Sjumper and everyone else thanks for the comments. Its the Trump 1/24 with all the available goodies Waldron ammo counters and rudder pedals,Eduard placards ,seat belts and guage set , Verlinden accy kit . Yes the gangs all here! I pre assy'd all the cpit components and will build the ip tonight.I have been battlin' with the Indian 841 wip in auto's.
When I post here ,shoot over to the wip in aircraft for the full details.
Thank you ,Krow113
Krow- the build is looking great so far..
sturmp- Nice paint job on the nightfighter? right
Dave- congrats on finishing the GB....shes one heck of a build, waht MM paints did you use
-Matt
facebook me Matthew Browning if you'd like to talk about the hobby
Work Bench Builds
Tamiya fw-190 d9 jv44
Revell-Monogram visible B-17G
Hello everyone!
i signed up for this group build when it started, then got involved in the NMF II GB and built two planes, so now that that is done, here I am to finally get started on the 190! After looking through the prior posts, I am kinda worried that my build won't be at the same calibre! Anyways, I am going to do the AM 190 A8. When I bought this kit (~1 yr ago), I also got the cockpit PE as well as the engine/exterior PE set- I had planned to expose the engine. I'm not sure if I am going to do that now- I'll see how the build goes. Hopefully I'll have some WIP over the week-end,
Rob
On the bench: Revell 1/72 HCMS Snowberry
Max fax--
Dave--Tremendous finish and almost as fast as Guy!
Stump--Great mottling and chipping. Don't go blind!
Krow--I have never tried 1:24 scale before. Fantastic detail. I hope you keep posting here.
Mike--The misfit was a real shocker but the group here talked me down from the ledge with the solid advice. I used an Eduard 1:32 mask with the length cut down for the spinner.
Frank--I will post pics tomorrow. I repainted the front portion of the wing underside with Mr Color RLM 75. The photos I posted show MC RLM 81 which I felt was too green. The Eduard painting instruction called for the RLM 81 but the Eagle Cals sheet called for RLM 75. The RLM 75 is much closer to the color Eduard actually depicted on the sheet, more of a deep gray than a green. I am getting my plan in order to paint the very heavily mottled top side and want to practice a bit with AB before I spray the plane itself.
Hugh
Looking forward to your build Max!!!!
Got the wings on my lil one last night/this morning. Going to add the tail feathers tonight after work. then will post a few pics. I test fitted the bottom half of the wing and everything looked ok, top halves didn't have locator pins!!! Was a bit worried at first, then realized I could fine tune the fit. There is the proverbial at the root but at least all the edges are even so that gap wasn't very big or a worry. Ok,I'm off to play with the BIG birds.
Goosh... thanks everyone for your really kind remarks. I had a lot of fun with it and a big thanks to Frank for hosting another great GB. So what's in store for RDIV or is that already decided?
Chewy, I used MM acrylics and the main colours were RLM 76, 81 and 82. I used polyscale RLM 04 for the yellow band and rudder.
Dave
razordws So what's in store for RDIV or is that already decided?
LOL, funny you should ask!
I am thinking about holding off on RDIV for a while, and doing something a bit different for the next GB!
Frank
Watching Catch 22 I thought that would be a cool GB .There is Dreedles custom B-25 , Milo's command car , and a number of other possibility's
Ip werk tonight........
OK guys, here she is, you've been following along so you know the drill. My special surprise is a Pilot and Crew Chief Spiess by Verlinden, first time I've done 1/35 figures since my teenage years, I thought they came out pretty good. Anyway, giving some serious thought to 1/32 Dora as a follow up, we'll have to see though.
aka Mike, The Mikester My Website
"He has all the virtues I dislike and none of the vices I admire." -Winston Churchill
Holy crap Mike, that is freakin cool! Now THAT is how a mottle scheme is supposed to look, perfect. Love the worn off paint on the back of the blades, nice touch. Well done all 'round!
Daywalker Holy crap Mike, that is freakin cool! Now THAT is how a mottle scheme is supposed to look, perfect. Love the worn off paint on the back of the blades, nice touch. Well done all 'round!
simpilot34 Daywalker: Holy crap Mike, that is freakin cool! Now THAT is how a mottle scheme is supposed to look, perfect. Love the worn off paint on the back of the blades, nice touch. Well done all 'round!
Spectacular build all around Mike! The figures are a nice touch.
Got the wing and tail bits on!!! Now will set at the bench later this morning(2am now) and commence sanding and filling the seams. Overall withe flying surfaces not a bad fit. A few gaps at the wing to fuse which seems common to most low wingers. The destructions is dated '92 and only give color refs as Black Green, Dark Green, and Light Blue. So would this be a typical 74, 75, and 76 scheme? Just looked at the color chips in my Vol. 2 Luft camo & mark book and it may be 70, 71, 76. Any ideas guys? Anyway here's a progress pic.
..and the inspectors photo
Mike, what an outstanding build all round. I am especially impressed with the different styles of motteling and the great controle you have over it. As usuall I like the way you present your builds.
Sim, nice progress and I know what your going through with the paint colours issues. Cant help ya on the colours as I dont know what version your building. These late war planes had so many different schemes.
Steve
Frank, on the subject of iv, I can agree that something different for the next GB is a good idea, something totally different would be cool.
Chaps - am now ready to apply a flat coat to the bird and I guess that will be it! I have some Tamiya Flat Base which I have never used before. I have read I can use this with Future to create a good flat coat. Is this a good idea or should i get a dedicated flat varnish, and if so which one?
Next up:
Trumpeter 1/32 Me109E-3
Dragon 1/32 Bf110C-7
Wingnutwings 1/32 Bristol F2B
Thanks Steve!!!! I'm building an A-8 and will dig around a bit more and see if I can come up with a lil more definitive cor description.
Stump, yes you can go down that route if you wish. There shouldn't be any problems. In mixing it up though, add enough flat base to get it satin then add just a touch more to get it flat. If you add too much you will start to get a frosty appearance. HTH
Mike-- She looks mahvalus! It feels like your looking at a scene in th Bavarian alps. Is that a background image or your backyard?
Stump--Call me chicken but I would never stray from Dullcoat applied with an AB. I can't tink of anything that would make me madder than to get to the point of final seal coat and have a major disaster because of a "home brew" miscue. It would make me
All--As I said before, I repainted the underwing forward section RLM 75 because the RLM 81 I used looked too green. Here is the difference;
Before:
After:
I have also nearly finished the topside camo:
Hugh she is coming along nicely mate!!! That is a very interesting camo you have there!!!!
simpilot34 Hugh she is coming along nicely mate!!! That is a very interesting camo you have there!!!!
love the camo job Hugh
Stump i agree with the other guys as well regarding the topcoat....
Hello all,
OK so I picked up a 1/48 ProModeler FW-190 G3 at a swap meet a year back and was aware that it was missing some parts related to the cockpit. So I bought a CMK replacement and started to work on it for this build. I got the cockpit 99% done as well as getting the wings and the fuselage started. And then I found out the terrible truth: The forward fuselage cover(part E1)was missing. Son of a &^#$&! Well, I sent a quick note to the host of the group build and he gave me permission to ask you fine folks if maybe, just maybe, you have one to spare. Perhaps a kit bit the dust? Perhaps you too have a partial kit? I believe this kit was originally issued by Trimaster, then Dragon(DML?) before the ProModeler kit. Any help would be greatly appreciated!
Thank you
Hey folks - I've finished my Tamiya 1/48 A-8/R2! I started this as an experiment to learn airbrushing and weathering techniques and never really envisaged I would complete it. But in the process I started too use the Finescale forum and Daywalker suggested I join the Group Build. I've had so much advice and support from a large number of you so thanks so much, you've really helped me move this hobby on.
Things that went well:
Things that went badly (and remain so!):
Here are a few photos - apologies, depth of field is not great and background needs tidying. I'll give it another go next weekend.
IMG]http://i1044.photobucket.com/albums/b445/sdellow001/Fw%20190%20Model/DSC_0497.jpg[/IMG]
Stump--Great job on the A-8.
You finished her and that is an accoplishment indeed. Since you have also improved your control of the AB, that is a double bonus. This was my frist GB too and I also benfitted from the advice of he group. Keep going with the GBs
Hugh- love that camo, don't see that everyday! Perhaps I missed it before, but is this one going to be "yellow 10"? Reminds of the wartime camo on that bird.
Mike- Sorry, I don't have the part you need, but hopefully someone here can help out.
stumpjumper70- Magnificent! Really a great looking 190, thanks for being a part of the GB! I added your finished build status to page 1.
Frank--You nailed it. This is going to be "Yellow 10".
Dave - Herman looks right at home in the cockpit! Nice work!
Mike - Stunning build! Your plane and figures look great and the background makes them look so real!
Hugh - That's a crazy camo scheme but I like it! Good job!
Stump - Your A-8 looks fantastic! It's amazing how much you can learn on one build if you're willing to try. I like your weathering. Something I can't seem to get the hang of.
With so many beautiful builds, I think that I'm going to keep the ball rolling. Yellow 4 is finished! Have a look and I hope you enjoy!!!
Sorry for posting so many pictures but I was proud of the way she turned out and wanted to show her off! Any comments and criticism welcome!
Jeremy
Clebode Frank--You nailed it. This is going to be "Yellow 10".
HA! I knew it. Looks just like the photos I have of her.
Jeremy- OUTSTANDING! I like it very much, and as far as criticism- can't see anything I would change. The paint looks flawless, and the spiral- I love it! Well done.
Great FW-190's for everyone who finished... Today was a rain out so I got alot done. only thing I'm Noticing is on pre fitting the open canopy there's gap between the fuselage and the canopy
Jeremy- Keep the ball rolling? I think you just rolled over the rest of us! That thing is a show winner, absolutely flawless, don't know what else to say.
Stumpjumper- Great looking build, love that exhaust staining, some of the most realistic I've seen. What's your secret?
