Striker8241
Bockscar
By the way Russ, how did you hold the little pieces in place while
you cemented them?
Dom
Not very professionally, I'm afraid. First, I glued the two bomb bay doors together at the angle I figured looked about right, then I traced the end of the door assembly onto a piece of paper. I used that as my reference for cutting and laying out the pieces. Once I completed the first assembly, I drew an outline around it to use as a pattern.
While I was piecing together the first assembly, I discovered the pieces were sticking to the paper. I was about to correct this when it occurred to my dull senses that this might be a good thing, if I didn't overdo it, so I let a bit of glue hold the already completed parts while I glued on the next ones. Once the assembly was finished and the glue dry, I inserted a sharp knife between the paper and the part and carefully cut it from the paper.
What would be nice would be a clear material that super glue wouldn't stick to that you could lay over a pattern and build the assembly on top of.
Russ
Russ:
You've managed to re-invent the wheel, your precision looked too good to be a random
glu-it-together.
Wide tape works, like a masking tape with thick stick-um.
Even if you do get some CA on the tape, it doesn't soak through the stick-um on the
tape so you can separate it, at worst, with a bit of varsol or lighter fluid.
a very fine point X-Acto or riffler to clean up the excess CA.
Also you are using patterns, a technique, don't laugh, I learned from my mom when she used to buy
them to cut and sew her own clothes back in 1962, also the cereal boxes used to have cut out rocket ships and planes, and my dad gave me an old acetate drafting guide to trace curves and circles.
My first real job was as a draftsman, go figure. I ended that gig cutting circuit boards on Compaq computers back in the early 80's......
I swear by patterns to this day, especially for guaging the inside of kit parts that need spars.
That is a very good process you have going, time tested and sound.
I can still smell the ammonia from the big blue print machine......lol
