Latest update on the B-29. I painted the engine cowlings. They turned out fairly good but need some touch-up to be complete. Photos below with commentary:
image by robertholcomb73, on Flickr
This shows the stainless steel front and some of the polished aluminum base, along with the white squadron marking. Need some touch up along the edge of the white; probably do that by hand (advice accepted, though...)
A second cowling, again showing a need for touch up.
The photo below shows something interesting (at least it was to me...)
First issue was some of the Polished Aluminum on the base pulled off, as can be seen to the left of the photo. That is bare plastic showing, so it pulled off the Polished Aluminum layer, the gloss black layer, and the grey primer layer. I used Tamiya masking tape and it seemed to be good everywhere else. Have to figure out how to touch that up and it may mean re-spraying the whole cowling.
Second item of interest is the spot on the Stainless Steel section of the cowling, in the center of the photo. This spot was created after I put on the gloss black coat. I had masked the black while I sprayed the Polished Aluminum to avoid overspray. When I pulled off the tape, this spot in the gloss black appeared. I touched it up with the same gloss black by brush, and went off to bed. It appeared smoother than the rest of the gloss black when I got up this morning, but thinking it was just the undercoat anyway, I figured what the heck and proceeded to spray over it all with the Stainless Steel. Whammo, suddenly that section of the engine cowling look exactly liked smooth metal. You could literally see your reflection in it if you got close enough to it.
My fears about the masking over the gloss white were unfounded; it did not pull up when I removed the tape. The Alclad; not so much. Perhaps I did not wait long enough for it to dry; I gave it roughly 24 hours and maybe I should have given it more. It is also clear to me that polishing the gloss black coat is important after you apply it.
Despite all the trouble, I am overall pleased with the colors and general appearance. I still have to touch it up to be perfect.
As always, open to hearing about good ideas and suggestions for me to improve. Mask kit for the cockpit glass hasn't arrived yet. Propellor tips and hubs are next on the agenda, and the gear and bomb-bay doors, and gun turrets.
