Well here is a little progress on my build... I'm actually just to the seam sanding stage but thought I would show some of what I'm doing...
This is a really sweet little kit, decent amount of detail for its size (closer to a 1/72 P-47 in size than a 1/48 aircraft)
This is the nice seams it has.. that upper nose piece is just laying there... no glue just gravity holding it down... arrows point to how tight the seams are.
Although bare the cockpit still looks ok... the real ones didn't have much if any more than the model has for a Cockpit...
This is the part that gave me fits... the gear are a 4 or so piece assembly... the lower tank support/landing gear door was a
to get on, you had to insert it vertically between both sets of struts, slowly twist it till it loops the lower struts and fits in between upper and lower struts... THEN you have to swing it in and down at the same time to get the piece in the slot... the second one I put on went in a LOT easier than the first let's just say... it was like a brain teaser puzzle.
---edit--- also notice the fine rivet detail... this is usually WAY overstated on other USN Carrier AC I have built..
Finally a blurry shot showing some of the detail just on the inside... the red line points to the included PE seat belts (has engine wiring, intake grills etc on the sheet of PE as well), the green line shows the floor of the cockpit which also seemed to be nicely molded... the blue line points to the gas tank with retaining straps and all... once closed up you can only see a tiny bit of it, simple molding a bulge into the floor would have worked but they included the whole thing!!!
---edit---- as a seperate piece of assembly, not molded in!
This is a very enjoyable build... and once I get through this slump I am in from all the stuff going on after the storm will build another one and take more time on it!!!
I'm anticipating spraying of Alclad on it by Sat or so.... should be fun!
