Star Wars GB Episode II CLOSED
    June 2007
Posted by Porkbits on Tuesday, November 24, 2015 10:59 AM
Another quick update...
I'm deviating from the instructions a bit to make painting easier. And thanks again to Brandon for pointing out the wing-orientation gotchas, invaluable info! I'm doing my best to keep the "right sides up." :-)
Hit the wings with some gray/white paint after pre-shading. I'm going for an overall "patchwork in-the-field repairs" look so decided to mask the markings (using the sticker decal sheet as the template) rather than use the decals to get some overspray and general messiness. Then started picking out various panels with darker and lighter grays and some yellow.
Next, I'll seal everything with Future and then start the weathering in earnest (panel line wash, filters, dry-brushing, chipping, and overall color adjustments as needed).
Thanks for looking! And for those in the U.S., hope you have happy and safe Thanksgiving.
Posted by Bish on Tuesday, November 24, 2015 12:11 PM
That is looking very nice PB, really good work.
    June 2007
Posted by Porkbits on Tuesday, November 24, 2015 1:09 PM
Thanks, Bish!
    May 2013
Posted by hogfanfs on Sunday, November 29, 2015 6:58 PM
PB, the X-wing is looking sweet!! Great job!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    May 2013
Posted by hogfanfs on Sunday, November 29, 2015 7:19 PM
OK, I'm finally going to get some pictures posted of the Star Destroyer. So far, I believe this kit was made to be a toy that you glue together. There are seems all over this model, but, Perfect Plastic putty has become my best friend.
I did buy a resin kit for this build, however, I decided not to use many of the parts. I'm not extremely happy with the molding of some of the parts and I started to late to be able to effectively add them to the build.
Anyway the pictures show what parts I am using:
Many of the locator pins had to be removed for the hull to attached correctly:
The hull being glue together:
Here the hull is attached:
Here is the resin Command Bridge. The Deflector Domes are from Shapeways. I am adding the cage surrounding the domes.
I have to finish the cage, then finish the seems on the hull. Hope to get primer on soon.
Thanks for looking! Comments and critiques are welcome!
 Bruce
Posted by Bish on Monday, November 30, 2015 12:58 AM
Bruce, great to see this of to a start.
    June 2007
Posted by Porkbits on Monday, November 30, 2015 11:16 AM
Thanks, Bruce! And your build is off to a great start, too.
Ah, the MPC SD. One of the first kits I built when I got back into the hobby ten or so years ago. I don't think all that aftermarket was available (or I just didn't know about it), so looking forward to seeing what you do with it. It boggles the mind that decades after ANH hit theaters we still don't have a higher-quality SD kit. C'mon, Bandai!
Posted by Bish on Monday, November 30, 2015 11:30 AM
Bruce, afraid I only had time for a quick response this morning. I wanted to ask about that resin hanger bay, which brand is that.
    February 2014
Posted by silentbob33 on Monday, November 30, 2015 11:41 AM
PB your paint is looking really good, I can't wait to see the rest of it come together. Bruce, you're doing a great job on that star destroyer. I'll echo Bish as to what brand the resin is. I have a destroyer in the stash and I might want to pick a set up.
On my bench: Academy 1/35 UH-60L Black Hawk
    May 2013
Posted by hogfanfs on Monday, November 30, 2015 12:34 PM
Bish, PB,
I bought the kit from Avery Model Products.
It's the Devestator Conversion set, but I'm not overly impressed with the quality of the parts. The bay and the engines have been the best parts so far.
 Bruce
Posted by Bish on Monday, November 30, 2015 1:04 PM
Thanks Bruce. I have been looking at the Odyssey on Starship modeller, but that's 40 bucks just for the hanger, but it does look nice. MMMMM decisions decisions. Though saying that, I think I should get an SD kit first.
    May 2013
Posted by hogfanfs on Monday, November 30, 2015 1:36 PM
Bish,
I bought the Odyssey Hanger bay too. It's in several pieces and look very delicate, but very nice. I also bought the Odyssey engines too.
I have enough parts to build another star destroyer, which I may do at some point.
 Bruce
Posted by Bish on Monday, November 30, 2015 1:50 PM
Would you say that Odyessy stuff is worth it then. I have ordered from Starship a few times and even though its across the pond I have had great service and no overly expensive postage. And I think its tie I got those TIE conversions they do anyway.
    May 2013
Posted by hogfanfs on Monday, November 30, 2015 1:56 PM
I think the Odyssey hanger is better than the Avery one I installed. But, it will take much more patience to install correctly since it's in multiple pieces. I installed the Avery hanger because I'm getting to the end of this GB and all I had to do was trim and glue.
Edit: Bish, I'll take pictures of the Odyssey kits along side the Avery kits. Maybe this will give you a better idea. I'll do this later tonight after I get home from work.
 Bruce
Posted by Bish on Monday, November 30, 2015 1:58 PM
Thanks Bruce.
    June 2007
Posted by Porkbits on Monday, November 30, 2015 4:25 PM
Thanks for the info on the SD kit, Bruce, and for the compliment, Bob. :-)
Going full bore with weathering on the wings (downside of building the X-Wing--you have eight wing  surfaces to weather!), hope to post some pics soon of my progess.
PB
    May 2013
Posted by hogfanfs on Monday, November 30, 2015 6:09 PM
 Bruce
Posted by Bish on Tuesday, December 1, 2015 12:50 AM
Thanks for those pic Bruce, that does make it pretty clear what you get. Looks like a bit of warping on the Odyssey kit, but nothing a bit of warm water should not sort out. Very useful, thanks.
    September 2006
Posted by NucMedTech on Wednesday, December 2, 2015 11:35 AM
Cowboy
Man, that is some nice work going on here! 16 days till the end and the sprint is on! PB's x-wing is looking great! Bruce, those updates will really enhance that SD. I used 1/700 quad bofors for my turbo lasers, but those resin ones are really nice. Waiting to see the AT-AT finished up, too. That is looking great. Now, did I see Bish starting in on the Stormtrooper? Those are really big kits. Bish, did you use the spray foam for the inside on this one?
Well looking forward to how this all turns out, keep it up everyone and may the force be with you!
-Stephen
Most barriers to your successes are man made. And most often you are the man who made them. -Frank Tyger
Posted by Bish on Wednesday, December 2, 2015 11:41 AM
Yep, you did see the trooper. He has now been painted white and sits in the shed to dry properly. I will get him out tomorrow to get some pics. No, I didn't use the foam, I did fill the legs with plaster of paris and the head with newspaper. I do have the Boba figure to do so might try the foam on hi.
    February 2014
Posted by silentbob33 on Wednesday, December 2, 2015 12:01 PM
Sorry I've been quiet with the AT-AT. I was out of town for Thanksgiving, and I've had to put more coats of stain on the base than I thought, and it's taking longer to dry. I'm just about done painting up the snowspeeder and I'll get some pics of that as soon as I'm done with it. I'm going to try and have this done by the 18th, but time will have to tell.
Posted by Bish on Wednesday, December 2, 2015 12:21 PM
No worries Bob, as always, the build can still be posted after the closing date.
    June 2007
Posted by Porkbits on Thursday, December 3, 2015 11:18 PM
Thanks, Stephen!
Got the topsides of the wings weathered, so halfway there. Bish, will definitely miss the deadline at this rate, so I'll keep posting photos after if you guys want to see more progress.
Thanks for looking.
PB
PS--Go, Pack! :-)
    May 2013
Posted by hogfanfs on Friday, December 4, 2015 8:24 AM
Wow, PB! Looks outstanding!
 Bruce
Posted by Bish on Friday, December 4, 2015 10:42 AM
That no problem at all PB. I think most if not all GB's are ok with people posting after the end has come. And that is looking really nice indeed, just how I would expect an X-Wing to look. WOW indeed.
    February 2014
Posted by silentbob33 on Friday, December 4, 2015 11:51 AM
PB that is truly amazing! It looks just about perfect
    June 2007
Posted by Porkbits on Friday, December 4, 2015 1:18 PM
Thank you, guys! Your compliments mean a lot, especially since I can be so self-critical. Ugh.
Anyway, I'll prob adjust the weathering as I go along (ie, tone it down or bring it up in various areas) after I get the fuselage in place and can see what the overall look is. The fuse won't be as beat up as the wings, so my strategy is go for more subtle tonal variations in the nose panels and other fuselage bits. Still pondering how to tackle the engines.
And will definitely keep posting progess pics after the deadline. :-)
PB
    February 2014
Posted by silentbob33 on Sunday, December 6, 2015 8:39 AM
I might be posting some pics after the deadline with you.  I stained the base, but it is taking forever to dry, so I'm hoping at some point in the coming week I'll be able to get some celluclay down on it.  In the mean time, I've painted up the snowspeeder that will be zipping around.  I also built the flaps on the bottom side from sheet styrene and the tow line launcher from stretched sprue.  I still have to weather it.
    May 2013
Posted by hogfanfs on Sunday, December 6, 2015 7:09 PM
SB,
The Snowspeeder looks great! looking forward to seeing your AT-AT complete!
 Bruce
    May 2013
Posted by hogfanfs on Sunday, December 6, 2015 7:17 PM
Quick update on the Star Destroyer.
Command bridge is complete. I scratch built the cage around the domes, not too happy with how they tured out. I should have used a touch smaller round stock, and placed them more inside the dome.
Here is the complete SD:
And here with primer:
After priming, I noticed some touch ups that are needed, then I shoot a little more primer, then pre-shade. Then comes the MM Neutral grey!
I'm shooting for the deadline, but I'll be close.
Thanks for looking!
 Bruce
