War In The Pacific Group Build 2009 - 2010
    August 2015
Posted by sf_plane_nut on Thursday, January 28, 2010 2:38 PM
VanceCrozier
Upper wing-to-fuselage join? I really didn't see anything that looked too bad, maybe different "in person"? And as far as the wash issues go, it's a P-40, it's supposed to look dirty! :) I actually like the look of it. Did you leave your wash on too long? Problems removing the excess? Thumbs up from my point of view!
thanks for the thumbs up guys...
it has some issues in the wing join area...never could get it nice and clean...i will try to get a better angle of it...
as far as the wash i tried a bunch of different stuff...ended up eating the future and staining the paint itself...upon cleaning it off and looking at it i too decided i liked it...need to get out the powders and finish it off...
    February 2006
Posted by ruddratt on Thursday, January 28, 2010 8:41 PM
Wow! You fellas have really been cruising right along!
Stik, the blue on the Hellcat looks fantastic! Did you do the demarcation freehand?
Paul, well done on your dio! I've never attempted one, but your fine work might be just enough to coax me into taking the plunge.
Carlos, I am thrilled that you were able to fix the issues with the NMF on your Jack. Definitely looking forward to seeing more progress on this one!
Dave, you are a machine, man! The office for your Corsair looks top-notch, and the P-40, well, it's one of my favorite warbirds and yours has me drooling!
Keep 'em comin guys!
I just got finished applying a flat coat to the main cockpit components on my Zeke, but it'll be a few days before I have anything significant to post in the way of pics. Soon though, with all the details.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    July 2003
Posted by KJ200 on Saturday, January 30, 2010 2:34 PM
Some progress on the Raiden....
...the yellow for the ID bands.
I used a custom mix of Tamiya yellow and orange for the bands, as well as spraying up the front faces of the props, as don't fancy using the Hase decals for the warning bands.
I've just Futured the orange, ready for masking tomorrow, after which it's on to the IJN grey.
Karl
    August 2015
Posted by sf_plane_nut on Saturday, January 30, 2010 2:55 PM
i have been going over/and over the colors for the corsair...keep coming up with ana602 sky gray for the bottom and inside the cowl...whats a good gray to match to that?...plain old light gray?..i cant find and examples for comparisons...
    March 2006
Posted by simpilot34 on Saturday, January 30, 2010 10:47 PM
Sf plane nut, Gunze H24 is the color I used on my ID bands!!! Didn't have to mix! However the  mixed color you have done looks spot on!!!!Toast
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    July 2003
Posted by KJ200 on Sunday, January 31, 2010 4:22 AM
Dave, if you are looking for paint matches try here...
http://www.ipmsstockholm.org/colorcharts/colorcharts.asp
Richie, I did look at the Gunze, as I will be using Gunze for the IJN Grey & Green, but already had the orange and yellow to hand.
I masked the bands up last night. I swear it took me an hour to get them straight!
Karl
    April 2007
Posted by polak on Sunday, January 31, 2010 5:47 AM
Darren sign me for sth. I haven't decided yet for:)
    July 2004
Posted by stikpusher on Sunday, January 31, 2010 1:33 PM
sf_plane_nut
Light Gull Gray is a good choice for this color. FS 36440.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2003
Posted by KJ200 on Sunday, January 31, 2010 1:59 PM
With the ID bands masked it was time to attack the underside of the Raiden with some paint.
I started with my usual preshade of Tamiya Nato Black along all the panel lines on the underside.
I don't bother with pre-shades under dark colours like IJN Green, as I prefer to use post shading instead, hence only doing the underside.
While I had the a/b loaded with Nato Black I painted the anti glare panel on the nose.
Here you can see it masked up after a coat of Future.
Looks a bit wasp like with all that black and yellow.
I then started on the IJN Grey, applying it to the centre of all the underside panels. You can barely make it out against the Tamiya Sky Grey I use as a primer coat.
Once that had hardened off for an hour, I went over the entire underside with further coats of Gunze IJN Grey, until the panel shading was only just visible.
I left the under carriage bays a little dirtier.
The whole lot is sitting on the bench drying as I type, so tomorrow night should see a coat of Future, before I mask up for the IJN Green.
Karl
    September 2007
Posted by Mobious on Sunday, January 31, 2010 2:40 PM
Thanks for sharing your in-progress pics of the Raiden, Karl. Love the looks of the Grey undersides.
Mobious
"It's a problem of applied physics" Roy Brown
    August 2015
Posted by sf_plane_nut on Sunday, January 31, 2010 3:01 PM
stikpusher
 sf_plane_nut:
i do have some of that...i was looking at plain old light gray but i will grab that up and compare...thanks...
    February 2006
Posted by DantheMan85 on Sunday, January 31, 2010 5:34 PM
I see come pretty good work going on over here!  I haven't done much with my B-29, my basement is a bit cold.  And every time I walk by RB-36H I get a headache.  I'll start on my B-29 when it warms up around spring time.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    March 2006
Posted by simpilot34 on Monday, February 1, 2010 1:47 AM
Karl, the Jack is coming along nicely!!!!!Toast
Posted by darson on Monday, February 1, 2010 11:06 PM
Great looking work on the Raiden Karl, keep those pics comings.
Posted by darson on Monday, February 1, 2010 11:47 PM
Well I've just gone back through the last couple of pages to see what I have missed and Wow that's some amazing work.
Paul congrats on a really fine looking dio, I've marked you up as finished on page 1 Toast
Dave, what can I say that Corsair is stunning and I agree with you the finish on the P-40 looks spot on.
Keep up the great work everybody and I may actually have some pics to publish on the 1/72 P-47 that I picked up again last weekend after it had sat on the shelf for 2 years.
    July 2003
Posted by jay12472 on Tuesday, February 2, 2010 5:29 PM
Hello all I just gone through the las tcouple of pages and there is some great stuff going
The sub dio is very nice, Love the detail work on the corsair, and the 2 jascks are real lookers
Jason
    April 2005
Posted by carsanab on Wednesday, February 3, 2010 11:10 AM
Karl.....Raiden is looking good,!!!! much better than mine,,,,I still havent repainted mine....got some chatch up work to do!
Carlos
 Photobucket
Posted by Gamera on Wednesday, February 3, 2010 2:08 PM
Wow I go away for a while and all kinds of awesome stuff gets posted!
Congrats all around!!!
I did find some dark grey sand that should work for my Iwo Jima diorama - now just to get some time to work on her.
    February 2006
Posted by ruddratt on Thursday, February 4, 2010 2:39 PM
OK guys, it's been a while I know, but I've finally been able to make a bit of headway on my Zeke. So far it's just the office, but I have to tell you that Tamiya knocked it right out of the park on this baby where OOB detail is concerned. Never thought I'd see one to top their 1/48 P-47's, but IMO this one does, and then procedes to raise the bar that much higher. It's a gem! All I needed to add was some PE belts - everything else is what comes with the kit.
Here are the sub-assemblies....
....and here's everything attached (including the gun breeches) just before I buttoned her up.....
    August 2015
Posted by sf_plane_nut on Thursday, February 4, 2010 3:27 PM
wow man...that looks great!...
    July 2004
Posted by stikpusher on Thursday, February 4, 2010 3:31 PM
Wow Rudd, that looks pretty impressive! I see what you mean about the detail. As far as topping their P-47 goes, I cant say, but I have heard that Mr Tamiya has a special fondness for Japanese subjects.
       - Plankton
LSM
    August 2015
Posted by sf_plane_nut on Thursday, February 4, 2010 8:40 PM
Been getting some stuff done over here as well...
think i am finally happy with the IP
A little dry brushing and detail painting...
need to do some more painting as i dont really like the gray...too blue...the knobs on the wiring harness are for the plug wires...
After going over the color reference i am working with i went for a dull dark green for the cockpit and the light gray for the underside and wheel wells but with the salmon primer for the front wells.....the wells and gear need another coat...
trying to get as much done as i can before surgery on the 25th...wont be getting much done after that for about a month...
Posted by darson on Thursday, February 4, 2010 9:07 PM
Mike that looks like an amazing amount of detail for an OOB front office and very nicely weathered too.  The Tamiya P-47 is my all time favourite kit and is my vote for best model ever, but if you are saying that the Zero is better I'd better get a start on mine.
Cheers
    March 2006
Posted by simpilot34 on Friday, February 5, 2010 1:47 AM
Mike and Dave, awesome work mates!!!!!!!!!!! Beutiful detail and painting skills at hand, and detail painting skills!!Toast
    August 2009
Posted by duiker2106 on Friday, February 5, 2010 6:03 AM
An update on the IJN wharf...
After finishing the I-400 I took a deep breath and did another try on the Akagi flight deck. First the white for the lines. No problem, can't go wrong (ok, i can but...)
After letting it dry for a day or 2, I start with the tape. It took the better part of the evening, but every stripe of white is there where it should be. After airbrushing the brown deck only the red "sun" and the red striping at the landing part of the deck had to be done. This was the 4th try on this part, so I was a bit nervous on that. Again masking the deck, airbrush... taking away the tape and... YES!!! IT WORKED!!!
With the old fashion hand brush I painted the grey parts on the deck, the sidewalks, so maybe this weekend I can finish the model. No diorama yet...
In the mean time, another big IJN ship has been placed on the wharf, the Musashi. So Darren... Would you please...?
Somthing else for you guys, I see the stakes are high here... Amaizing how detailed some people make the cockpits and the planes... The Elfes would love to fly them...
Paul
On the bench: 1:350 Yamato + I-400, 1:48 F15 strike eagle...
    August 2015
Posted by sf_plane_nut on Friday, February 5, 2010 1:05 PM
Way to go....glad it finally worked out for you...and the sub dio looks great as well...
    February 2006
Posted by ruddratt on Friday, February 5, 2010 8:46 PM
Thanks much, fellas! Got the halves buttoned up and have moved on to the wing assemblies. I'll keep ya posted.
Darren, stik - I love Tamiya's Jug kits (built the razorback and have a bubbletop in the stash). They are awesome kits with incredible cockpit detail, but I think the Zeke's is just a little better. As for the rest of the Zeke, I'll let ya know how she compares to them when she's finished. Yes
Dave, stunning work on the Corsair. Incredible attention to detaiI! I never saw that color in their wheelbays before. Gotta love this site. Always something new to learn.
Paul, mighty fine work on the carrier! Looking forward to seeing the Musashi too. Keep up the great work!
    July 2004
Posted by mucker on Saturday, February 6, 2010 9:01 PM
SF Plane Nut, coming along fine!
Mike: That is simply steller work, of which I'm not surprised. I always enjoy your builds!
    March 2006
Posted by simpilot34 on Sunday, February 7, 2010 5:38 AM
Paul, glad to see you finally got the flattop licked!!!! That looks great mate!!!! WELL DONE!!Toast
    March 2006
Posted by simpilot34 on Sunday, February 7, 2010 5:57 AM
Still haven't finished the Jake, not much left to do really. But there are fish to catch!!!
Some small Snapper(pinkies) I caught today.
