The Official 1942 70th Anniversary Group Build
    May 2012
Posted by Old Ordie on Monday, September 3, 2012 1:59 PM
 YesLooking good - very nice seam work, man. Wish mine looked that good.
Flight deck:  Hasegawa 1:48 P-40E; Tamiya 1:48 A6M2 N Type 2 ('Rufe')
Elevators:  Airfix 1:72 Grumman Duck; AM 1:72 F-4J
    September 2009
Posted by sub revolution on Tuesday, September 4, 2012 3:05 AM
I agree, excellent! I tend to shy away from seam work if I can away with it, because I just cannoy get it to look good!
NEW SIG
    August 2005
Posted by corvettemike on Tuesday, September 4, 2012 3:20 AM
Thanks guys :) Bondo attack round 3. It's almost ready for rescribing and final prime.
Rise my brothers we are blessed by steel in my sword I trust...
Arm yourselves the truth shall be revealed In my sword I trust...
Havoc Models
    May 2012
Posted by Old Ordie on Tuesday, September 4, 2012 7:00 PM
Yes
    September 2003
Posted by checkmateking02 on Tuesday, September 4, 2012 7:35 PM
Nice work, Mike.  I looked at your website.  You've got some nice looking models there.  Very impressive.
    July 2004
Posted by stikpusher on Tuesday, September 4, 2012 7:50 PM
Well, I finally kicked off my TBD build today.
This is everything I will be using. The basic Monogram kit, some PE seat belts from a Lions Roar generic set, other USN aircraft details from a Tom's Modelworks set, main decals from Aeromaster, and prop tips decals from Yellow Wings, and USN aircraft instrument decals from Pro Modeler...
I only did very basic construction and clean up today.
The Engine
In the cockpit I added the Lions Roar seat belts on all positions.
and on the gunner's "turret" I added PE seat belts and the preforated elevation skate rail where the gun mounts.
more to follow...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    August 2005
Posted by corvettemike on Wednesday, September 5, 2012 1:38 AM
"Nice work, Mike.  I looked at your website.  You've got some nice looking models there.  Very impressive."
Thank you sir Embarrassed
Havoc Models
    October 2008
Posted by bsyamato on Wednesday, September 5, 2012 4:19 AM
Nice workin Spit Mike Yes
Stik i like the devastator!! and this old monogram seems really more detailed than the tamiya ki-84 you started in the jap GB!! what things must to see Tongue Tied
    September 2009
Posted by sub revolution on Wednesday, September 5, 2012 5:04 AM
stikpusher
Woooo!! Coral Sea build, right? Looking forward to it!
NEW SIG
    May 2012
Posted by Old Ordie on Wednesday, September 5, 2012 3:15 PM
stikpusher
I wish this sucker had been available when I bought my TBD - it woulda saved me a lot of money (yeah, I bought one of those Great Wall kits ...).
    July 2004
Posted by stikpusher on Wednesday, September 5, 2012 4:07 PM
    BSY, yes the TBD is certainly more and better detailed than the Tamiya Ki-84. And they are both of the same vintage- mid 1970s or so. It was kits like this that forced Tamiya to step up their game.
    Sub, yes she will be a Coral Sea build, the TBD's grand moment of glory on May 7th, 1942.. but I suspect that the decal sheet I am using is mis-labeled.  From doing a little research, I have learned that the Lexington's air group never used black numbers, they stuck with white. The Eagle Strike sheet (not Aeromaster as I previously said) has black numbers. So I suspect that this is a VT-5 aircraft. Also the Bu. No. is 0325. That TBD survived to be the last TBD in the Navy inventory, being stricken in 1944. Unless 0325 recovered aboard Yorktown instead of Lexington at Coral Sea on the afternoon of the 8th.
    Ordie, this kit has been issued many times and is still fairly easy to find on ebay and such... This particular one has been in my stash for well over 10 years when I found it at a shop that specialized in carrying old kits. I have no doubt that Revell will issue it again sometime soon as they seem to be doing with all the other old Monogram 1/48 kits. This one is one of their best from that time. Too bad it did not come with the twin .30 mount as well.
       - Plankton
LSM
    July 2004
Posted by stikpusher on Wednesday, September 5, 2012 10:05 PM
Today's progress: I spent the day building up things that could be glued together now without having to paint yet.
first up, the outer wing panels
And then I attached the inner wingfold ribs to the lower wing half
Next I built and attached the scoop and attached the torpedo cradle to the lower wing half bottom
Then I attached the bomb aiming doors in the closed position to the fuselage halves
and finally I built the Mk.XIII torpedo and the main gear wheels
yes the torpedo pic did not focus well, but this close up of where I drilled out the bull nose on the tip of the torpedo came out good...
       - Plankton
LSM
    August 2005
Posted by corvettemike on Wednesday, September 5, 2012 11:11 PM
The seam filling is done and all the raised panel lines have been re-done. If the weather cooperates (been raining all day) it'll hit the paint shop tomorrow.
Havoc Models
    September 2003
Posted by checkmateking02 on Thursday, September 6, 2012 7:57 AM
stikpusher
I think you are right in your research, Stik.  Starfighter Decals' instruction sheet  for 1/700 Lexington Air Group says that by Coral Sea only VB-2 had its codes in black.  The rest, including VT-5, kept to white.  The sheet also notes that by this time, the "2" was removed from the codes; VT-2 omitted the " - " in the codes.
The sheet is pretty well research, citing five references for its conclusions.
    July 2004
Posted by stikpusher on Thursday, September 6, 2012 11:58 AM
Yes, and I have had no luck so far of finding a photo from Coral Sea that shows one way or the other. The Squadron numbers on codes had been been removed some time earlier for OPSEC reasons. I would like to know the souce(s) of Eagle Strike's reference for this sheet. If it is a VT-5 TBD, Yorktown airgroup was also putting the aircraft number on the tail as well...
       - Plankton
LSM
    May 2012
Posted by Old Ordie on Thursday, September 6, 2012 1:46 PM
stikpusher
   ...  Ordie, this kit has been issued many times and is still fairly easy to find on ebay and such... This particular one has been in my stash for well over 10 years when I found it at a shop that specialized in carrying old kits. I have no doubt that Revell will issue it again sometime soon as they seem to be doing with all the other old Monogram 1/48 kits. This one is one of their best from that time. Too bad it did not come with the twin .30 mount as well.
I was completely unaware of its existance ... I bought my TBD right after the GW kit came out, while I was buying (stashing) PTO Navy kits, the first binge I went on after picking up my Kitty Hawk kit at Hobby Lobby (an impulse buy, and my first 'modern era' purchase - seems like a lifetime ago for some reason, but has only been six months, LOL!)).  Remember when I was all bothered about SBD kit availability, which culminated in my first buy on ebay?  Yeah, I already had the GW TBD kit by then, a pity.  Your sprue (parts) shots look like your Monogram kit is indeed a good one.  If it gets reissued, and I want to build another TBD, I'll sure pounce on it.  Meanwhile, I'll just enjoy following your build.
Smile
corvettemike - Can't wait to see it in paint ...
    September 2003
Posted by checkmateking02 on Thursday, September 6, 2012 4:45 PM
stikpusher
With all the fine references out there these days, I don't know how some decals get produced the way they do.
I suppose that if the sheet is in fact for VT-5, the aircraft number for the tail isn't included?
    August 2005
Posted by corvettemike on Thursday, September 6, 2012 9:05 PM
Back from the paint booth. There's some touch up's that need to be done in places before I can move on to markings and the landing gear. The bottom is RAF sky, and the top is RAF dark earth/dark green all MM Acryl.
EDIT: Several hours later the touch up's where there were bleeds etc.. were done with a brush and the whole thing was gloss coated. All it needs now is markings, landing gear, some light weathering, and the prop to finish it up. Toast
Here is the touch ups done. I used a fine wide brush and thinned paint to re adjust some of my camo lines and you can't really tell where the brushed paint ends and the sprayed begins.
Havoc Models
    September 2009
Posted by sub revolution on Friday, September 7, 2012 3:24 AM
Nice work on the camo job! Looks very good.
NEW SIG
    August 2005
Posted by corvettemike on Friday, September 7, 2012 4:18 AM
Thanks, and would you believe this is my first ever camo job?
Havoc Models
    September 2009
Posted by sub revolution on Friday, September 7, 2012 6:58 AM
Looks a lot better than my first (and only so far) camo job! Mine came out looking cartoonish.
NEW SIG
    July 2004
Posted by stikpusher on Friday, September 7, 2012 1:45 PM
Very nicely done Mike! So let me get this straight, you airbrushed the camo pattern (with a mask I peresume) and then went back and hand brushed touch ups?
       - Plankton
LSM
    September 2003
Posted by checkmateking02 on Friday, September 7, 2012 3:40 PM
Great results with the camouflage, Mike.
    August 2005
Posted by corvettemike on Friday, September 7, 2012 6:37 PM
Thanks all. Yes I masked the pattern with Tamiya tape then went back over bleeds and readjusted some of the lines with thinned MM Acryl and a fine wide brush.
Havoc Models
    May 2012
Posted by Old Ordie on Friday, September 7, 2012 7:16 PM
Nice!  I'm getting ready to do my first three color camo job on a P-40 during the next few weeks, and I hope I do anywhere near as well.
    August 2005
Posted by corvettemike on Sunday, September 9, 2012 12:23 AM
Markings, prop, and wheels installed. It hasn't been hit with dullcote yet. Next update will be the finale...Toast
Havoc Models
    September 2009
Posted by sub revolution on Sunday, September 9, 2012 4:05 AM
Lookin' good...
I notice a couple of decals look like they could use some solvent. That's the only thing I see, and it would only be noticable in bright light.
Thanks, Budd
NEW SIG
    August 2005
Posted by corvettemike on Sunday, September 9, 2012 4:19 AM
Yeah the kit decals were terrible. They didn't want to release from the backing paper even after 5+ minutes of straight soaking and are a bit on the thick glossy side, once on the model they almost became immovable unless you doused them with water and microset. The NK-K silvered badly even over future, I'm working them with microsol and a hair dryer to try and tame them a bit.
Havoc Models
    February 2011
Posted by gunner_chris on Sunday, September 9, 2012 10:54 PM
I am done the 1/72 Airfix Spitfire VB
There's a bit of a story behind it too.
This aircraft belonged to 411 (DB markings) squadron RCAF, who flew in support of the Dieppe Raid.
This serial number AD263 received category C damage and the pilot F/Sgt S.A. Mills was wounded during the battle but still managed to return to base.
This serial number was also known as Miss ABC II.  The story goes the during the battle of Britain an idea came up to "buy a spitfire".  Locals would collect donations to put towards new aircraft.  Apparently one night during a raid the manager of the London cinema pushed a wheelbarrow up and down the aisle asking for donations.  "The more you give, the less raids there will be".  The result was this aircraft along with 3 others.
Of course the reason for picking 411 squadron was also personal.  When I joined the army reserves, basic training was out of the now closed CFB Toronto.  This was home to a helicopter squadron, you guessed it, 411 squadron.  After WW2 it went through a number of changes until its final disbandment in 1996.
Records weren't the greatest, so I don't know for sure is DB*X is actually the right code for AD263.  Even went through the flight records for the squadron but came up empty.  For me its good enough.
My first model with a story and history to it.
    August 2005
Posted by corvettemike on Monday, September 10, 2012 4:32 AM
Great looking spit Chris!
My Spitfire is done as well...
The story of P8088
More history can be found here: http://www.spitfires.talktalk.net/A7_Specials/Spitfire_MK_IIa.html
The Spitfire in question is P8088, a Mk. IIa manufactured at the Castle Bromwich Aeroplane Factory, and donated in January 1941 by the Borough of Lambeth Spitfire Fund. This machine, carrying letters NK-K, an inscription “BOROUGH OF LAMBETH” together with a personal ‘Just Jake’ nose art of P/O Alec Lumsden, arguably ranked as one of the more colourful of the early Sptifires. It became popular with many young modellers of the 1960s when its markings were carried over to the mass-produced 1/72 Revell kit of the Spitfire. This model was since followed by many, including a recent 1/18th version made by 21st Century Models. Microsoft Combat simulator also has a version of NK-K which has been beautifully recreated for computer gaming.
The original aircraft was donated in January 1941 by the Borough of Lambeth Spitfire Fund. There was talk that it would be called the Lambeth Walk after the popular song of the same name but in the end, the more austere name ‘Borough of Lambeth’ was chosen.
P8088 was dispatched for service in February 1941, being taken on charge with 39 Maintenance Unit, Colerne on 1st March 1941 with serial number P8088. From Colerne, P8088 was delivered for active service on 21st March 1941 to No. 66 Squadron stationed in Exeter.
On the 9th April, 1941, the aircraft taken over by No. 118 Squadron at Ibsley where it was given the call sign NK-K. While stationed at Ibsley it was flown by the well known wartime pilot and civilian author P/O Alec Lumsden. It was Lumsden who attributed the nose art depicting Captain A.R.P Reilly-Ffoull (Really Foul), a character from the wartime cartoon strip ‘Just Jake’ and featuring ‘Jane’, a young lady who was forever losing items of her clothing. ‘Just Jake’ ran for 14 years in the Daily Mirror newspaper from 1938 and was drawn by Bernard Graddon.
It is also mentioned that on the 18th April, Lumsden added the name of his girlfriend, Bette, to the door of P8088. No red tape or time wasted back in those days! In Alec Lumsden’s Pilots Log Book, records indicate the exact dates when the nose art and the name Bette were added to the Spitfire. On 16th April 1941, The ‘Borough of Lambeth’ was painted and on the 17th April, he received a telegram from Bette saying “Good luck to Bette the Spitfire”.
After its four month service with Ibsley, NK-K passed to another airfield, Middle Wallop, Stockbridge, Hampshire on 6th July 1941 and then was assigned to No. 152 (Hyderabad) Squadron at Portreath, Cornwall. On the 27th August that same year, the same aircraft moved to No. 19 Squadron at Perranporth, Cornwall as part of an emergency detachment of Spitfires from Matlask, Norfolk.
There, on the 31st August, P8088 suffered an engine failure on a night landing at Matlask. It overshot, ran through a barbed wire fence and tipped onto its nose, fortunately without injury to Pilot Officer N.D.O. Devereux.
P8088 was taken to Exeter for repairs on the 7th September 1941 and was ready for collection by the 16th May, 1942. She was then flown to 33 Maintenance Unit, Lyneham on 3rd June 1942.
On the 21st September that year, P8088 was issued to 61 Operational Training Unit, Rednal and on 19th May 1943 she sadly suffered Category B damage (Beyond repair on site, i.e. repairable at a Maintenance Unit or at a contractor’s works) when Pilot Officer J.H. Gielstrup (Danish) stalled when landing after the engine failed, collapsing the undercarriage on impact.
By the 17th July, P8088 was repaired and went into storage at 6 Maintenance Unit, Brize Norton on 19th July. On the 1st August she was then passed to Central Gunnery School, Catfoss. 22nd February 1944 saw NK-K taken to Heston Aircraft Co., Heston Aerodrome for repairs and was ready for collection on the 26th May, 1944 and delivered to 9 Maintenance Unit on the 14th June. The 1st July, saw P8088 allotted again to 61 Operational Training Unit and on 16th September, 1944, NK-K crashed into the ground at Lower Heath Coppice, Prees, Shropshire, killing Flight Sergeant John Cashel Barry RAAF, 22 years old from Wahroonga, New South Wales, Australia. He was buried in Chester Regional Cemetery.
In 1944/45, P8088 was recovered by Cosford recovery team and stored for spares and scrappage. In 1978, further parts were recovered from the crash site by the Wartime Aircraft Recovery Group, Heritage Aircraft group. The remains were then passed on to Ibsley museum, Ringwood, Hampshire and displayed. The museum was closed down in the mid 1980′s and the Spitfire display and boxed remains subsequently passed to a collector and ex-Cosford recovery team member, Mr Harrington, who then put it into storage.
Over recent years NK-K has attended a number of events allowing a large number of people to enjoy it, sit in it, as well as generate some revenue for charity organisations.
The model
Revell 1/48 Spitfire Mk. II call letters NK-K "Bette' as she would have appeared around 21'st September 1942 with the 61 Operational Training Unit. Though the nose art and "Bette' name were associated with Alec Lumsden they were not removed after the craft was no longer piloted by Lumsden as seen in this image of the remains from 2008
And here is my finished build
Havoc Models
