Jeremy- Very nice, ignore that luftwoller fella, he's just mad he isn't working on a 190 right now LOL. I had to look very, very hard for the crease on the spiral. I like it, well done!
Hugh- Ah,. yes... I love those half NMF/ half paint schemes, well done! Any new pics?
Krow113- Looking good there! I have to admit, I got the impression that you didn't want to post here in the GB anymore, so I removed your build from page 1. I would happily add it again, would you like me to do that?
stumpjumper70- Not to step on Jeremy's toes here, but there are many choices for solutions that will pull those decals down into the panel lines. Of course, just the brand of decal can impact how well they behave. First, I use Micro Mark setting solution to apply the decals. Put a brushful down on the surface where the decal will go, and after the decal has softened up I lay it into the pool of solution. I wait for a while (anywhere between 2 minutes and 15 minutes) to let the decal soften up, then gently pat it down to the surface with a slightly damp cloth. After the decal has had a while to adhere to the surface, it's time to pull them down into the lines. One trick I always use is to take a brand new hobby blade, and lightly cut the decals along the panel lines. That will help immensely to pull them down. I will then use one of these solutions to really pull them down. I use Micro Mark softening solution, Gunze Sangyo Mr. Softener, and Walthers Solvaset. In extreme cases, I have even used a tiny bit of liquid plastic cement! When using these more aggresive solutions, test it first on an extra decal to see how it responds. Once you start using these, the decals will really adhere well to the surface of the model. If you mess up, usually the only way to fix it is to rip them off with tape (along with some nearby paint) and start over. I hope that helped, if there is anything else- just ask.
