Fairly big progress update from me. For those on dial-up (dupes), sorry but this is somewhat image-intensive.
I have the cockpit squared away, or close enough that I'm ready to move on. I agonized over the interior color for awhile. All my reference material indicated that German aircraft interiors were RLM 02 until November 1941 when the switch to RLM 66 occurred. The particular kit marking's I'll be doing are a snapshot of the aircraft in 1941, so I could go either way and likely be right. In the end I went with the RLM 66. Suffice to say but Monogram's color markings were less than helpful.
I also guessed on the long floor area off to the right of the pilot. I wasn't able to find any good pics of this area so I assumed this would be a padded spot for bombadier to lay down on. Thus the leather color. If I'm wrong...meh.
I also have the fuselage, wings, elevators, main wheels and torpedo's glued together.
At this point the legendary Monogram fit is living up to it's reputation. With a wing loosely placed, the underside joint isn't too bad.
The joint on top, however.... That's about an 1/8" gap at the widest point. And the other wing is exactly the same. <sigh> It's always something. I'll have to use some styrene strip to fill that distance.
Anyway, slowly but surely.
Cheers
