War In The Pacific Group Build 2009 - 2010
    March 2006
Posted by simpilot34 on Wednesday, July 29, 2009 11:33 PM
Mo that looks GREAT!!!! Yes, I like the engine run pic as well!!!! Beautiful work!!!!
Stikpusher, looking forward to some pics!!!!
Didn't get on the bench last night or today, have a bit of a cold lingering and caught up with the forums last night and had a NICE sleep in today so after work tonight hopefully will get back to that blooming cowl of mine and gt it whipped and then concentrate on fuse seams. or the PE belts for the 1/48 Buccaneer I'm doing for the FAA GB. Will have planty to keep me occupied thats for sure!
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    January 2006
Posted by DiscoStu on Wednesday, July 29, 2009 11:39 PM
 Mobious wrote:
 Hey Stu, If you're trying for a chipped paint effect, you may want to consider trying the salt method. There was an article in Nov '08 FSM. It looks relatively simple and has really cool results. You may want to try a search on the Forums. I've never tried it. I have enough of a time getting the paint on, not taking it off. hehe.
I may have to.  For giggles I did a quick spray over some of the masked areas and pulled the masking film off, it did pull off the top coat.  And the clear coat.  And the Alclcad.  And the Primer.  So I'm in the process of pulling off all the liquid film and will give the rex a nice light sanding and start over.  I tried the salt technique on a Corsair a few years ago and had mixed results.  I had a little better luck recently with another Corsair but this time I was using the salt to mask random spots for various sprays of smoke, and lighter tints of the overall blue.  The end result was pretty good but I was left with some salt residue on the paint that needed to be covered up.
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
    March 2006
Posted by simpilot34 on Thursday, July 30, 2009 12:09 AM
Stu a reader tip a few issues back someone used a fine sand instead of salt. No residue then and it's reusable!!Thumbs Up [tup]
    September 2007
Posted by Mobious on Thursday, July 30, 2009 12:10 AM
 Hey Stu, I can understand how the residue could be a problem. It's great to get real life feedback on a technique that I've only read about. I have used Vallejo's liquid mask, but it's difficult to get all of it off. It's alot like rubber cement. There is another technique using hairspray. I've only read about it too and it's in the same FSM issue. The Armor guys use it for weathering winter white wash camo.
 Hey simpilot, thanks for the comments. When I get those six .50's I'll be making strafing runs on the cat! I did get the landing gear highlighted.
"It's a problem of applied physics" Roy Brown
    April 2005
Posted by carsanab on Thursday, July 30, 2009 12:12 AM
Hey Guys...
Here is a pic of my Seiran coming out of my "spray booth"...of course I already have a big greasy thumbprint on the green...boy it doesnt forgive you not wearing gloves, from now on I wont touch it without them....
Been working on the beaching dolly. I wasnt happy with any of my fake wood finish/paint on the slats.....so i figured why not go with the real thing....hey Mucker I guess not really a trick....still....I feel like Im installing wood flooring in Barbie's townhouse.!!! HAHAHABig Smile [:D]
Once im done I will stain it with some thinned down stain I used to refinish my backyard deck...cant wait to see how it turns out!! Hopefully the wood grain pops out a bit better.
Carlos
 Photobucket
    September 2007
Posted by Mobious on Thursday, July 30, 2009 12:30 AM
Hey stikpusher, thanks for the comments, looking forward to seeing updates on the Bearcat.
    March 2006
Posted by simpilot34 on Thursday, July 30, 2009 11:21 AM
Carlos she's looking great mate!!! I know what you mean about the thumb prints!Whistling [:-^] Is that the Tamiya IJN green you used?
    April 2005
Posted by carsanab on Thursday, July 30, 2009 11:52 AM
I did use the IJN green and the IJN grey...for some reason this time the grey seems to have a bit of a blue hue to it...it could be because its raw..no weathiering or washes yet...also a shot of dullcote tones it down a bit too...wait and see I guess...
 Photobucket
    September 2007
Posted by Mobious on Thursday, July 30, 2009 3:12 PM
 Hey Carlos, consider the thumb print as a signature! I always do. On the wood decking you may want to consider using an oil wash, or even my favorite coffee. I'd recommend experimenting with finishes on scraps of wood planking, before committing to a stain.  Just my 2 cents friend.
    April 2005
Posted by carsanab on Thursday, July 30, 2009 3:58 PM
Thanks Mo.. I will try all the methods..I figured regular wood stain thinned down a bit will work too..hey why not...it is real wood after all...still will test with a couple of methods see which looks better scale-wise.
 CS
 Photobucket
    July 2004
Posted by mucker on Thursday, July 30, 2009 9:02 PM
Carsanab and Mo: Wow!!! that's some great stuff.
    September 2007
Posted by Mobious on Friday, July 31, 2009 6:39 AM
 Thanks Mucker, the comments are appreciated.
 Replaced the canopy with a vacuformed one from Squadron. There are 2 in a set. One for yourself and the other for Justin. You know, Justin Case. They're pretty thin compared to the kit part and clear. I would have used the kit part if I'd planned on keeping the F4F closed, but I had to open it up and the thickness of the kit part really shows. The only problem is I should  not have installed the kit one in the first place. I had to pry it off with a small screwdriver, and the touchups seemed to never end at that point.
 A couple photo's of the VMF-223 Gaudalcanal F4F-4 Wildcat.
DSC_0001" border="0" />
 The MG's haven't been installed yet, missing the antenna, and the elevator hinges need work. I'll post a few more photo's when the whole thing is done, but until then this is what I've got.
 DSC_0002" border="0" />
DSC_0003" border="0" />
    March 2006
Posted by simpilot34 on Friday, July 31, 2009 7:27 AM
Mo that looks great!!!! Looking forward to her getting her claws!!!Thumbs Up [tup]
    July 2004
Posted by mucker on Friday, July 31, 2009 8:20 AM
Mo: The weathering...did you use the dot filter technique I see so much on the armor forums? whatever you did, the overall "finish" came out fantastic. the Wildcat is such a cool little bird.
    January 2006
Posted by DiscoStu on Friday, July 31, 2009 8:47 AM
Mo, that is superb.  Nicely done.  Positioning the flight surfaces really brings the plane alive.  I'm very impressed.
    January 2006
Posted by DiscoStu on Friday, July 31, 2009 8:57 AM
 Mobious wrote:
  (coffee, burnt umber, and a drop of detergent). After the wash was dried and sealed, a drybrushing of highlight color was added next. Exhaust and MG trails were airbrushed on. Here's what I got for the efforts.
I did a double take.....Coffee? Is that the color or the actual drink?  I've heard of people using actual coffee to weather things like scale maps and papers and was wondering if you've got another use for the wonderful black blood of life that starts so many of my days.  Care to explain?
    September 2007
Posted by Mobious on Friday, July 31, 2009 7:10 PM
 Thanks Guys for the comments, all are greatly appreciated. I was disappointed with how the Blue Grey finish came out on this build.  I'll be looking for another source for the blue grey other than the MM acrylics for future builds.
 The weathering was done with acrylics. A fan brush was used to streak the washes as they dried, the coffee was just handy, hehe. There's always coffee at my bench. I would have liked to done this up with a chipped paint effect, so I'm looking forward to seeing progress on how that turns out on the Claude, Mucker.
 Hey Carlos, I signed this one with a few thumb prints too, actually more thumb prints on this one than what's in the FBI database, hehe.
 Looking forward to seeing progress from everyone,
 Mo
    July 2003
Posted by jay12472 on Sunday, August 2, 2009 7:55 AM
hey Just back from vacation and got to take a look. mo the wildcat looks great, sim the dauntless,rufe, and pete are coming along very nicely.
hope I didn't forget anyone
Jason
    March 2006
Posted by simpilot34 on Sunday, August 2, 2009 8:34 AM
Welcome back Jason!!!! Hope the holiday was a good one!!! Yes those builds are going very nicely, but I'm doing a Jake!Big Smile [:D] Must have been a good vacation!Laugh [(-D] Again,Sign - Welcome [#welcome]back!!!
    November 2007
Posted by Recon on Sunday, August 2, 2009 8:44 AM
I would like to sign up for this one.
    March 2006
Posted by simpilot34 on Sunday, August 2, 2009 8:55 AM
Sign - Welcome [#welcome] aboard Mike!!!!! The CO darson(Darren) will be along shortly to show you to your cabin. What do you have planned for us?
    July 2003
Posted by jay12472 on Sunday, August 2, 2009 2:22 PM
MIke dido welcome
Sim is was a good vaca sorry about the mix up but I did find some really strong beverage
Jason
    April 2005
Posted by carsanab on Sunday, August 2, 2009 11:26 PM
The "modeling elves" paid me a visit last night, set up shop and completed the woodwork on the beaching dolly....the wood stain needs another coat but I like their work so far....
at least they cleaned up after themsELVES...Sigh [sigh] oh and they painted my prop and hub too..
Thanks guys..
Carlos
 Photobucket
    September 2007
Posted by Mobious on Monday, August 3, 2009 3:50 AM
 Hey Carlos, The stain looks great. Those wood elves did a nice job. I like the little bucket, hehe. Great job and looking forward to updates on the floater.
    March 2006
Posted by simpilot34 on Monday, August 3, 2009 4:01 AM
Love the sawhorses and the bucket!!!! Hehe nice touch!!Big Smile [:D] Looking forward to more pics as well!!!
Jason,Whistling [:-^] hehe I'll have what you had!
Posted by darson on Monday, August 3, 2009 5:10 AM
Mo that's outstanding work you've done there and so quick Thumbs Up [tup]Thumbs Up [tup]Thumbs Up [tup], I haven't even finished assembling the cockpit yet Blush [:I]. I'll mark you down as completed on page one of the build. Oh and I don't know what you think is wrong with the Blue Grey finish, it looks spot on to me.
Hey there Mike (Recon) and Sign - Welcome [#welcome] to the build. Do you have any idea of what you may be building yet?
Carlos that's great looking work on the dolly, about all it needs is a few paint and oil stains.
Stu I'm looking forward to checking the Rex when that liquid mask comes off.
    January 2006
Posted by DiscoStu on Monday, August 3, 2009 9:30 AM
I'm hopeful I'll have pics up soon.  The liquid mask idea was a disaster so I re-did the aluminum and tried the salt technique.  The plane is now having it's clear-coat dry.  Once that is done I'll hit it with the last couple weathering layers and it'll be done. The salt worked  very well, though I may have overdone it a bit.  Once again, the salt left a bit of residue that was a bugger to get off, and even when you think it's off it shows through the finish like rust under paint.  So when I try this on the Pete I may use a salt substitute and go for more subtlety
    April 2005
Posted by carsanab on Monday, August 3, 2009 10:38 AM
hahaa thanks Jason...
its called too much time on your hands...I was bored watching the stain dry when I came up with the idea of making little saw horses with the scraps...the rest..well just silliness...oh and did you see they folded the painters tarp and left it on the bench too...Eight Ball [8] funny thing is as i was putting it together I just picked a random size...almost got the scale right...just a little too big...closer to 1/35 because thats and old bucket from an armor kit and it looks right...now that I think about it its been sitting in my spares box for over 25 years!!! WOW
CS
 Photobucket
    July 2003
Posted by KJ200 on Monday, August 3, 2009 1:38 PM
Mobius, great job on the Wildcat.
The faded finish looks spot on.
Darren, finally made up my mind, put me down for Hase's 1/72 Ki-44 Shoki.
Karl
Posted by darson on Tuesday, August 4, 2009 12:03 AM
No problems Karl, consider page 1 updated.
