Thanks Josiah! BTW, those are all steel wheels on Stikpusher's T-34, not rubber on them. Looks like he painted the contact surfaces a metallic color which would be appropriate. Same with the tracks, the surfaces that contact the wheels are shinier than the rest of the track due to the metal to metal contact.
That being said I do like the way these are turning out Stikpusher. I agree with Josiah though regarding the bright look of the T-34. Are you planning on some special weathering on this guy?
OK, so I managed to fix, replace or remake the booboos on my KV-1.
Cut off the molded on tow hooks an drilled new holes.
Fixed the tow hooks with .020 brass wire.
Voila!
I don't know what this cable & hook assembly is for. Maybe the engine hatch is too heavy to lift by hand? Anway I cut off the molded, oversize cable & ring and replaced with wire.
The front DT mg was an easy fix...just a little liquid cement and it was back in shape. The turret rear mg was a different story. It disappeared, so I made a new one from SS tube, brass wire and aluminum sheet.
Actually, before I did all this I drybrushed the entire model with a light olive-green oil paint. This helped to lighten the paint job a little before the upcoming oil washes. The oil paint allows the drybrushing to be much more subtle. Its disadvantage is that it takes 1-2 days to dry. Sorry I didn't take photos of the model.
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
