Well, one thing I have found out is that it took a whole lot less time to build a real B-29 than it has taken me to build this model of one...
As I suspected, a lot of seam work has been in my life lately, not just because of ill-fitting seams, either. I have done a lot of discovery learning and re-learning. I have finally settled on Tamiya white putty as my putty of choice, and am happy with how it is turning out. Photo below shows one underside wing seam and the center seam between the bomb bays. I have also stuffed tissue into the wheel wells to avoid overspray when I prime it.
photo 1 by robertholcomb73, on Flickr
Next photo shows overview of entire underside:
photo 3 by robertholcomb73, on Flickr
Center seam is almost (but not quite) finished, with about 3 inches aft of the rear bomb bay still to be sanded (it is drying as I write; it included a round hole for the clear plastic support to be emplaced, upon which the tail would rest when the model was displayed. After putting about 15 pounds of lead weights in the nose, I don't think I need the plastic strut and so puttied over the hole)
The starboard horizontal stabilizer had a significant ridge where it mated to the fuselage. This could be a bad design or it could be that I screwed up somewhere when I installed it. To remedy the situation, I took two white styrene strips, one .02" thick and the other .01" thick, and used them to make a "stair" gradually sloping down from fuselage to stabilizer. A little putty and a lot of sanding later and I have a smooth blending of stabilizer to fuselage. That is what that the white strip is on the right side (starboard when the airplane is right-side-up).
Below pic is a close up of the strips. Sanding is almost completed on them now. The white line on the left side stabilizer is just the putty seam; no styrene needed there.
photo 2 by robertholcomb73, on Flickr
It was a stroke of genius to use different size corks to plug the gun turret holes prior to painting. You may also notice that the horizontal stabilizers themselves are already primed; I got ahead of myself and primed them before they were installed. I then got to sand away much of the primer for my haste.
I have found if I sand away the panel lines that a light scribing with a metal ruler makes a suitable replacement. I know one is raised and the other is not, but it fools the eye for a short panel line.
Anyway, just wanted the forum to know I was plugging away and making progress. Figuring out my own best technique for putty and sanding was a major step (and with a lot of mis-steps along the way!).
BTW, in my spare time I have also now begun the Trumpeter 1/48th C-47 aircraft, in honor of my mother-in-law who was a flight nurse on one in WWII. She now lives with us, became interested in the B-29 work and inspired me to do something for her service as well. I probably won't go on writing about that build until the B-29 is done, but it gives me something else to work on whilst waiting for stuff to dry or if boredom sets in with sanding. There are about a zillion parts in that Trumpeter kit. I will have to scratchbuild stretcher racks inside, I guess.
cheers, Bob
