dudes,Embarrassed,,,,thanks for looking,,,,,,,,,,,
Posted by VanceCrozier on Friday, January 20, 2012 12:57 PM
Handiabled - no worries about "hogging the thread", you've just gotten off to a better start than the rest of us! (I will probably be lurking for the most part until the summer judging from the other builds I need to finish off first Embarrassed)
Nice work on the plumbing on that engine!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    July 2011
Posted by handiabled on Friday, January 20, 2012 1:02 PM
VanceCrozier
                  Thanks !!!  Look forward to seeing your 109 !!  Cool
    December 2011
Posted by Luft Modeler on Friday, January 20, 2012 1:03 PM
No worries handi Im enjoying your build so far so keep the pics coming! Seems like Herman is being a little commanding lately. Telling you to put parts here and there, has Herman done his fair share of work??
    July 2011
Posted by handiabled on Friday, January 20, 2012 1:08 PM
pzl66
Thanks!! I will,,, no problem there,,, all Herman does is crank Do Hast on the boom box and watch me sweat (typical Illinois Nazi     Sad)
Posted by VanceCrozier on Friday, January 20, 2012 1:35 PM
Here - just so handiabled doesn't feel alone. Wink  This -109G-10 was finished up in the fall. 1/48 Revell kit:
    July 2011
Posted by handiabled on Friday, January 20, 2012 1:46 PM
VanceCrozier
      Thats a beauti Vance!!    Thanks!!    Hope mine turns out as good !    Smile
Posted by VanceCrozier on Friday, January 20, 2012 1:51 PM
From what I've seen of your engine work, you won't have any problems! How do you like the Trumpeter kit? (I know, you've just started it!) I haven't picked up one of their kits yet.
    July 2011
Posted by handiabled on Friday, January 20, 2012 3:41 PM
VanceCrozier
Thanks again Vance for the kind words,,, so far I'm impressed with the kit,,oob it comes with some pe and vinyl tires,, other than the squared wheel bays and some changes that need to be made to the rudder and control surfaces it's a nicely detailed kit with crisp lines and pretty minimal clean up off of the sprue,,,,first Trump kit I've built also,,,,thought I'd give it a shot,,,,so far so good  Yes
    June 2010
Posted by DoogsATX on Friday, January 20, 2012 4:06 PM
VanceCrozier
http://i1012.photobucket.com/albums/af250/VanceCrozier/Bf109-G10/IMG_0734_sm.jpg
She's a beaut, Vance!
Since we're sharing, here's my Eduard 1/32 E-7 Trop from this time last year:
And Vance's favorite epic RATO pods...
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    March 2010
Posted by Nathan T on Friday, January 20, 2012 5:07 PM
Great job Doogs I've always wanted to try the desert/olive green schemes...Some more inspiration-
    July 2011
Posted by handiabled on Friday, January 20, 2012 6:10 PM
                                     Hey guys,,,,,,after seeing these builds I think you've raised the bar a bit,,,they look great!!  Yes
    December 2011
Posted by Luft Modeler on Friday, January 20, 2012 6:43 PM
Ok quick question, Im looking for an "E" version 109 model that 1/48 scale and that is well made with a nice amount of detail. Any suggestions? The G version is nice and all but the E model is my favorite.
    March 2010
Posted by Nathan T on Friday, January 20, 2012 6:52 PM
[quote user="pzl66"]
I think the Tamiya one is actually a little superior to hasegawa's Emil, and IMO it beats the Airfix too, but out of these 3 hasegawas decals are the best and that doesn't say much...
    December 2011
Posted by Luft Modeler on Friday, January 20, 2012 7:09 PM
[quote user="Nathan T"]
pzl66
Thanks for the heads up, decals are the least of my issues with kits.
    April 2006
Posted by jgeratic on Friday, January 20, 2012 7:39 PM
I wouldn't be so quick to discount Airfix's new tooling of the 109e that can built in one of three versions.  I've only come across box reviews of the kit, but many have concluded that although the new molds are not ground breaking, they do bring it on par with Tamiay and Hasegawa.  I've an open box in front of me now and comparing to a built Tamiya E-4, my only concern is the somewhat heavey panel lines - whether this will appear less after a few layers of paint and clear cotes remains to be seen (will only know after I build it later for this GB).
If you plan to build the 109 with lowered/raised control surfaces might want to consider Airfix as they are all molded separately.  I've read the Tamyia E-3 version had issues with cowl shape.  On the E-4 it was corrected but unaware if subsequent boxings of the E-3 followed suit.  I've only the Hasegawa E-1 and is somewhat sparse on wing surface detail compared to the other two.  It also has the  exhaust molded as part of the fuselage.
regards,
Jack
    March 2010
Posted by Nathan T on Friday, January 20, 2012 7:52 PM
Good observations Jack, Yes the hasegawa has some low points like the exhaust you mentioned and both tamiya and hasegawa's earliest boxings had incorrect noses, however this was fixed right away, all the "JT" series hasegawa boxes are correct. Both Hase and Tamiya have better surface detail than the Airfix, but the hasegawa Emil molds are getting a little old as the panel lines in places are shallow and barely visible, but maybe that was just the kit I had. You'll have to let us know the verdict when you start yours.
    June 2010
Posted by DoogsATX on Friday, January 20, 2012 8:07 PM
I'm tackling the Airfix next so I'll let y'all know. Also, Eduard is going to be doing their Emil line in 48th. Been plugging the new E-1 hard on Facebook this week.
    December 2010
Posted by Geof on Friday, January 20, 2012 8:32 PM
Hey, builds look great! While we are doing a sort of primer gallery I thought I would add. A 1/24 Trump G-6 Hartmann along side a Hartmann G-6 1/48 Academy:
Photobucket
Photobucket
On the Bench: Tamiya's 1/48 A-10a Thunderbolt
In the Hangar:  Hmmm???
    December 2011
Posted by Luft Modeler on Friday, January 20, 2012 9:23 PM
Geof
http://i1113.photobucket.com/albums/k519/Geof3/hart-7.jpg
When are you going to take the 1/24 out to fly?? That thing is huge!!
    February 2011
Posted by randypandy831 on Friday, January 20, 2012 10:04 PM
i want to start on my G-10 but school is overwhelming me. hope to get some work done on sunday.
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
