Hey Carlos, thanks again for the heads up on the landing gear. The struts didn't fit properly. The stop at the top of the strut prevented the assembly from setting all the way down into postion. I had to trim the stops and file them smooth to get the lower brace up tight to the fuselage. I finally installed the gear and double checked alignment before glueing. I had to add some styrene to the strut attachment points to strengthen them for carrier landings. The Wildcat is setting pretty good. Both wing tips are equal to the bench and square with the cat. I'll start adding plumbing/detail to this area before I install the tires and gear doors.
I also placed the prop in position. The prop IMO,was setting to far away from the cowling. I sanded a little off of the engine and checked it again, A little made a big difference. And yes I was spinning the prop making airplane noises, Vrooom, takatakataka, Vrooom.
Hey simpilot, a great shot of the Pratt & Whitney, I used the Squadron F4F Walkaround for color reference. It shows a color photo of a restored engine, I believe, one recovered from Lake Michigan. I kinda figured all that shiney brass would have been a no-no on actual combat aircraft.
Thanks for comments, critiques, and for checking in.
Mo
