Ga.Modeler & Simon U.:
altho' i'm no expert, i will offer the following :
frosty's lozenge 101
be forewarned that roden decals r often not-too-good in terms
of quality...
u mite b better off ordering aftermarket lozenge decals from
Eagle Strike or Americal/Gryphon instead of trying 2 use the ones that
come w/ the kit.
if u do decide 2 try the kit decals, hit them with a coat of clear gloss
or future & let them dry b4hand, this will help 2 hold them together.
when u apply the lozenge, do it over a basecoat which is close 2 the
darkest lozenge color... float the decals on using plenty of water, then
blot w/ a paper towel & use a setting solution 2 help the decal snuggle
down over the ribs. larger pcs. can b cut into smaller sections b4 u
apply them...
finding the little holes 4 the wingstruts after u've covered the wings w/
decals mite b a bit difficult, but u can use a couple of little trix i've found:
do only one side of the wing at a time, then use the other side as a
location guide 2 find the holes (i.e. 'between the 3rd & 4th rib section
from the wing root', or whatever...)
using a cocktail stick w/ a slightly blunted tip & gentle pressure, u will
b able 2 find the strut locator holes & clear them out w/o scratching up
ur carefully applied decals...
repeat 4 the opposite side, using the cleared holes as ur position markers.
i line up the decal w/ the wing's leading edge & trim the trailing edge
w/ a fresh exacto blade once the decal is dry.
future or clearcoat afterwards 2 protect the decals & keep them from flaking off... any damaged areas r best repaired w/ a patch of decal material, but if the area
in question is smallish, the proper basecoat color will probably keep the problem from being too obvious as it will blend in w/ the lozenge pattern.
hth !
Simon:
the Camel is looking really great !
sorry 2 hear that the roden(t) kit isn't one of their better ones, they r like airfix
in that there is a big difference in quality between some of the kits in their line...
so far i haven't met anything quite like what u mention w/ the Gotha, tho' !
Ga.Modeler:
i posted some notes re: wing construction tips 4 the roden dvi 4 rafael pelote
earlier in this thread, u mite find them helpful 4 ur build....
Kaz:
welcome back, hope u r feeling better !
sounds like u made some good scores there at the LHS, too bad about
the shagbat, but at least it's fixable... i really try not 2 handle any of these
little birds too much after they r built, & i still have had 2 repair 2 out of 3
after the short flight 2 the floor...
& believe it or not, i've had a strong wind lift a model a/c or 2 rite off the
shelf, i guess an efficient wing design always works, even in scale, LOL !
i think u should build the sopwith pup (airfix kit?)...
but any of them would b cool...
been hard at work prepping 3 Dr.I kits, 2 4 this GB & 1 4 the Flying Circus GB...
i will have pix 2 post soon...
frosty
