Sorry guys.....forgot to post this here on Mon.
It is fitting that I finish this model for the 1/40 FA on Memorial Day weekend. To all my FA brothers at from the 1/40, Happy Holiday
Well I was down to details. First I drilled a hole in the chassis and thru the base. Using a furniture screw and nut I secured the M108 in position. To make the tracks look proper on the ground, I coated the underside of the tracks with cell-u-clay tinted with Raw Sienna acrylic. I used the same mix tor “glue” all the details sitting on the ground.
As for the details
· M16s- Dragon M16 kit, painted Tamiya Flat Black on the plastic areas and Alclad Burnt Exhaust for the metal areas.
· 105mm Ammo Crates – Custom cast resin, custom decals, Poly Scale US Earth Base and coated with Tamiya Buff. After flat coat, dusted with MIG VN Earth pigment.
· Section Chest – Resin cast, Poly Scale Tac Dk Green, Alclad Steel on hinges and latch, dusted with MIG VN Earth pigment.
· 105mm High Explosive – Resin cast, Alclad Pale Gold casing, Tamiya Dk Copper rotating band, projectile Tamiya OD, PD fuse Alclad Pale Gold, MTSQ Time fuse Tamiya Flat Black, custom decals.
· 105mm WP – Resin cast, same as HE except projectile is a mix of Tamiya Olive and Cockpit Green.
· Plywood – 1/64” plywood, cut to scale for 4 x 8 sheet, grain enhanced using a Winston Oil Dark Sienna wash, dusted with MIG VN Earth pigment.
· Bug Juice container – Tamiya, Alclad Steel
· Gas Cans – Resin Cast, Poly Scale Tac Dk Green, Floquil Bright Oil for spilled diesel stains.
· 105mm Fibers – AFV, Tamiya Flat Black, gloss on the end caps
· Aiming Posts - .040 styrene rod, Tamiya Flat Red and White
· 50 cal Ammo Cans – AFV, Poly Scale US Med Green, MIG Dark Wash.
· 50 cal Ammo Belt – Academy, Alclad Pale Gold and Tamiya Flat Black
· M2 50cal – Parkerized finish with a 70/25/5 mix of Tamiya NATO Black, Metallic Grey and JA Green. Handles are Tamiya Flat Black
So without further waiting, here is the finished M108 of the 1 BN 40 FA form Vietnam
As always thanks for stopping by. Your comments good or bad are always appreciated.
Next up may be the M1200 conversion of the M1117
Remember a vet! Happy Memorial Day
Rounds Complete!!
EOM!!
