Here are a few items of progress.
Thanks to advice from this GB, I've ordered some decals for the F-82, so I'm really excited about starting that bird. I'm hoping that the instructions have a paint match for the light blue sash in the Milky Way, if not, do any of you have a spec?
But first of all, I'm getting farther with the C-46 (not a part of this GB) in order to clear my bench.* I like getting the antennas right on my aircraft- the ones here are not yet cut to length or rigged, but the solution to flying over the Hump was developing RDF and a hard working radio/navigator, so it needs to be put together right. If I haven't mentioned, only one company kits this aircraft, and I think it's a pretty fine model, too. I'd like to do another one in Flying Tigers Line, and they are planning a new release, so...
On to SAC- the C-54 is starting to look good. I glued the pieces all together and cut out the window strips for replacement with resin inserts. These were ground down on the back with the sanding drum in the Dremel, then popped into place as shown here, finger tight. I'm going to have to scrape out the window slots a little from the inside to get the resin pieces to come out proud so that they can be sanded flush. I've also glued in the kit rectangular windows in the remaining openings, to be puttied and flushed over.
I found this image, which isn't the right aircraft, but it's the finish and markings I think I will do. I cannot find a dedicated SAC C-54 picture. The aircraft at the SAC Museum is a pressurized, radome equipped, basically short DC-6.
This is all based on the Heller DC-6 which I think is a good model to start with.
I bought a little C-45 on eBay for almost nil. I think I'll try to squeeze her in at the end if the F-82 goes together well.
FMM- how's that Stratojet? Do the wings know their roots yet? Can't wait to see.
Wirraway- I'm happy to let you know what not to do w/ the B-36 but it's a great kit.
Tex-?
Yardbird- looking forward to your Thunderjet.
D-Rat- I went back through the string and looked again at your progress shots- great work and keep in the pattern.
Bondoman
On the bench:
C-46 60% (NI This GB)
C-54 15%
F-82 just a bunch of $$ spent so far
C-45 0%
October mystery- ??
